LinkBack (2) Thread Tools
Old 03-17-2005, 12:10 AM   #291 (permalink)
100% MEAT
Ellery Clinton's Avatar
Drives: 3000GT NA
Trader Rating: (24)
Ellery Clinton is an unknown quantity at this point
Default Re: N/A UPGRADE BIBLE.
sounds great... I'd be nice to have plenum & throtle body boring there. Also, you speak of fuel and air, but what about spark? Iridium plugs, 8mm wires, and (if you wanna go all out) and Amp.
fyi, you're claimed that the plenum spacer will give 5hp
2003 C32 AMG
1995 3000GT - sold 12/14/06
Ellery Clinton is offline   Reply With Quote
Old 03-17-2005, 12:12 PM   #292 (permalink)
Import Chop House
YOGURT!'s Avatar
Drives: '03 350Z Track
Trader Rating: (51)
YOGURT! Level 2YOGURT! Level 2YOGURT! Level 2
i dont put anything for ignition because IMO were not gaining anything from spark plugs and wires, thats more ricer territory than anything. IMO, the stock wires are just fine, and every other option is just a waste of money. untill i see dyno numbers on a properly tuned n/a with NGK plats, vs. NGK irridium that dictate a gain, i wont ever be on that boat.
As of 1/28/08 I am 3S-less
'03 Nissan 350Z Track Edition
Super Black Brembos-LSD-Nav-M6
[K&N Drop in][Radiator Cooling Plate][TopSpeed Pullies]
[Grounding Kit][PowerLab 3/8"][TopSpeed TP]
13.86 @ 101.3 (without pullies) Ran at NYIRP
1995 Eagle Talon TSI AWD
White 5spd.
[FMIC][Turboback][intake][BlitzDD][Walbro]
Former Cars: All Dearly Missed.
2005 Nissan Altima SE-R Black
1993 3000GT Base Red 5spd
1992 Dodge Stealth ES Black 5Spd
1994 Dodge Stealth RT/TT Pearl Yellow 473 AWHP 6spd
1994 3000GT SL Danube Blue 5spd
1993 3000GT Base Green 14.0@101 5spd
Nitrous+
FQuick.com
Take a look at Fquick, its Myspace for your car!
YOGURT! is offline   Reply With Quote
Old 03-27-2005, 10:54 AM   #293 (permalink)
Keith_from_GpTx's Avatar
Drives: 1999 3000gt WRECKED
Trader Rating: (6)
Keith_from_GpTx is an unknown quantity at this point
whats about upgrading the TB? or porting the TB, maybe even doing it to theintake manifold? what do better ignition wires do? or best spark plugs.? i know there r threads about this but i think its time to add those to the list
Keith_from_GpTx is offline   Reply With Quote
Old 03-27-2005, 12:27 PM   #294 (permalink)
puffin04's Avatar
Drives: 1994 Black 3000GT SL
Trader Rating: (8)
puffin04 is an unknown quantity at this point
I have been searching for this for sometime in the thread but could not really find. I just removed my air compressor and all the holes in the engine bay. The reason why i did this is because my evaporator core was damaged in the wreak and thoughs stupid Mexicans in El Paso wanted the same price for a new one that was used out of a wreaked car. Sorry I am in am not raciest but was pretty mad because I am white and they where trying to take advantage of me. But anyways what I did was remove all of that stuff which was quite easy. The hard part was finding the right belt to put in it. The belt that I finally ended up with was 41 and a half inches and the width of the belt is the same on the car. Basically it is the same way and you tighten up on the tensioner until you get about what ½ dip in it. It fired it up and everything worked as plan and the belt stayed on and everything. I did notice the pick up on the car with the quick acceleration and also the horsepower as well. Now I could not tell you how much of a gain this is because I do not have a dyno and no one around in BFE has one either. I am just saying it can be done and done fast with little time. I am planning on talking more out in the interior for more weight purposes. But the only reason I listed this is because I looked for thread that would have it but could not find it when I was in need. If you have any questions or need more information please PM me. Thanks
Steffen Sparks
puffin04 is offline   Reply With Quote
Old 03-27-2005, 04:13 PM   #295 (permalink)
Import Chop House
YOGURT!'s Avatar
Trader Rating: (51)
so what youre saying is you took the AC compressor out? im just making sure thats what you were talking about. sounds like a good modification! thanks for the tip.
Old 03-27-2005, 05:22 PM   #296 (permalink)
Trader Rating: (6)
lol, wait reduction mod and HP gain, good one. i forgot that i did that too, and i also used to do it to may camarows. wial your at it, who needs power sterring anyway??? not me... any one dynos this?
Old 03-27-2005, 05:51 PM   #297 (permalink)
100% MEAT
Drives: 3000GT NA
Trader Rating: (24)
you guys are kidding, right? Yogurt maybe you should lock this thread and point everyone here How much power can we get from NAs?.
Old 03-27-2005, 10:31 PM   #298 (permalink)
puffin04's Avatar
Trader Rating: (8)
Yeah i took out the compressor and i figure well hell since i am doing that might as well take the hoses out for more space and less weight as well and i took out the condensor as well. I dont think you can take out your steering pump because it is pretty hard to drive it without it if you have ever had your car turned off in a turn you will know but hey if you can i would recommend. lol... Well who in the hell need air condition anyways. And now one can BS me because io live in BFE in New Mexico and i manage and i am the whitess fucker ever. LOL... But again i dont know the hoursepower gains or anything like that. All i know is how to do it and it has worked perfectly for me over a few hundred miles. And to make it sound worse i am running on one fan because the other got destoryed in the accident. But taking out the condesser has helped with cooling and plus i have taken a lot of safty equipment in the front of the car and i have the erector set material thing holding my radator in place as well. I will send you all pictures it looks kind of mean. And please dont lock this thread because it is everybodys ideas not just one individual.
Steffen Sparks
Old 03-28-2005, 04:22 PM   #299 (permalink)
Gas Cyphoner
SUPERTOM's Avatar
Drives: 95 BASE SOHC Stealth
SUPERTOM is an unknown quantity at this point
ive done almost all the weight reduction mods but I cant seem to part with the AC. I have this battle with myself everyday. Man its so hard
PERFORMANCE:RiPP Headers,Maximal Catback,MSD (6AL Box, Blaster Coil, Wires),3SX Pulley,DOHC TBw/plenum port & coolant bypass,K&N filter w/HomeDepot Performance pipe & Supermac coldair wall, Topline GroundWires, Ek2 Plenum Spacer
WEIGHT LOSS:Removed (AC,SRS,crash bars,rearseat,tar, GasTank Shield,extra wires). Race seats,Hawker 12lb.battery. Hollowed trunk/trunklid,replaced random unseen bolts w/zipties, solid motormounts,CF Evo hood, Took a big dump -->
SUSPENSION:Ground Control, New KYB's, Front/Rear Strut bars, Dohc rear Anti-sway bar, Irotors brake upgrade
SUPERTOM is offline   Reply With Quote
Old 03-28-2005, 05:02 PM   #300 (permalink)
puffin04's Avatar
Trader Rating: (8)
Well you are going to have to sacrife luxery for more power and less weight. Or like some of the people on here that complain about weight maybe you should go on a diet i mean i lost 15 pounds this semester and i am 169 right now. LOL
Steffen Sparks
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f58/n-upgrade-bible-85924/
Posted By For Type Date
More power? This thread Refback 04-14-2008 10:07 AM
FAQ..read Before Asking! - Automotive Forums .com Car Chat This thread Refback 04-09-2008 12:00 PM
