Old 05-04-2004, 06:30 PM   #21 (permalink)
The Math Man
95red3000gt's Avatar
Drives: 1995 3000GT FWD-TT
95red3000gt is an unknown quantity at this point
Default Re: Saturated to Peak Hold Injector Conversion
ok so how much do you think the TT ecu+ harness will run me?? I just today got all my tt parts in and am ready to start (minus some misc. bolts from the hardware store), but I'm realllllllllllly low on cash right now. I also just found out that I'm not gonna be getting my bonus till july instead of May 19th so now I don't know what the hell I'm gonna do about a clutch. I still have the stocker with 55k on it, so I have no idea whats gonna happen now.
1995 3000GT FWD-TT: Sold
Motor:
3.1L, Forged Crank, Forged Rods, Ross 93mm Forged Pistons, clevite bearings, custom 3 inch exhaust, K&N cone intake, solid motor mounts, IPO MBC, PTE 550cc injectors,
Drivetrain:
ACT Maxx clutch, Nitto555R Drag Radials, Kormex LSD
Electronics:
SAFC II, Autometer EGT/ Boost, LM-1 wideband o2, 95 TT ecu/Harness
95red3000gt is offline   Reply With Quote
Old 05-04-2004, 06:45 PM   #22 (permalink)
Play that Funky Music
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (209)
Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7
Don't really need a harness. The NA an TT ECU plugs/harness are the same. There are only a few pins that change over, like boost control. You can use the NA harness and add the resistor pack to it. This will save you money. Or you can do the whole thing. Either way you need to purchase the resistor pack. Your call.
As for how much? That really depends on the seller. Prices are all over from high to low.
I got a TT ECU, 91 CAS with CAS Bracket, complete 91 TT ECU harness, resistor box, and the TT oil cooler with lines and block attachment for $400 shipped.
AEM Factory Trained Tuner
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T4-995AWHP Uncorrected 6G72 3.0L
91VR4 Red-17Gs w/supporting mods-sold
93SLTT/T2
91VR4 Pearl White-sold
91VR4 Black-sold
92VR4 Sandstone-sold
94VR4 Green-sold
93VR4 Pearl White-currently parting out
91VR4 Black-Currently building "daily Driver"
3SX Performance
3SX Performance Service Email
Old 05-04-2004, 06:55 PM   #23 (permalink)
firebomb757's Avatar
firebomb757 is an unknown quantity at this point
I am not sure i am reading this right so a little clarification would be appreciated. The way i am reading this is that i cant swap out my injectors for larger injectors without doing this modification. Is that correct? Thanx.
Garry Hubbard
firebomb757 is offline   Reply With Quote
Old 05-04-2004, 07:06 PM   #24 (permalink)
The Math Man
you can, but you need some way to control them (ie- SAFC). But with the tt ecu, there is already set fuel maps for the 360 injectors so corrections arn't necessary.
So now am I understanding this correctly? I can just get the TT ecu and plug it into my NA harness. Do I absolutely need to change over the pins? Why would I need to change over a pin for boost control if I'm using a MBC ?? Since I'm a base, are there really any other pins I'll need to change over being that I don't have all the luxury items the tt has??
Old 05-04-2004, 07:14 PM   #25 (permalink)
Garry Hubbard
Without the resistor pack you can not swap in larger low impedance peak hold inj.
Saturated Injectors (NA high impedence) can be used in Peak Hold (TT) systems, but not the other way around. So if you want to use the better (larger) injector you must do this conversion.
Old 05-04-2004, 07:16 PM   #26 (permalink)
The Math Man
ohh ya sorry, forgot to mention you need the resistor pack too...
Old 05-04-2004, 07:18 PM   #27 (permalink)
Jeff's ECU pin assignment pages
Old 05-04-2004, 07:25 PM   #28 (permalink)
Head of Society of Bob
Drives: 1993 Stealth R/T AWD
Trader Rating: (11)
Bob The Great is an unknown quantity at this point
That's great work, IPO. I started trying to do this with my TT conversion, but it looked to be too much work to get the harness to work with the resistor pack, too much custom wiring, and I was pressed for time anyway. I ended up just putting some 5.6Ohm resistors in series with each injector. So far, so good.
With regard to the different ECU pins, check Jeff's page, and also this spreadsheet listing the differences between N/A and TT 1st gen harnesses. --> http://www.stealth316.com/misc/3s_19...3_ecu_pins.xls
I'm using the N/A harness with the TT ECU, and it was not hard to modify the ECU plugs.
Bob The Great has spoken.....
1993 Dodge Stealth R/T Turbo
Currently In Hibernation...
238awhp 265awtq (old dyno on 9b's @ 10psi)
Click to go to my website
Twin Turbo Conversion
All Wheel Drive Conversion All Wheel Steering Conversion
Factory Options
One of 482
Black Leather Interior
Removable Moonroof
5spd Manual
Modifications
3SX Light Crank Pulley
Cold Air Wall and Cone Filter
Snake Eyes
Fidanza Aluminum Flywheel
SBC DXD Clutch
DN Precat Eliminators
ESP Downpipe
Test Pipe
DSM SMIC's
450cc Black Top Injectors
TD04-9B/13G combo @ 10psi on 10:1 CR
Bob The Great is offline   Reply With Quote
Old 05-04-2004, 07:46 PM   #29 (permalink)
Bob, I know what you mean.
I had three things going for me.
1. I worked in the automotive electonics field for 12+ years. I think in WIRING. I used to live and breath it 80+ hours a week.
2. I have my motor and tranny out! Easy access to the entire harness and easy to rip apart and put back together
3. I had a complete TT harness with stock resistor pack. How does this help? I was able to rip apart the NA and the TT harness and see where the TT was tapping off wires that were common in the NA harness. They literally have a section of wire stripped back then take a metal band to crimp together 2-4 wires.
Much easier having what the finished product should be to disect sitting in front of you then to guess or look at schematics. This made it a cake walk. I did refer to the shop manual schematic for the inj circuits to ensure what I was seeing in the harnesses was really what was going on.
Simply put both NA and TT ECUs put out the same inj signal. On the NA it just goes directly to the Inj. On the TT that signal just gets put thru the resistor pack first then to the inj.
Where my install got a little fancy is I stole some male/female connectors from teh 91 donor harness to add the new wires needed for the injectors. The NA has a 4 wire setup for the rear set as there are 3 firing wires and one common. The TT has 6 independant wires so I was short two wires. I left the existing 3 independant wires alone, used teh shared as #1 new independant and added the new two wire plug as #2 and #3
Here is the new 6 wire setup and the other side of the plug is wired into the harness in the car. Notice the middle plug has a new 2 wire plug above it.
Old 05-04-2004, 09:43 PM   #30 (permalink)
Trader Rating: (11)
yeah, having the engine out and having the time to pull both harnesses apart would probably have helped
