#11 (permalink) |
Moderator
I saw this on e-bay, something you might find interesting:
http://cgi.ebay.com/PERIPHERAL-MITAH...QQcmdZViewItem Supposedly you can use aftermarket amps with the stock Infinity amp using that cable. Also, do you know if those single-din Infinity headunits will plug into a 91-93 car? I saw a 95TT with Infinity speakers using the non-Infinity double-din headunit and it was working. I've also seen the same headunit (looks the same) on 91-93 non-Infinity cars, but it's possible it's a different model headunit that just looks the same.
- 94 R/T Turbo
- 93 VR-4 - 94 R/T - ![]() |
#12 (permalink) |
so was the only diff in wireing the amp the speeker out puts on the amp? what if anything else did u have to change?
can you post a pic showing what you had to do to fix the plug? i am totaly into the factory idea if you read my post on my system i have the j-spec navigation dash. i have no idea what it can out of
![]() You Tube VIDEOS: 3Si06 = http://www.youtube.com/v/uzoYwkslGuQ DWI = http://www.youtube.com/v/BaQ8ofAsGPU |
#13 (permalink) | |
Preserve a 3S
Anything is possible recently I made a plug and play adaptor to test non infinity stock units in infinity systems. ( a line output converter wired between two radio plugs 1 male and 1 female) I have sold several infinity conversion kits they can be installed in any non infinity 6 speaker Mitsu. Eclipse and talon too.
![]() October Quickening Best Performance Modification 2004 & 05 -Stealth- Best Non Performance Modification 2004 & 06 Check out the Links "Stealths in Boston" "The 315-Watt Mitsubishi/InfinityŽ CD Audio System with 7 Speakers" "How to install an Amp on a Stock Infinity System. With pics!" "Dash & Door Speaker alternative, installation, & review" '95 RT/TT Firestorm Red one of 61 MSRP $37,448.72 Digital Climate Control Conversion, Radio Control Addition DR-500 turbos, Lucas 550's, RPS Max Street Clutch & Flywheel, Tanabe SM Hyper Exhaust, Greddy Denso, ARC-2, Blitz DSBC, 03 Mitsu Infinity System/in dash 6 Disc Changer Diamond-D971 components, JL e6450 650w 6ch amp Smokin corner box JL W3. 99 lights & fogs w/Hid's . Bridgestone S-03 Pole Position skins. Member #846 6/01 99SL Black (Deb) The first actual 99 Digital Climate Control Conversion Oct. 04, 05, & 06 Quickening "Best Stock" |
#14 (permalink) | |
By the power of Grayskull
and i saw the car but didnt hear it
![]() ChrisEs1984 : theres alot of pushrod lovers Galganaban : i love to push my rod into your mom shawnisworking : lol shawnisworking : 0wn3d |
#15 (permalink) | |
Preserve a 3S
#16 (permalink) |
Hile, gunslingers!
Excellent write up, and it sounds like you scored big points with Deb. Always a good thing. Great ideas on how to upgrade and still remain "stock."
-golfpro
The current fleet:
'97 3000GT SL, red (hers) '02 Honda S2000, silver (his) '98 Saturn SL, white (winter beater) '93 Ford Ranger, red (203,000 miles and still ticking) ![]() The 3000GT & Stealth Audio FAQ Thanks to Keith Upton for permission to use one of his excellent photographs in my avatar. For some of the best photogaphy on this website, car or otherwise, search "Mobo" in the A/V Forum. |
#17 (permalink) |
Woot!
Dave if you start collecting the plugs you could make an adapter and sell the amp and the plug as a kit, I bet you could sell quiet a few of them. do you know all the specs on the amp? RMs and max watt per channel?
-John |
#18 (permalink) | |
Preserve a 3S
She loves it! Her Dad said it's going to cause hearing damage LOL |
#19 (permalink) | |
Preserve a 3S
I guess you've done some pin pulling RMS wattage??? If one would assume worse case and Mitsu to rate it at 315 Peak. So 160 RMS watts is reasonable Via the peak/2 formula. Or is it the peak x.707=220 watts formula that applies. But then again since the distortion spec never comes into play in these factory systems maybe its 315 watts rms @ 10% distortion. All we have to go by with these is the advertised spec. One good thing is they are still making the amp in 06 ![]() |
