#371 (permalink) |
will work for turbo
I'm planning on getting a Nitrous kit but not sure which one I should get. Should I get wet or dry? I don't know the difference. Also, with the mods done to my car currently listed in my sig, is it safe to run nitrous? Don't wanna blow anything up.
K&N FIPK|3SX front & rear polyeurathane motor mounts|3SX downpipe|Maximal Performance testpipe|Unorthodox under drive pulley|HKS dual SS exhaust|NGK platinum spark plugs|NGK spark plug wires|Maximal Performance wire kit|ACT stage 2 semi-racing clutch|Tein Flex complete coilovers|3SX front tower bar|Cusco rear tower bar|custom rear sway bar|18x9.5 Bronze 5zigen FN01C-R|265/35/18 Toyo Proxes R888 semi-slick tires|Bomex front lip spoiler|GTO MR Titanium shift knob|custom short throw shifter|Razo pedals| Momo Tuner steering wheel|Corbeau CR1 racing seats|Corbeau 4pt racing harness|Stoptech 4-piston 328x28 Big Brake Kit|Deftracing 575 Carbon Fiber hood|Koyo radiator|
#373 (permalink) | |
Import Chop House
sounds like you have one hell of a car!
As of 1/28/08 I am 3S-less
www.nissanztrader.com LIVE NOW. TELL YOUR Z FRIENDS! '03 Nissan 350Z Track Edition Super Black Brembos-LSD-Nav-M6 [K&N Drop in][Radiator Cooling Plate][TopSpeed Pullies] [Grounding Kit][PowerLab 3/8"][TopSpeed TP] 13.86 @ 101.3 (without pullies) Ran at NYIRP Former Cars: All Dearly Missed. 2005 Nissan Altima SE-R Black 1993 3000GT Base Red 5spd 1992 Dodge Stealth ES Black 5Spd 1994 Dodge Stealth RT/TT Pearl Yellow 473 AWHP 6spd 1994 3000GT SL Danube Blue 5spd 1993 3000GT Base Green 14.0@101 5spd Nitrous+ Take a look at Fquick, its Myspace for your car! |
#375 (permalink) |
I just read the na upgrade bible and it says the first gen brakes will fit on my na stock 16inch rims. but i think the 1st gen vr4 im getting the brakes from has aftermarket drilled/slotted rotors. will they still fit? or am i going to need bigger rims?
edit* or is it ok as long as its 1st gen calipers? and is 250 a good price for all four?
94 base (stick)
ride or die |
#376 (permalink) |
Damn It!
if u can afford direct port get it.
96 3000GT FWD TT -Rebuilt 2 bolt 8:1 block, balanced stock internals, valve job, 99 Lifters, Maximal Performance Motor mounts and valve cover!! Quaife LSD, ACT Max Extreme 6 puck, RPS flywheel, Greddy emanage Ultimate, custom fuel system i designed my self, profec B spec2, walbro 255lph, stock turbos, Braided steel upper and lower radiator hoses, KNN FPIK, FMIC, FM oil cooler, cusco Oil catch can, stillen DP, IPS 3" single, Full AC delete, stripped interior, Corbeau Forza 2 seat, 2 inch harness, ALL Greddy electronic gauges, brakes: 4 piston calipers from Yogurts TT, Hawk pads, Valvoline DOT 4, Russells steel lines
![]() Coming soon: Tranny number 3 ![]() Special thanks: IPS, Maximal Performance, 3SX, Evans Performance and all 3si and FL3s members that sold me parts |
#377 (permalink) |
ok, there hasnt been a post here for a while but i dont really have time to read 38 pages of posts (though id like to), im wondering if on the atx if a 50 or 75 shot of nos (probably dry) wouldnt end it disaster? mods so far are 3sx downpipe, maximal performance test pipe, borla cat-back exhaust, k/n intake, lightweight (not the underdrive) crank pulley, groundwire kit, tt fuel pump. any help would be very appreciated.
oh and btw i know i should search but again no time, very sorry but true i may also just be worrying too much but ive already spun a bearing and swaped the engine and dont wanna have to do it again.Thanks |
#379 (permalink) |
Phewwww. 38 pages later....thought it'd never end. really enjoyed it though. There's a ton of valuable info and discussion here, and many years later, here I am reading it. Great job Yogurt! I will live by the first page.
Rock on NA's. |
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f58/n-upgrade-bible-85924/
| Posted By | For | Type | Date | |
| More power? | This thread | Refback | 04-14-2008 09:07 AM | |
| FAQ..read Before Asking! - Automotive Forums .com Car Chat | This thread | Refback | 04-09-2008 11:00 AM | |
| Thread Tools | |
