Car audio Woes - 3000GT/Stealth International Message Center
Old 12-11-2012, 03:15 PM   #1 (permalink)
Drives: 1991 3000gt SL :(
J_train is an unknown quantity at this point
Feedback Score: 0 reviews
Angry Car audio Woes
I had been running a nice setup in my 91 SL for a while, but then one day my subwoofer went out, bought a new type R to match my amp, and I just got it all hooked up again today, to watch it play for 5 seconds then my radio shut off, and since it didnt turn back on I went on adventure through my wires to found out the dumbest fix.... my radio power wire, had been run into my brake light fuse under my steering wheel.... I feel society is too lazy for its own good, REGARDLESS I was curious if anybody knew what color the actual battery wire was on the harness. I cant seem to find a good diagram today thanks for the help!
Keep it Classy
J_train is offline   Reply With Quote Quick reply to this message
Old 12-11-2012, 05:30 PM   #2 (permalink)
Default Re: Car audio Woes
New problem I'm drawing no power from my harness I checked it with a meter, and an pulling nothing so what fuse would I have to replace to fix this?
Old 12-11-2012, 06:36 PM   #3 (permalink)
Drives: 91Stlth95spdr93supra
blackandblu is an unknown quantity at this point
Feedback Score: 1 reviews
1991-93 Mitsubishi 3000GT Stereo Wiring
Constant 12V+ Red/Black
Switched 12V+ Blue
Illumination Green/White
Dimmer n/a
Antenna Trigger White/Black
Antenna Left Rear
Front Speakers 6 1/2" Doors
Left Front (+) White/Blue
Left Front (-) Black/Blue
Right Front (+) White/Red
Right Front (-) Black/Red
Rear Speakers 6" x 9" Side Panels
Left Rear (+) Yellow/Blue
Left Rear (-) Gray/Blue
Right Rear (+) Yellow/Red
Right Rear (-) Gray/Red
blackandblu is offline   Reply With Quote Quick reply to this message
Old 12-11-2012, 07:24 PM   #4 (permalink)
bearded1's Avatar
Drives: '93 VR4
bearded1 is an unknown quantity at this point
Feedback Score: 8 reviews
Check out Jeff's site for the wiring diagrams for various ecu's. Could tap ignition or +12v there. I'm not sure what you need at this point from your description. Check your fuse boxes for a stereo labelled fuse. - Stealth 316 - ECM pin assignments
bearded1 is offline   Reply With Quote Quick reply to this message
Old 12-12-2012, 10:59 PM   #5 (permalink)
Preserve a 3S
Dave57's Avatar
Drives: '95 RT/TT
Dave57 Level 1Dave57 Level 1Dave57 Level 1
Feedback Score: 38 reviews
The Fuse box has two open taps. (in the Fuse slots) One is full time power. (that's for the radio's yellow wire) then there is an open tap for switched power.
Blitz DSBC, 06 Mitsu Infinity System/in dash 6 Disc Changer Diamond-D971 components, JL e6450 650w 6ch amp
Smokin corner box JL W3. 99 lights & fogs w/Hid's . Bridgestone RE050A skins. Member #846 6/01
Dave57 is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
