Old 04-10-2004, 06:55 PM   #1 (permalink)
Play that Funky Music
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (209)
Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7
Default Saturated to Peak Hold Injector Conversion
As many know, and some may not, NAs have what 80%+ cars have which is Saturated high resistance injectors. TTs come with Peak Hold low resistance injectors as do amny turbo cars.
Saturated Injectors are lower performance. You will get faster more accurate Fuel injection using Peak Hold injectors. So when doing a TT or Single T conversion you should change the system over to Low impedence Peak Hold.
Don't know how many have done this or if any threads/FAQs have been done but I started mine blindly tonight taking pictures and all. I will have a good write up with pics tomorrow. Once I dug through everything and consulted the shop manual a few times for wiring schematics it was pretty simple.
You will need a TT resistor box. It helps if you have the harness with some lenght on it also but you can always just extend the wires.
I also converted the 4 wire on one plug rear injector harness to a full 6 wire by chopping off a male and female plug with some wire lenght from a donor harness. This way the rear will have 6 independant wires just like the fronts. And I wired the 4 wire stock NA plug to two injectors and the added 2 wire plug to the last injector. This will also give me the Plug in option instead of a hard wired sytem. It will be more stock like.
And remember:
Saturated Injectors can be used in Peak Hold systems, but not the other way around. So if you want to use the better injector you must do this conversion.
AEM Factory Trained Tuner
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T4-995AWHP Uncorrected 6G72 3.0L
91VR4 Red-17Gs w/supporting mods-sold
93SLTT/T2
91VR4 Pearl White-sold
91VR4 Black-sold
92VR4 Sandstone-sold
94VR4 Green-sold
93VR4 Pearl White-currently parting out
91VR4 Black-Currently building "daily Driver"
3SX Performance
3SX Performance Service Email
Import Power is online now   Reply With Quote
Old 04-11-2004, 09:53 AM   #2 (permalink)
Default Re: Saturated to Peak Hold Injector Conversion
Not one response?
I am done the conversion and have many pics. I will post them in a sec. I did it the hard way so that it would look stock. You can probably take shortcuts and make it a little easier.
Old 04-11-2004, 10:15 AM   #3 (permalink)
Hitokiri Battousai
Jeremy C's Avatar
Drives: A car that runs
Trader Rating: (47)
Jeremy C is an unknown quantity at this point
Why respond when I'm just waiting for the writeup? Punkasscrab had done something similar, but instead of wiring in the stock resistor pack he wired separate resistors into each injectors wire loom.
Jeremy C is offline   Reply With Quote
Old 04-11-2004, 10:28 AM   #4 (permalink)
That would work also
Working on getting the pics up.
Old 04-11-2004, 10:51 AM   #5 (permalink)
I will get around to adding text-info to each picture later. It's lunch time.
http://importpoweronline.com/ipw-web...y/resistorpack
Click on slideshow and it will walk thru all 37 pics in order.
Old 04-29-2004, 09:23 PM   #6 (permalink)
The Math Man
95red3000gt's Avatar
Drives: 1995 3000GT FWD-TT
95red3000gt is an unknown quantity at this point
so are you almost done with the writup?? And just to clarify to make sure I'm understanding this right, this is wiring a TT resistor pack into the N/A harness which is using a N/A ecu?? If so then you truely are god lol.
1995 3000GT FWD-TT: Sold
Motor:
3.1L, Forged Crank, Forged Rods, Ross 93mm Forged Pistons, clevite bearings, custom 3 inch exhaust, K&N cone intake, solid motor mounts, IPO MBC, PTE 550cc injectors,
Drivetrain:
ACT Maxx clutch, Nitto555R Drag Radials, Kormex LSD
Electronics:
SAFC II, Autometer EGT/ Boost, LM-1 wideband o2, 95 TT ecu/Harness
95red3000gt is offline   Reply With Quote
Old 04-30-2004, 05:12 AM   #7 (permalink)
Yes and no. This is wiring a TT Resistor pack into an NA harness yes. And yes you can then use an NA use with NA harness and have the Resistor pack wired in like stock.
Only no part is that I am not using an NA ECU. You can just plug in a TT ECU as the wires are the same. I am using a LINK Plus Standalone though.
Never did the write up cause it realy seems no one is interested in it. The thread just kinda died so I didn't want to waste time that I don't have to make a write up that no one cared about.
Old 04-30-2004, 06:34 AM   #8 (permalink)
driven
-bluej's Avatar
Drives: 92 ES
-bluej is an unknown quantity at this point
WE CARE!!!!!
we were just waiting for the writeup to be finished before talking about it...
-bluej is offline   Reply With Quote
Old 04-30-2004, 09:22 AM   #9 (permalink)
The Math Man
so is there a way to use a NA ecu then with the NA wiring harness and still do the Resistor pack in it? Man I really care about this thread. I was estadic (sp??) when I found it cause I've been looking into different ways to do this and finally concluded that I should just solder individual 2W 6ohm ceramic resistors in there, but if there a way to avoid that using OEM mitsu equipment then I'd rather go for that. Trust me there is a big need for that write up. About 3 months ago there was a huge debate on the boards on whether it could be done period and pretty much everyone said it couldn't. You've pretty much proved everyone wrong which I feel has helped better the FWD TT community a ton. It's only been lately that this community has started to really break ground and we need all the help and input that people can give if we are going to continue to break even more ground. I know I for one was really excited when I heard that you were switching over to the FWD crowd and going to do a FWD T car. It's people and like you that are willing to take the initiative that are gonna end up bettering this platform and people like me who are VERY interested in your work that will impliment the new ideas and other things. Ok well I'm done ranting now. I'm gonna go water my bambo stick.
-Gary
BTW- PLEASE DO THE WRITEUP!!!!
Old 04-30-2004, 09:27 AM   #10 (permalink)
Yes, The way I did it in the SL-T is using the stock NA harness and the TT Injector pack. Now I did have the car side plug on the TT Ressitor pack with some legnth which is whoat helped big time in wiring it in. It can totaly be done using an NA ecu and harness with TT Injectors or any low impendence Peak Hold size injector.
