Go Back   3000GT/Stealth International Message Center > 3SI Knowledge Base > 3SI wikipedia Discussions > Technical Documents
Old 03-22-2005, 05:02 PM   #11 (permalink)
Certified PiMp
blusilvr's Avatar
Drives: PiMpMobile
Trader Rating: (64)
blusilvr is an unknown quantity at this point
Default Re: Another Five Car Comparo Motor Trend 1993 w/ VR-4
Originally Posted by UncleDonut
Yeah, I remember that one............I bought it!
Holy Schneikes!!! You have had that car for that long-dayum! 5 spoke dp enduro rims?
What is the color scheme on it??? It was at Norwood Chrsyler, manager back then was Sal Rizzuto. I was in the market for a while back then, they occasionally had sweet TT for sale.
Lamborghini Marketing VP describing Countach- "on the down side, you can't take packages, there are only two seats so no kids, only a beautiful woman. The white one, she is like a virgin. The red one is like a mature woman, the black one like an intriguing woman."
blusilvr is offline   Reply With Quote
Old 03-22-2005, 05:08 PM   #12 (permalink)
2000 C5 M6 Z51 BBQ
oxrageous's Avatar
Drives: On a black dildo
oxrageous is an unknown quantity at this point
Yeah, can you get us some pics?
oxrageous is offline   Reply With Quote
Old 03-22-2005, 06:29 PM   #13 (permalink)
Drives: '91 R/T TT
UncleDonut is an unknown quantity at this point
These are the only ones I have. I drove it mostly before digital cameras were around.
UncleDonut is online now   Reply With Quote
Old 03-22-2005, 08:30 PM   #14 (permalink)
It's all stock.
306GTO's Avatar
Drives: a de-badged sleeper
306GTO is an unknown quantity at this point
Did you ever run it? How long has it been sitting?
Handing out reality checks to "500HP Hondas" for 8 years and counting.
'92 Sandstone Grey 3000GT VR-4. K&N filter, Spec 2 clutch, NGK plugs/wires, Custom EBC, Greddy E-manage Ultimate, built 6G74 engine (in progress), Turbonetics ceramic ball-bearing T-70, custom intake/exhaust/intercooler piping (still plumbing those), 24"x12" FMIC, Brembo rotors, Stillen pads, E-bay Ground kit, 2nd gen shifter, HKS SSQV, Denso 660's, twin Walbro fuel pumps, GTO center garnish, eK2 EGR block-off plates, Prosport gauges: [oil press, fuel press, manifold press, oil temp, water temp, volts], Toni's interior LED conversion (still installing), forgot the rest.
'91 Firestorm Red 3000GT VR-4. K&N filter, eK2 poly engine mounts, Seattle Short Shifter, custom MBC, Forged crankshaft, Tein S-Tech springs (front only), DNP Y-pipe, TD04H-13T's (with 13T wastegates), amber taillights, gutted pre-kitties, eK2 EGR block-off plates, Prosport gauges: [oil press, manifold press, fuel press, water temp], Borla exhaust, NGK plugs, MSD wires, Greddy type-S BOV, forgot the rest.
'90 Fiji Blue 300ZX TT. Stillen front bumper/nose-panel/wing/control arms/sway bars, Greddy intake/exhaust/clutch/fuel injectors, Super Autobachs strut bars, Brembo brakes, Energy Suspension bushings, Tokico shocks, JWT ECU chip, Bomex rear bumper, Nismo gound kit, NGK plugs, IPS short shifter, Custom interior, forgot the rest.
'92 Black MR2. Wife's car. K&N filter on a custom cold-air intake, some interior stuff.
306GTO is offline   Reply With Quote
Old 03-22-2005, 08:34 PM   #15 (permalink)
Suzuki 3000GT
Twinsen's Avatar
Drives: 1997 3000GT VR-4
Trader Rating: (6)
Twinsen is an unknown quantity at this point
Jesus, their driver sucks. 13.2 @ 108mph? That should be good for mid-low 12s.
Twinsen is offline   Reply With Quote
Old 12-14-2005, 06:42 PM   #16 (permalink)
11sec club baby!!!
jrod's Avatar
Drives: 1BADVR4 & 85 Bronco
Trader Rating: (22)
jrod Level 1jrod Level 1
I just bought that issue at a thrift shoppe here in florida i was stunned when i found it i always look for old car mags that might have are car in it b/c the new sure as hell don't
jrod is offline   Reply With Quote
Old 04-04-2006, 12:51 AM   #17 (permalink)
www.pansypatrol.com
henryC's Avatar
Drives: stuff
henryC is an unknown quantity at this point
They should have done a quarter mile test in that water!
-- Henry
1996 Stealth RT/TT
Deleted: AC, CC, SRS, ABS, rear seats and seatbelts, anything on the interior that can't be seen from driver or passenger's seat, all trunk everything, antenna, vacuum tank, evap stuff, heat shields, excess engine junk, keyless entry+security, and whatever else I forgot to put here.
http://www.pansypatrol.com
henryC is offline   Reply With Quote
Old 06-08-2006, 04:07 PM   #18 (permalink)
11sec club baby!!!
jrod's Avatar
Trader Rating: (22)
I just found this mag at a local garage sale for 25 cents. I also found a mag where it shows the HKS vr-4 from like 92.
www.ok3s.org
12.4 at 109 9b's
12.0 at 114 14psi 13t's pump
11.7 at 117 19psi 97oct
I break 25 splines
