#41 (permalink) |
L Burna
IPO, ur site doesn't work anymore, is there anywhere else I can get this info? thanks
ATX TT Conversion w/ DSM 13g's
NA Block w/ .030 over Stock TT Forged Internals w/ 9:1 Ross Forged Pistons Magnaflux, Blueprint, Bored, Honed, Acid Dripped, Balanced Custom SS 2" Intercooler Pipes 450CC Injectors Walbro 255 Fuel Pump Hotwire Fuel Pump SFR Poly Motor Mounts Topline Engineering Ground Wire Kit MSD 8.5mm Superconductor NGK Plugs Emanage w/ Ignition, Injector Harness, Pressure Sensor Autometer Oil Pressure, Trans. Temp, Boost AEM Wideband MirageCorp 94/95 Hybrid Datalogger Custom LED Screen Carputer MBC Open Element Air Intake Dejon Intake Pipes CFR Performance UDP Custom SS 3" Downpipe (cutoff) Power Enterprise Kevlar Timing Belt Tranny Cooler and External Filter Modified Valve Body & High Stall Torque Converter SFR LSD Insert Turbo XS RFL BOV |
