Old 05-13-2008, 11:31 AM   #1 (permalink)
Drives: 1993 VR4
clumzy is an unknown quantity at this point
Default Getting better sound and bass out of 6x9s
I've been seeing that some people are complaining that even with upgraded 6x9's bass is terrible. I have Infinity Reference 6x9s and I can't get a nice bass sound out of them. I'm thinking it's the ported enclosure.
I'd like some opinions on how it would sound if I sealed the port and filled it with some loose poly batting. I understand that's pretty common in home subs.
clumzy is offline   Reply With Quote
Old 05-13-2008, 05:07 PM   #2 (permalink)
Preserve a 3S
Dave57's Avatar
Drives: '95 RT/TT
Trader Rating: (37)
Dave57 Level 3Dave57 Level 3Dave57 Level 3Dave57 Level 3
Default Re: Getting better sound and bass out of 6x9s
The easiest fix is to add a "basslink" powered sub
Blitz DSBC, 03 Mitsu Infinity System/in dash 6 Disc Changer Diamond-D971 components, JL e6450 650w 6ch amp
Smokin corner box JL W3. 99 lights & fogs w/Hid's . Bridgestone S-03 Pole Position skins. Member #846 6/01
Dave57 is offline   Reply With Quote
Old 05-15-2008, 01:04 PM   #3 (permalink)
Drives: 1993 VR4
well yes and no. The rear speakers sound bad so fixing that would be ideal. That and I road course so I'm not putting any more weight into the car.
Old 05-15-2008, 02:05 PM   #4 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (66)
I'm no expert, but why not grab some duct tape and give it a shot? Worst case it won't work and you can pull the tape off the plastic, right?
Are you powering the speakers through an amp? Do you have the pre-out adjusted correctly? Do you have the crossover and bass amplification all configured?
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts Nov 2008 ROTM
Old 05-15-2008, 02:09 PM   #5 (permalink)
Kibwe Walker's Avatar
Drives: 93 RT/tt
Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7
What are you using for a head unit?
If you get a good head unit with a highpass and low pass filter you can designate which wavelengths are played by what speaker groups allowing the speakers best able to play whatever wavelength to have just that wavelength and not have any inteference (trying to play everything).
I have 2 tens in the back with r tweets, two 6.5's and two 6x9's. Letting it just play is one thing, getting in there and messing around with the EQ is a night and day difference with the low pass going for the subs and high pass going for the other speakers.
His - Red 93 RT/tt
Mods: Hallman's MBC @ 16 psi, turbo XS type H BOV, stillen dp, custom exhaust, Spec stage 2 clutch, RPS FW, 3sx lightweight crank pulley, BCP7RES-11 @ .030 gap, autometer gauges, slightly gutted mas, dsm SMIC's, ACPT 1 piece CFDS, Tein S springs, pte 580 inj's, safc neo/SITC, 13t's, hotwired walbro, maximal performance solid motor mounts, DR plenum spacer.
Hers - BPU Green 94 vr4
Kibwe Walker is offline   Reply With Quote
Old 05-15-2008, 02:46 PM   #6 (permalink)
Drives: 1993 VR4
I have a Pioneer DEH-770P headunit and a Pioneer 480W 4channel amp powering the rear 6x9s. I've fiddled with the highpass and lowpass stuff but the problem is either the speakers suck or the enclosures aren't right for the speakers. I'm pretty sure that people here are running powered Infinity ref 6x9s and I've never heard of issues.
Old 05-15-2008, 08:59 PM   #7 (permalink)
streamlnauto's Avatar
Drives: 1993 VR-4
streamlnauto is an unknown quantity at this point
The biggest reason is the enclosure for them is tiny and flimsy. The only thing you can really do is re-enforce the stock enclosure with some fiberglass/sound deadening, also seal up the back side of it where it sits against the metal with some silicone, and plug those horribly tuned tiny ports.
It will help a little, but its not going to be a huge difference.
streamlnauto is offline   Reply With Quote
Old 05-16-2008, 09:03 AM   #8 (permalink)
Drives: 1993 VR4
Thanks for the advise.
Old 05-16-2008, 10:45 AM   #9 (permalink)
DC 95VR-4's Avatar
Drives: 99 VR4
DC 95VR-4 is an unknown quantity at this point
ditch the 6x9s and go with some fiberglass pods for 6.5s or 8" midbass
DC 95VR-4 is offline   Reply With Quote
Old 05-16-2008, 11:05 AM   #10 (permalink)
Drives: 98 sl
98slept Level 398slept Level 398slept Level 398slept Level 3
i increased my bass response by adding dynamat on the hatch and a little on the trunk walls. now i hear a real nice clean deep undistorted bass from my STOCK SPEAKERS. help me hope it helps
98 SL TWIN TURBO
TT 9b's at 5psi/ 95 TT ecu/Ebay precat eliminators and downpipe/3sx lightweight pulley/k&N intake/Fidanza lightweight flywheel/Centerforce dual friction clutch/walbro 255 fuel pump/MP solid motor mounts/Passport gauges/99 front conversion/l.e.d gauges/needles
98slept is offline   Reply With Quote
