LinkBack (2) Thread Tools
Old 01-29-2004, 08:43 PM   #231 (permalink)
will work for turbo
ewang9394's Avatar
Drives: 1996 DOHC NA 5spd
ewang9394 is an unknown quantity at this point
Default Re: N/A UPGRADE BIBLE. wish i had this when i was a NOOB.
Originally Posted by
Underdrive pulleys do just what the name says, they underdrive the alternator. the alternator doesn't turn as fast, so it doesn't generate as much power for a small hp gain. This is why your lights dim, they aren't getting as much power... Your lights should only dim at idle, however.
The problem is that they shorten the life of your engine, despite what uneducated enthusiasts say... if you don't believe me, read this:
http://dinancars.com/html/danger_of_power_pulleys.htm
Nuff said
Yes, my lights (especially head lights) are kinda dim during idle. Once I rev, the light goes back to normal. So I guess the pulley is harmful to the engine in the long run. But does it produce power in anyway??? I asked my mechanic and he said that it really does nothing in terms of power to the car. Any comments? I'm not familiar with the udp because it was intalled when I got the car.
Thanks,
Ed
K&N FIPK|3SX front & rear polyeurathane motor mounts|3SX downpipe|Maximal Performance testpipe|Unorthodox under drive pulley|HKS dual SS exhaust|NGK platinum spark plugs|NGK spark plug wires|Maximal Performance wire kit|ACT stage 2 semi-racing clutch|Tein Flex complete coilovers|3SX front tower bar|Cusco rear tower bar|custom rear sway bar|18x9.5 Bronze 5zigen FN01C-R|265/35/18 Toyo Proxes R888 semi-slick tires|Bomex front lip spoiler|GTO MR Titanium shift knob|custom short throw shifter|Razo pedals| Momo Tuner steering wheel|Corbeau CR1 racing seats|Corbeau 4pt racing harness|Stoptech 4-piston 328x28 Big Brake Kit|Deftracing 575 Carbon Fiber hood|Koyo radiator|
ewang9394 is offline   Reply With Quote
Old 01-29-2004, 08:53 PM   #232 (permalink)
<T>
What have we here
<T>'s Avatar
Drives: a cash vacuum
<T> is an unknown quantity at this point
Thanks,
Ed
The 10-20hp claims are complete 100% bullshit-smoke-up-your-ass. 5-8hp if you're lucky! If you want such a little upgrade save yourself the cash and buy a good air filter...
I personally ran without a crank pulley (the ULTIMATE underdrive pulley) just for fun to see if there was any difference, and it was minimal at best... my butt would say about 5hp at most, honestly. It's as much a bullshit upgrade as plenum spacers or throttle body spacers... just a gimmick.
Bottom line, it isn't worth the risk for the small amount of hp you get... honestly I would say if you have a good amount of miles on the car I would look into getting a stock replacement crank pulley, but that's just me. Just know it is the equivalent of smoking cigarrettes... it aint gonna do harm right away, but over time it sure as hell will.
Hey if you'll buy a UDP or spacer, maybe you'll be interested in this!:
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=2980180592
On slight hiatus again, bad timing...
<T> is offline   Reply With Quote
Old 01-30-2004, 05:51 PM   #233 (permalink)
NewBie Modder
t_do's Avatar
t_do is an unknown quantity at this point
//austin power voice// why wont this thread die!
1994 pearl white base 3000GT
YOGURT's dual dragger exhaust, YOGURT's testpipe, 3KGTmotorsports short shifter, KN FIPK, 18x8 Eagle 077's w. kumho supra 712's, bomex front end, custom interior, blue engine bay, kenwood 6x9's,kenwood 5.25" 's, kenwood kdc-x819 receiver
1997 black talon TSI FWD:
EVO III B16G, walbro 190 pump, proboostMBC.com [boostedzx] @ 14psi, injen intake, 2.5" AGP o2 housing,2.5" downpipe w. testpipe, RNR 3" catback w. n1 muffler, free mods, UICP, LICP, symborski shift kit with cut shifter, really fuggin heavy clutch, cross drilled rotors, strut bar, 3 pc. arc spoiler, 17" gunmetal exel mimi's w. proxe fz4's, apexi boost gauge, apexi turbo timer
next up : 660's , SAFC II, FMIC... hello 20 psi
t_do is offline   Reply With Quote
Old 01-30-2004, 08:31 PM   #234 (permalink)
og
chansigril's Avatar
Drives: 93 stealth rt tt
Trader Rating: (48)
chansigril Level 7chansigril Level 7chansigril Level 7chansigril Level 7chansigril Level 7chansigril Level 7chansigril Level 7chansigril Level 7chansigril Level 7chansigril Level 7chansigril Level 7
i have an underdrive pulley (udp) currently installed, and have had it on my vehicle for the past 50k+ miles. i have *no* problems with my car, my crank, my belts or my electrical systems. the lights do dim at idle. i have no oil leaks. it does provide a boost in power. no one i know personally has had an issue with their udp... and that is a good many people, including contacts with tuner shops. for some real-life information about underdrive pulleys on our cars, visit this thread.
i want the tin foil hat too! it will protect me from fbi.com
- mike
93 stealth r/t tt: mildly modified, 12.4@109
94 stealth r/t na: used to drive, 13.9@100
93 dodge stealth r/t tt: personal parts car
03 ford focus se: beater
chansigril is offline   Reply With Quote
Old 01-30-2004, 09:36 PM   #235 (permalink)
<T>
What have we here
<T>'s Avatar
- mike
Umm... the entire source for that site is:
In other words it's blank... is that part of the joke?
Old 01-30-2004, 10:51 PM   #236 (permalink)
og
chansigril's Avatar
Trader Rating: (48)
if you check the ebay item it specifically lists that site as an entity which the hat will protect you from. i wanna know how T found that site but i digress... let's keep this a noob bible, meaningful discussion and all
- mike
Old 01-31-2004, 08:56 PM   #237 (permalink)
<T>
What have we here
<T>'s Avatar
How'd I find the eBay item? It was in a forwarded email, but it has been featured on a bunch of "Who Would Buy That?" type sites... and there are a million sites like that out there too...
I do say that is genius though, check out his other items... he's selling I think a pizza crust in a peanut butter jar as one of his items lol
- mike
If it wasn't for us, this thread would be dead already, so I think no one will care if we poke the carcass
Old 02-05-2004, 10:49 AM   #238 (permalink)
TPW Educator
LVA3KGT's Avatar
Drives: with EDFC at 0/0
LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7
UDP are, in theory, bad for the life of your motor.
However... I have 178K miles on my motor. 118K of those are w/ the UDP. So far, so good. Gains are slight at best, and truth be told, I wouldn't waste the money on it again.
If anything, My K&N filter is what is bad for my car. Ever since I've had it, I've noticed my oil gets dirtier faster. I used to change it ~6K miles (mobile 1 oil and filter). Now I change it 3-4K miles. Now, I haven't taken the oil to be analized; it just looks black much faster than it used to... of course, I do have 178K miles on my motor...what do you expect? lol
97 SLtt
World's fastest fwdTT 97SL in Phoenix
410 Ft/lbs of torque-steer and 390HP to the front wheels, making 1-3 gear useless @17psi. Built and tuned by 3SX
(Firebird) = Best 60ft 2.4 Best ET 13.8 , best trap 110.8MPH , picked up almost 30mph on the big end of the track.
3SI member # 5422
LVA3KGT is offline   Reply With Quote
Old 07-22-2004, 12:21 AM   #239 (permalink)
Import Chop House
YOGURT!'s Avatar
Drives: '03 350Z Track
Trader Rating: (51)
YOGURT! Level 2YOGURT! Level 2YOGURT! Level 2
hey fellas, whats up.... GOD, this thread is like 3 years old, and has gotten over 15k views...... lol thats great! anyway. someone should go ahead and update this thing and clean it up a bit so they can make it a sticky........
glad to see im still helpin people out!
hey i disagree man, the UDP's are a good mod, its simple physics, less rotating mass=higher potential velocity? right? anyone who says the underdrive pulleys are going to break or potentially break your engine are full of it. if you have a 1200 hp motor then yes, the slight vibrations would magnify into bad things over TIME..... not in a car that puts 156 hp to the ground tho man... come on. common sense.
anyway. its cool to see this thread is up and around. lol good luck guys, i think im comin back to 3si, this time incarnated in TWIN TURBO form. the Z is too much of a problem child.
As of 1/28/08 I am 3S-less
'03 Nissan 350Z Track Edition
Super Black Brembos-LSD-Nav-M6
[K&N Drop in][Radiator Cooling Plate][TopSpeed Pullies]
[Grounding Kit][PowerLab 3/8"][TopSpeed TP]
13.86 @ 101.3 (without pullies) Ran at NYIRP
1995 Eagle Talon TSI AWD
White 5spd.
[FMIC][Turboback][intake][BlitzDD][Walbro]
Former Cars: All Dearly Missed.
2005 Nissan Altima SE-R Black
1993 3000GT Base Red 5spd
1992 Dodge Stealth ES Black 5Spd
1994 Dodge Stealth RT/TT Pearl Yellow 473 AWHP 6spd
1994 3000GT SL Danube Blue 5spd
1993 3000GT Base Green 14.0@101 5spd
Nitrous+
FQuick.com
Take a look at Fquick, its Myspace for your car!
YOGURT! is offline   Reply With Quote
Old 07-22-2004, 12:31 AM   #240 (permalink)
<T>
What have we here
<T>'s Avatar
Man where the hell have you been?! Glad to have ya back
Anyways, the less rotating mass isn't even where most of the benefit comes from, but rather underdriving the components decreasing the load on the engine. The problem is not with either of these two functions (although underdriving your alternator shortens its life) but rather that a VITAL piece of engineering is being removed from the car, the harmonic balancer. Even a 2L 4 cylinder needs a tortional damper.
Besides all the risks, it has been shown on every independant dyno that UDP's are worthless as a power adder anyways, adding 1-3hp on everything from 4 cylinder hondas to 8 cylinder BMW's across the board. (an alternator is going to take just as much power to drive on a V10 as it will on an I4) Never mind the fact that in that same test four out of six BMW's equipped with UDP's needed rebuilt after a full weekend of racing.
http://www.teamscr.com/pulleys.htm
Here you can see they completely removed the accessory pulley and only saw a 3hp gain.
It's funny that if you claim certain horsepower figures over and over how people will just accept them. Just like the amazing Tornado was for a while until people actually took it to the dyno and found out it REDUCED hp because it is a restriction.
anyways, yeah good thread!
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f58/n-upgrade-bible-85924/
Posted By For Type Date
More power? This thread Refback 04-14-2008 10:07 AM
FAQ..read Before Asking! - Automotive Forums .com Car Chat This thread Refback 04-09-2008 12:00 PM
