Old 07-19-2008, 01:52 AM   #1 (permalink)
Drives: 3000gt vr4
jetblack3s is an unknown quantity at this point
Default need help hooking up a pioneer adapter to my battery.
i got a pioneer z2 double din HU and trying to install the pioneer CDIB100II ipod adapter. i am trying to figure out where to hook the yellow battery lead into. because i don't think it's such a good idea to tap the ipod adapter to the head unit power(since the power lead to the HU has very small wire) . is there any other way i can hook this up?
jetblack3s is offline   Reply With Quote
Old 07-19-2008, 02:19 AM   #2 (permalink)
umm...yea?
B-Rad's Avatar
Drives: 94' Vr-4
B-Rad is an unknown quantity at this point
Default Re: need help hooking up a pioneer adapter to my battery.
just splice it into the accessory power source. on the headunit harness it will most likely be marked Acc. 12v .
98' New Zealand Green 3000GT VR4 - Sold
94' Panama Green 3000GT VR4. New Set-up to come
Special Thanks to: GT Pro Performance, Disturbing Motorsports
B-Rad is offline   Reply With Quote
Old 07-20-2008, 01:03 AM   #3 (permalink)
Drives: 3000gt vr4
the Acc is the Red coded wire that is used to hook up to the deck right? do i tab another wire into this connection? since the red is already connecting from car to the deck for the ignition switch 12v. and the owners manual on my ipod adapter said connect the adapter to the constant power lead regardless of ignition switch ON/OFF. which is the yellow one from the deck. i am afraid to just tab the power lead from adapter to the deck because i am going to be charging the ipod and watching video from the deck. i don't want it to excess the current capacity of the lead. the fuse on the ipod adapter is 2A, if i run it straight to the battery, it is too much power and burn it fuse right? please, i know you guys know this, help me out.
Old 07-20-2008, 06:07 PM   #4 (permalink)
Preserve a 3S
Dave57's Avatar
Drives: '95 RT/TT
Trader Rating: (37)
Dave57 Level 2Dave57 Level 2Dave57 Level 2
If you look at the fuse box you will see some open spots one will be switched and one will be fill time power.
Blitz DSBC, 03 Mitsu Infinity System/in dash 6 Disc Changer Diamond-D971 components, JL e6450 650w 6ch amp
Smokin corner box JL W3. 99 lights & fogs w/Hid's . Bridgestone S-03 Pole Position skins. Member #846 6/01
Dave57 is offline   Reply With Quote
