#1 (permalink) |
Wheels In Hand...
I'm looking for something inexpensive. I am planning on doing a carpc down the road so I don't want to spend too much. Anyways, I found this:
http://www.crutchfield.com/S-sVA9044...01&i=113DPX501 on ebay for about $200. I would really like a DD stereo just to fill up the space (no other reason). Anyways, will this fit deck fit? What other hardware will I need? Thanks
Personal Best:
1995 Stealth TT - 11/17/2006 - 1.759 60' / 11.978 @ 116.08 MPH - UNDER CONSTRUCTION Building the 19T record! |
#2 (permalink) |
Volunteer FireFighter
yea, when i upgraded my deck i looked at that, but bought an alpine instead.
ok for compatibility...crutchfield includes harnesses and other hardware free including a wire map... i believe. 1. if you are running all stock now and have a infinity system with a amp, the amp will need to be bypassed which includes cutting the wires at the amp for each speaker and wiring it to the HU direct. 2. if you dont have a amp. it should work fine with the harness they give you. or you may need to cut the speakers at the harness and wire them to rca depending on that deck, im not sure if it uses rca for speakers like my alpine or if it takes it in the harness. 3. it should bolt right in. if you have a cd changer...thats useless after you put the kenwood in. good luck
![]() Mods- 4" Intake, Modded Throttle Body, Re-Grind Cam Shafts, Big Tyla's Ground Wire Kit, Eibach Pro Kit Lowering Springs, NGK Copper Plugs, Accel Thundersport 300+ Red Spark Plug Wires, 6000k HID Kit, 99 Garnish, Prosport Gauges, Evolke 17" Wheels, Hella Optilux Fog's, Custom Exhaust, Clear Corners |
#3 (permalink) | |
Preserve a 3S
![]() October Quickening Best Performance Modification 2004 & 05 -Stealth- Best Non Performance Modification 2004 & 06 Check out the Links "Stealths in Boston" "The 315-Watt Mitsubishi/InfinityŽ CD Audio System with 7 Speakers" "How to install an Amp on a Stock Infinity System. With pics!" "Dash & Door Speaker alternative, installation, & review" '95 RT/TT Firestorm Red one of 61 MSRP $37,448.72 Digital Climate Control Conversion, Radio Control Addition DR-500 turbos, Lucas 550's, RPS Max Street Clutch & Flywheel, Tanabe SM Hyper Exhaust, Greddy Denso, ARC-2, Blitz DSBC, 03 Mitsu Infinity System/in dash 6 Disc Changer Diamond-D971 components, JL e6450 650w 6ch amp Smokin corner box JL W3. 99 lights & fogs w/Hid's . Bridgestone S-03 Pole Position skins. Member #846 6/01 99SL Black (Deb) The first actual 99 Digital Climate Control Conversion Oct. 04, 05, & 06 Quickening "Best Stock" |
