LinkBack (2) Thread Tools
Old 03-13-2003, 12:47 PM   #201 (permalink)
Tambit24's Avatar
Tambit24 is an unknown quantity at this point
Default
Well, I was hoping to replace it soon. I feel like a dick everytime I'm at a light or just rolling down the street. The gas pedal sticks kinda bad and makes the car jerk all over the place. It's very annoying. You think it might be something else. I don't know much about cars, but thats what my mechanic said it was when I brought it to him.
Tambit24 is offline   Reply With Quote
Old 03-13-2003, 12:52 PM   #202 (permalink)
suffers lead foot syndrom
phat_3kgt's Avatar
Drives: 91 300GT SL
Trader Rating: (13)
phat_3kgt is an unknown quantity at this point
Default
if the actual peddle is sticking it is probably the cable. If you push in on the peddle and let up and it still takes off, it could injectors that are stuck open. The throttle body just lets air in. It doesn't actully fuel the car to my knowledge.
phat_3kgt is offline   Reply With Quote
Old 03-13-2003, 01:26 PM   #203 (permalink)
Tambit24's Avatar
Default
The pedal only sticks when I am trying to push it down. Never stays down on its own. He said its the throttle plate thats sticking or something like that
Old 03-13-2003, 05:09 PM   #204 (permalink)
Tambit24's Avatar
Default powerstack filters
I found this site. Not sure if it's the same exact one you were talking about, but they have them. http://www.intenseperformance.com
Not sure about the adapter though. I haven't check 3sx yet, but I'll give them a try.
Old 03-13-2003, 05:28 PM   #205 (permalink)
linchpinjoe's Avatar
Drives: 99VR4
Trader Rating: (21)
linchpinjoe Level 2linchpinjoe Level 2linchpinjoe Level 2linchpinjoe Level 2
Default
is there any place that u can send your throttle body in to get it polished and bored out?
linchpinjoe is offline   Reply With Quote
Old 03-13-2003, 05:45 PM   #206 (permalink)
Your my boy Blue!
Wolffv's Avatar
Location: Houston is home. Cleveland, Ohio is where I reside now.
Wolffv is an unknown quantity at this point
Default
You can send it to Dynamic Racing for one of their N/A upgrades. Only problem is its the 400 hp upgrade which is the last step. They might take it and do the work anyway.
N/A 400 hp upgrade, call and see about the TB
MODS:
-3.1 liter w/ Arias 11:1 comp. piston
-balanced crank
-Clevite bearings
-ported and polished valves
-NGK spark plugs
-aftermarket plug wires ( NGK SUCK! )
-K&N filter
-Dual Tanabe medalion ( wannabes )
-S-AFC installed and tuned
-Spec stage III clutch
-Fidanza lightend flywheel
-Motor mounts
INTERIOR:
-greaddy shift knob
-3kgt short shifter
Wolffv is offline   Reply With Quote
Old 03-13-2003, 06:07 PM   #207 (permalink)
Tambit24's Avatar
Default
GT-Pro does the boring to for $275. They have cores there for $150 as well.
Old 03-14-2003, 01:34 PM   #208 (permalink)
phat_3kgt's Avatar
Drives: 91 300GT SL
Trader Rating: (13)
Default
That is the site. To get the adapter you will have to call 3sx. They do not carry them on the website except in their kits. Or you can just check on ebay. Make sure you get the 7" cone filter with a 4.5" connecting end.
As for the Throttle Plate I'm assuming he is talking about the small plate on the throttle cable. It is just behind the intake plenium. A small steel braided wire runs through it. You might check it out and see if there is anything wrong, although I don't know exactly what to tell you to look for.
The throttle body bore from Dynamic Racing is apparently cheaper than the one from GT PRO (Not suprisingly) since the cam regrind from DR is $750 and you get 100 hp Nitrous Jets with the stage upgrade all for $1000. So I'd assume just the bore would be $200 to $150.
Old 03-14-2003, 01:55 PM   #209 (permalink)
Tambit24's Avatar
Default
Ya, so you think Dynamic Racing is the way to go. I tried 3SX and they don't do it. GT-Pro was like the only one that did it, but then again I never check out D Racing.
Old 03-14-2003, 02:05 PM   #210 (permalink)
is dominating the race!
Deathsled's Avatar
Drives: some sort of TT
Trader Rating: (21)
Deathsled Level 2Deathsled Level 2Deathsled Level 2Deathsled Level 2Deathsled Level 2
Default
perhaps there's a better place for this discussion than at the end of a 14 page 9 month old thread?
'09 SOUTHEAST DRAG DAY // OCT 11, 2009 // SOUTHEASTDRAGDAY.COM
1991 Stealth RT/TT : 1992 base Stealth : 1996 3000GT VR4
Deathsled is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f58/n-upgrade-bible-85924/
Posted By For Type Date
More power? This thread Refback 04-14-2008 01:07 PM
FAQ..read Before Asking! - Automotive Forums .com Car Chat This thread Refback 04-09-2008 03:00 PM
