Hey guys quick question, I was looking around for a cold are intake and I read this post and how the ones off of ebay are ok to buy. Has anyone bought one of them? Do they just bolt right in or whats the deal?
How much louder are the after market exhaust than the stock? I know usually on a na car it tends to be much louder than a turbo? On my 300zx na with hks cat back it is crazy loud inside the car. I just dont want my 3s like the z. Which in my view the 3s is a much better car!!!
I would say that adding headers and a high flow cat is not any louder than stock. It just changes to the tone. It is amazingly quiet. I have a 24VDOHC non turbo.
Don't know. I bought my cold air intake from 3SX Performance.
you need to keep a high flow cat or resonators to get rid of the ricey backpopping sound
PERFORMANCE:RiPP Headers,Maximal Catback,MSD(6AL Box,Blaster Coil,Wires),3SX Pulley,DOHC TBw/plenum port & coolant bypass,K&N filter w/HomeDepot pipe, Supermac coldair box, Topline GroundWires, Ek2 Plenum Spacer
WEIGHT LOSS:Removed (AC,SRS,crash bars,rearseat,tar, GasTank Shield,extra wires).MOMO street racer gt seats,Hawker 12lb.battery. Hollowed trunk/trunklid,replaced random unseen bolts w/zipties, solid motormounts,CF Evo hood, Took a big dump -->
SUSPENSION:Ground Control, New KYB's, Front/Rear Strut bars, Dohc rear Anti-sway bar, Irotors brake upgrade kit
ive just purchsed my 91 sl. its in pretty low condition right now, but ive started the replacements needed before the mods. i put new spark plugs and spark plug cables on and my fuel filter is brand new. i had to get a new clutch and clutch line, so im tight on money. my timing belt seems to be working on key, but id still like to replace it. the timing belt and water pump and tensioner for the timing belt is replaced for around $900 at the local shop, but im trying to find estimates for lower prices. any suggestions?
im wanting to know if the performance parts from ebay are worth buying? i found the sway bars and strut bars for alot less money than 3sx. If anyone has went with this setup let me know how it worked out. thanks
ebay intake will work fine and it saves alot of money and does the same thing. I dont see why the strut bars wouldnt work as long as they line up right...
found on the first page...
INTAKE: This modification is good for about 1hp to the ground, BUT it helps with other mods. The most cost effective method is to get one off Ebay, Do not pay 180 bucks like many others do for the K&N FIPK. On Ebay, you can get them for about 40 dollars. It is the same thing, and none too critical to performance. Also, do not pay $200 for the nice shiny arm that some companies put out. Plenty of Ebay sellers have the SAME thing for under $50 shipped, a lot of times they come with a filter too.
93 3000gt sandstone 5 speed SOLD
92 blue stealth tt SOLD
96 celica gt DD
92 pearl white stealth tt *for sale*
92 silver vr4 parting out
91 black vr4 (track car)
92 sandstone vr4 dr-500's
I know I'm a noob here and probably don't have much say. But how about adding those '99 lifters to the list. If youre going to be pushing more power and holding higher revs you might want lifters that actually flow oil =). And how about rasing the compression ratio a bit. maybe using a Thinner headgasket or shaving the head down.
