Originally Posted by MichaelMR2
what page and part numbers are you refering to?
Page 22-35 W6MG1 - Input shaft detail
Item #10 / 5th gear bearing sleeve
Item #11 / Spacer ring
Item #12 / Steel ball
Item #15 / 4th gear bearing sleeve
I had 5th and 6th off. The 5th gear bearing sleeve holds the spacer in place. I used my bearing tool under item #17 / 3rd gear to press the assembly apart. I ended up splitting the 4th gear sleeve, damaging the needle bearing, shaft, and ball.
It would appear that I skipped step E on 22-36, but there did not seem to be enough room to get the bearing tool under the syncro teeth of the 4th gear. I would have had to use the teeth surfaces, and thought it would damage the teeth.
