Old 05-02-2008, 03:34 PM   #1 (permalink)
Tribute's Avatar
Drives: 94 FWD S/C ATX
Tribute is an unknown quantity at this point
Default I'm sure this is something stupid I've done... whining sound from speakers
So I put a new amp in my car and whenever the car is on the speakers whine in line with the alternator. Sounds like a grounding issue to me but I've looked and can't figure it out. Any things I should look for?(it seems that SOMETIMES when I mess with the Audio In plugs, it goes away, but it doesn't last... I've opened up the box and the connections look good)
Tribute
-94 3000gt SL ATX DOHC
Current Modifications:
--Polyurethane Motor Mounts
--Test-Pipe
--K&N Filter
--3KGT Motorsports Full-Length Headers
--High Stall Tq. Converter
--Translab-175 Shift kit
--Improved clutches
--Quaife LSD
--Ripp Modifications Supercharger
Tribute is offline   Reply With Quote
Old 05-02-2008, 03:42 PM   #2 (permalink)
DSM GURU
Mike1992's Avatar
Drives: 91 Stealth RT/TT
Trader Rating: (22)
Mike1992 is an unknown quantity at this point
Default Re: I'm sure this is something stupid I've done... whining sound from speakers
Did you run the RCA cable along side the Power wire to the amp? If you did thats my guess.
1992 Mitsubishi 3000GT VR-4 RIP 3/06
1990 Eagle Talon TSI AWD - 11.29@126 - SOLD
1991 Dodge Stealth RT/TT - K&N / MSD Wires / 2.5" Downpipes Merged 4" Cat-back / Hotwired Walbro 255hp / Aeromotive AFPR / Scanmaster 3 / Innovate LM-1 / F&R Solid Motor Mounts / Greddy RS BOV / TD04-13T / Seattle STS / CXRacing FMIC
Mike1992 is online now   Reply With Quote
Old 05-02-2008, 09:12 PM   #3 (permalink)
1992 Stealth RT
jbavousett's Avatar
jbavousett Level 1jbavousett Level 1
You might need to ground the outer jacket of the RCA cables. Sometimes that can knock the whine out.
jbavousett is offline   Reply With Quote
Old 05-02-2008, 10:37 PM   #4 (permalink)
Tribute's Avatar
oh, some info I left out. It makes no difference what the RCA source is. I can plug an ipod directly to the amp and it still makes the whine. Thats how I eliminated the power interference possibility. I also tried ground the rca plugs directy to a car screw. No change at all.
Old 05-04-2008, 09:45 AM   #5 (permalink)
AxeMan's Avatar
AxeMan is an unknown quantity at this point
9 times out of 10 it is a grounding issue.
Change the area where you ground the amp,and check the ground on the head unit (CD player)
AxeMan is offline   Reply With Quote
Old 05-04-2008, 10:02 AM   #6 (permalink)
dodgemystealth92es's Avatar
Drives: dodge stealth es
dodgemystealth92es Negative 1
it could also be jest the rca cables alone. cheap rca's can do this. but as stated most often it is a ground issue. ground the amp better and ground the batt to the body better, as well as the head unit. it should go away. but the way you can tell if its a groundproblem is unplug all rca cables and turn it way up. then plug in the rca. if it is still there without rca its in your ground if its only there with rca's its coming from the rca or the head unit.
dodgemystealth92es is offline   Reply With Quote
Old 05-04-2008, 08:17 PM   #7 (permalink)
Tribute's Avatar
ok its only there when the RCA's are plugged in. It seems to be there regardless of which rca cables I use however.
Old 05-05-2008, 12:03 PM   #8 (permalink)
3KGTVT's Avatar
Drives: 1995 3000GT SL
3KGTVT is an unknown quantity at this point
Did you wire the amp directly to the speakers or to the wiring harness behind the cd player? If it is wired into the wiring harness you need to unplug the stock amp under the passenger seat. Good luck
3KGTVT is offline   Reply With Quote
Old 05-05-2008, 03:36 PM   #9 (permalink)
Tribute's Avatar
I removed the stock amp, cut the harness at the amp, then spliced wires to the resulting exposed wires(which led to the speakers) then attached the wires to the amp screwed onto the back of the passenger side back seat.
Old 05-06-2008, 07:06 AM   #10 (permalink)
Paid Member
973000GTSL's Avatar
Drives: 97 3000GT VR4 Black
973000GTSL is an unknown quantity at this point
Stinger SGLI Car Audio RCA Ground Loop Isolator Install Accessory
1997 3000GT VR4 Black
RoJa R2-5 18X9 w/Dunlop Direzza Sport Z1 Star Spec
KN FIPK
Mods to be installed
Apexi AVC-R
Walbro 255 hotwired
Unorthodox Underdrive Pulley
1997 3000GT SL Black (sold)
973000GTSL is online now   Reply With Quote
