#1 (permalink) |
Hello. This is my car pc. Sorry I donīt speak English, for that reason i donīt explain anything of the assembly
. Nevertheless if you want to ask some question I will be about responding you ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by TUMITHAK : 08-14-2008 at 11:33 AM. Reason: Update |
#6 (permalink) |
220K club
Welcome.
The installation of the PC was well done. It looks well planned. Nice job you did!
'92 R/T TT 236 K mileage club
AEM EMS, Twin TD-O5 MHI EVO 16G, Electronics: AEM ems, FJO dual WBO2, GaugeTech AEM ems display, custom made EL type main gauge faces, [/size] |
#8 (permalink) |
thank you
The case I believe that I have been made a little bigI have used component these Motherboard: Asus M2NPV-VM HD:250 GB SATA2 3,5" Seagate 1GB ram DDR2 800 MhZ M2-ATX is an intelligent vehicle ATX power supply VGA 7" MM400 Case made by me USB GPS Receiver (Sirf 3 chipset) Amplifier JBL GTQ 400 (75X4) Spearkers front: Herzt DCX (61/2) http://www.hertzaudiovideo.com/Doc/pdf_dcx165.pdf Speakers rear: INFINITY COAXIAL 6x9" 9613l and http://www.pioneer.es/es/products/ar...05A/index.html Greetrings ![]() |
#9 (permalink) |
My first carpc I used a miniITX motherboard and fit all components inside a gutted double din radio. It was pretty tight with all the usb cables, vga cables, etc. At 1.3 Ghz speed was mediocre.
Later I sold it and replaced it with a notebook and have it installed in the trunk underneath the carpet. If you open my trunk you wouldn't know there was anything different because it's all hidden. The plastic tray on the driver's side was replaced custom wood tray to hold the notebook. Heat isn't much of an issue, I only experienced a lock up once after a 3 hour drive in the summer. Easy solution is to flip the carpet partially to allow heat to escape. You might wanna consider using RoadRunner software as your front end, as it's free and makes it look much better. See mp3car.com . p.s. The aerocool panel looks cool. ![]() |
