#1 (permalink) |
Like a Rat out of Water
I wanted to make a thread about my ongoing carPC project now that I finally purchased a digital camera (I know, welcome to 1998). First, I'll list some specs:
Jetway mini-itx board with VIA C7 @1.5GHz 1Gb of Kingston RAM (motherboard-limited to 533MHz) 120Gb WD 5400RPM laptop drive 64Mb S3 onboard graphics 7" Lilliput USB touchscreen M2 Power Supply VoomPC case (black) That's all I have so far. I still need to get a USB-powered slim DVD drive, GPS antenna w/software and other odds and ends I want to put on this thing. I also need to start thinking about how my speaker and subwoofer amp are going to connect to the audio-out on the mobo. As you may have read in another thread, I am trying to interface the stock steering wheel controls so that they control the volume in WinXP. I'm still in the process of doing that and I will post updates when I have them. ![]() ![]() I also spent a considerable amount of time molding the lilliput touchscreen into the stock radio bezel, but I am still not happy with the results. As you can see in the picture below, I still need to do a lot more work near the buttons. This has proven to be the hardest part mainly because of the curvature of the LCD faceplate. I also need to purchase some flexible interior spray paint that will match the rest of the trim pieces in the car. Tomorrow is supposed to be a warm day so I will probably attempt to complete this portion of the fabrication then. ![]() Hardware VoomPC/M2-ATX Combo - $144.95 + $12.85 shipping Jetway J7F4K1G5D Motherboard - $119.95 + free shipping Lilliput 7" USB LCD Touchscreen - $158.50 + $19.99 shipping Kingston 1024Mb ValueRAM - $22.75 + free shipping at the time Western Digital Scorpio 2.5" HDD 120Gb - $69.99 on clearance Stinger Ground Loop Isolators (x2) - $19.50 + 6.25 shipping Materials/Fabrication QuikPlastik Epoxy - $7.00 + $3.49 shipping Primer filler - Advance Auto Parts (will post price when I find the receipt) SEM interior colorcoat (satin black) - ~$10 Total: ~$675
1991 3000GT VR-4 - 13T, 550cc, E-manage, Walbro 255, AEM FPR
1991 3000GT VR-4 - Full JDM swap in progress ![]() 1991 3000GT SL - Spare parts/Test car Last edited by Wombat : 03-05-2008 at 07:25 AM. |
#3 (permalink) |
Looks like it will be a nice setup. I did this once but didn't do as good of job. I should have gone mini-itx and DC power supply. Here was my page.
http://www.vtc.edu/users/crd04080/carpc
#4 (permalink) | |
#5 (permalink) |
65-70 degrees out so I decided to work on the faceplate a little bit and apply some filler primer to take out any of the small imperfections left in the epoxy.
![]() Going to sand with 600 grit, spray it once more with filler primer, then sand with 800 grit and apply some SEM colorcoat interior paint. |
#6 (permalink) |
Hmm that 7" lilliput screen is a lot different than the 7" lilliput screen I used have. Is that a widescreen version?
Looking good so far. And that black ampie case is nice. I used to have the 1.3 Ghz version of that same C7 processor and found it a bit too weak for my likings. It got the job done, but I wonder if it could handle my needs today. I love running my Red Camera/Speed trap alert program and I think it may be CPU hungry. |
#8 (permalink) | ||
As for computing power, this 1.5GHz has been plenty so far. I have a very light version of WinXP installed on it. It doesn't have internet explorer, windows media player, and all of that other networking BS that you'll never use. Right after the installation, I checked the WINDOWS folder and it was only about 250Mb. My desktop has the full version installed and it's close to 1Gb. The light version also only has about 14 startup processes and my carPC boots into windows a lot quicker than my 2.13Ghz Intel Core2Duo desktop with a 10K RPM HDD and 2Gb of RAM. Quote:
#9 (permalink) |
Wrenchmonkey #839
Can you post what you paid for everything?
I am thinking about building a car pc system but I want to plan & budget it completely before I start. I saw an article for a home entertainment PC that use a 35gig ram drive for the hard drive to get extremely fast booting. Too expensive for me but I bet they will be pretty cheap in a few years EDIT: doesn't anyone make a infrared reader for CAR PC tha could be used with the steering wheel converter http://www.supercar-engineering.com/...WRC/index.html
See this thread to buy remote IAC mounting block:
http://www.3si.org/forum/f4/f-s-remo...bodies-416611/ 1992 Stealth TT ![]() 3.5L 6g74 Swap http://Wrenchmonkey.com/Webpages/6G74swap.html Last edited by John Monnin : 03-04-2008 at 03:24 PM. |
#10 (permalink) | ||
