#1 (permalink) |
Stainless Steel Slacker
I recently installed a Kenwood DDX512 into my '93 SL, and ran into a few problems after installation.
The first problem is that the power antenna does not go up any more. No clue why that is, I'm assuming I took something out that I was supposed to leave in. The second problem was it doesn't seem to have a constant power supply. Every time the car is shut off, the memory of the unit is wiped. Which wire provides a constant power supply? And just so you guys know what I was using to install this, I pulled a wire list off of installdr.com. |
#2 (permalink) |
one day at a time
1991-93 Mitsubishi 3000GT Stereo Wiring Information easy find man hope you install goes well
#5 (permalink) |
constant work in progress
Did you use a wiring harness or did you cut/splice each wire seperately?
Your headunit should have a hole in the back to put the power antenna plug into, if it doesn't, then it doesn't. It's a black 90 degree bend type of plug. If you cut each wire individually, you may need to run a wire to the battery. I don't know why more people don't spend the $5 to get a harness. Not saying you didn't.
'91 VR4 fo' sale! http://www.3si.org/forum/showthread.php?t=392983
![]() Good lord! I'm getting a reading of over 400 Mega-Fonzies! |
