Old 05-06-2008, 04:55 PM   #11 (permalink)
Tribute's Avatar
Drives: 94 FWD S/C ATX
Tribute is an unknown quantity at this point
Default Re: I'm sure this is something stupid I've done... whining sound from speakers
Ok well, I did some more investigating. When I plug the RCA-1/8th cable into the IPOD only part of the way, the whining goes away and the sound comes out of both speakers but is only half of the signal(obviously). Also I noticed that when the whining is occuring the amp heats up quickly, almost to the point where I feel it would overheat if left on too long. I'm starting to think this is an amp problem and not a problem on my end. Thats my third amp in a year...
Tribute
-94 3000gt SL ATX DOHC
Current Modifications:
--Polyurethane Motor Mounts
--Test-Pipe
--K&N Filter
--3KGT Motorsports Full-Length Headers
--High Stall Tq. Converter
--Translab-175 Shift kit
--Improved clutches
--Quaife LSD
--Ripp Modifications Supercharger
Tribute is offline   Reply With Quote
Old 05-10-2008, 05:05 AM   #12 (permalink)
Crash66 is an unknown quantity at this point
Ok since I assume your still chasing this, I would suggest you start from the beginning and eliminate the basics first. The ground wire for the AMP needs to be as short as possible and grounded to a very clean bare metal body ground also check the body ground from the battery always worth the time. That wire also needs to be the same guage wire as the power wire if possible. It is very possible it is literally just the amp grounding and to long of a ground wire will cause hum. If that doesn't fix it step 2 would be to start looking at the remote turn on wire coming I assume from the head unit..is it coming from the head unit or are you using a different source to power it? The fact that you say this would be your 3rd amp in this car should tell you there is a major problem in what the amp is getting. It sounds like a ground difference problem to me but on the other hand I would check it all since it is wiping out your amps. My guess is the actual amp ground not being proper but thats a shot from the cheap seats since I am not looking at it! Anyway hope that helps some if not I will watch your response!
Crash66 is offline   Reply With Quote
