#11 (permalink) |
The Math Man
hey man again thanks so much for doin this for us. If you get a chance, I know I at least would greatly appreciate a brief writeup (and I'm pretty sure the rest of the community would appreciate it too
1995 3000GT FWD-TT: Sold
![]() Motor: 3.1L, Forged Crank, Forged Rods, Ross 93mm Forged Pistons, clevite bearings, custom 3 inch exhaust, K&N cone intake, solid motor mounts, IPO MBC, PTE 550cc injectors, Drivetrain: ACT Maxx clutch, Nitto555R Drag Radials, Kormex LSD Electronics: SAFC II, Autometer EGT/ Boost, LM-1 wideband o2, 95 TT ecu/Harness |
#12 (permalink) |
Play that Funky Music
OK, here is the new photo album, got that fixed. What I may do is write a caption under each pic to describe what is going on. They are in cronological order.
http://importpoweronline.com/ipw-web...y/resistorpack
AEM Factory Trained Tuner
T4 AWD 9.21 @ 154.98 T2 FWD 10.19 @ 140.31 T4-159.23 MPH Ran on 6G72 3.1L! T4-995AWHP Uncorrected 6G72 3.0L 91VR4 Red-17Gs w/supporting mods-sold 93SLTT/T2 91VR4 Pearl White-sold 91VR4 Black-sold 92VR4 Sandstone-sold 94VR4 Green-sold 93VR4 Pearl White-currently parting out 91VR4 Black-Currently building "daily Driver" 3SX Performance 3SX Performance Service Email |
#14 (permalink) | |
Nope. I got the resistor pack from RussianVR4's part out along with bunches of other things for the SL-T lie the whole ECU Harness, a CAS, Oil cooler with lines and block attachment. |
#15 (permalink) | ||
Foolish
In the time it took you to do that you could have already replaced the entire NA harness with the TT harness. Then all you would have needed to do is plug in the resistor box. If you were not running a stand alone running the TT ECU stops you from needing a huge correction from a piggy back to get the fuel right. I can run 450cc with about -10% correction. I don't think you can get enough correction out of a NA ECU to run anything larger then 360's. I know this doesn't apply to you because you are going with a stand alone but I don't see why the average Joe would want to run the NA ECU when the TT ECU has been proven to give you 50 H.P. increase by just plugging it in. J.B. saw a 50h.p. increase from the NA ECU to the TT ECU and was able to retune w/o large corrections. Timming advance just blows and when you are running your SAFC at -50% then what would you expect.
Mike Sullivan 95 Stealth FWD TT conversion 10:1 compression@12 PSI
All aftermarket parts happily purchased from 3SX performance.com Turbo conversion parts happily purchased from Mitsuspecialties. |
#16 (permalink) |
Foolish
#18 (permalink) | |
Foolish
Plus why would J.B. make the jump if the dyno didn't give any proof. |
#19 (permalink) | |
Also, it is easier to get a hold of the resistor pack then an entire harness with the resistor pack. It is also cheaper. So for those looking to save where they can I don't see the problem in doing it this way. And as mike stated, there is proven power, 40-50HP just in the ecu swap. This is due to correct fuel maps, timing maps, and the way it handles boost. It should not be a consideration, it should be a given. Swap that puppy out. Now for Autos it gets more sticky. |
#20 (permalink) |
Foolish
The Auto have to run the NA ECU unless there is a way to find out exactly what the ECU controls on the NA ECU and convert it to to a TT ECU. I wonder how hard it would be to run two harness and two ECU's Use the TT ECU for controlling the motor and run the like or same signals split off to the "dummy" NA ECU which is only going to take info in and the info out will only go to the ATX computer. All of the true info in would be comming in from the same sensors that are feeding the TT ECU but you would need a way for the info out to look as if it were being processed. You wouldn't need any of the NA ECU harness out signal wires from the ECU to the sensors only the in signl wire back to the NA ECU. Maybe it would look like it is being processed even though it isn't going anywhere because the NA ECU would still be processing info from the car running off of the TT ECU. The only info going out from the NA ECU would be to the ATX computer. This would basically turn the NA ECU and ATX ECU into a piggyback system. Its probably just a few simple circuits that could be put in a nice blinking box and sold to the public for the magical sum of $399.
