Old 05-11-2008, 08:48 PM   #1 (permalink)
Drives: 94 VR4
Trader Rating: (19)
Blue94VR4 is an unknown quantity at this point
Default which antenna to use with AM unit?
Hi,
I am replacing my stock double DIN unit with an aftermarket Pioneer unit. My stock unit has 2 antenna inputs: one on the rear windshield and one for the power antenna. Which one should I use with the new unit? Which one provides better reception? I know that most people keep power antenna, why is that?
Thanks,
Sergey
Blue94VR4 is offline   Reply With Quote
Old 05-12-2008, 10:19 AM   #2 (permalink)
Drives: 3000gt sl & 93 RX7
boomboom is an unknown quantity at this point
Default Re: which antenna to use with AM unit?
i wonder if they make a splitter so you can use both?
boomboom is offline   Reply With Quote
Old 05-12-2008, 11:53 AM   #3 (permalink)
Drives: 94 VR4
Trader Rating: (19)
You cannot use both, has to pick one, ut which one?
94 3000GT VR4 (upgraded)
"Your 1994 Mitsubishi 3000GT VR-4 is one of 1650. There are 57 other cars that were made with both the same interior and exterior color. Exactly Identical - 8"
For sale:
1. used stock oil sender & gauges
2. used A/C belt (10K on the belt)
3. Stock front and rear sway bars.
4. 3SX dual O2 simulator
5. Used 2'' couplers/reducers/hump hoses
Old 05-12-2008, 08:50 PM   #4 (permalink)
Drives: 94 VR4
Trader Rating: (19)
Anyone?
Old 05-12-2008, 09:12 PM   #5 (permalink)
carsoncars is an unknown quantity at this point
im sure the antenna in the rear hatch is for AM and the pw one is FM.
carsoncars is offline   Reply With Quote
