#31 (permalink) | ||
Foolish
I really don't care about the injector impedence if the maps are fubared with the NA ECU in the first place. My concern was to run a TT ECU with a NA ATX controller.You can build a custom harness with all of the wires that send the signal between the NA ECU and NA ATX controller. I had built this harness pin for pin and knew where every wire plugged in to the TT ECU. So now if you follow you would have been able to run the TTECU and harness with this new harness attached and it would have controlled the ATX computer also. Well after 1.5 solid weeks of tracing wires, pulling them from their harness and marking them, I got to 3 wires that had no place to go on the TT ECU. They were all shift related so after talking with Frank at Kormex and Steve at 3SX along with Brian at GTpro I was given the same answer. Well maybe it will work just fine without those wires connected and maybe it won't. Well no shit! So I just pulled the ATX and installed the 5spd. It would be nice to run the TT ECU and the ATX.
Mike Sullivan 95 Stealth FWD TT conversion 10:1 compression@12 PSI
All aftermarket parts happily purchased from 3SX performance.com Turbo conversion parts happily purchased from Mitsuspecialties. |
#32 (permalink) |
Play that Funky Music
http://www.3si.org/forum/showthread.php?p=2165191
DONE http://importpoweronline.com/ipw-web...y/resistorpack
AEM Factory Trained Tuner
T4 AWD 9.21 @ 154.98 T2 FWD 10.19 @ 140.31 T4-159.23 MPH Ran on 6G72 3.1L! T4-995AWHP Uncorrected 6G72 3.0L 91VR4 Red-17Gs w/supporting mods-sold 93SLTT/T2 91VR4 Pearl White-sold 91VR4 Black-sold 92VR4 Sandstone-sold 94VR4 Green-sold 93VR4 Pearl White-currently parting out 91VR4 Black-Currently building "daily Driver" 3SX Performance 3SX Performance Service Email |
#34 (permalink) | |
Moderator
- 94 R/T Turbo
- 94 R/T - ![]() |
#35 (permalink) | |
Member: Burned valve club
Are you 100% sure TT uses Peak / Hold drive for the injectors. I always thought the injectors were low impedance injectors with a series resistor but driven in saturation mode - not peak/hold where the ECU modulates the current. I'll toss a scope on one of my injectors to confirm. If the ECU pulls the injector to ground for the entire duration of the injector period, it is being driven in saturaion mode not peak/hold. Clint
Maint: Castrol 10W40 / Mitsu Filter / Rislone Replaced: 2X clutch / 3X brakes / 2X front rotors / 2X ABS HU / 1X NGK Plugs / 1X Ball joints / 2X Antenna mast / 1X Active exhaust cable / 1X Windshield / 1X Fuel FIlter / 1X Struts / 1X rear rotors / 1X Front Head / VSS / 1X rear wheel bearings / 1X Transfer case (warranty) / 1x Tie rod end (drivers side) Overhauled: Starter, IAC, BISS, CV Boots Upgrade: SilverStar Headlights / ebay "Xenon" Fog Bulbs (no more yellow!) A/F Gauge / MAP - Electronic Boost Logging / MMCd Data Logger Pending Projects: Steering Rack |
#36 (permalink) | |
Billygoat
Evey time I looked at this thread I cringed at the references to low impedance injectors as peak and hold but it's a very common mistake and didn't seem worth mentioning. |
#37 (permalink) | |
Haven't seen any hard data but my theory is that a Peak/Hold would provide more precise injector timing. Clint |
#38 (permalink) | |
Senior Fanatic
1. The ECU does not put out any "signal" to the fuel injectors. It quite simply grounds a circuit for a prescribed length of time (in milliseconds). For the TT injectors, that circuit happens to include an external resistor, with a total resistance in that circuit of about 9.5 ohms. The NT injectors supply their own extra resistance (no external resistor) for a total resistance in the circuit of about 13.8 ohms. In both cases, resistance in the wiring and connectors has been ignored. The main consequence of this difference in circuit resistance is the amount of current (amps) in each circuit. Bringing us to item 2. 2. Because the amps are higher in the TT circuit, and because the TT injectors are designed to act faster, the ECM decreases the duration of the pulse (that is, the amount of time the current is applied or the circuit is grounded) to compensate for the faster solenoid response. The ECM for NT injectors knows to use a slightly longer pulse duration. This is most evident if monitoring IPW on TT vs NT engines. So, if the ECU is not changed (TT into a NT car after switching to TT injectors) then the ECU will be using a longer IPW than it should. An AFC should be able to compensate for this.
#40 (permalink) |
What have we here
I'm bringing this back up as well:
For an NA staying NA looking to upgrade the injectors, a TT ecu is pointless, correct? And all that is needed in this case is the TT injectors and a resistor pack along with an AFC, right? IPO, you think you might start selling kits for conversions? |
