LinkBack (2) Thread Tools
Old 07-29-2002, 11:24 AM   #131 (permalink)
hostile is an unknown quantity at this point
Default
ek2 my friend says he can make me a downpipe for the cost of the pipe. The only problem is he doesnt have a mandrel bender just a regular bender.
If we fill the pipes with sand and do it slow, will one of his downpipes still give me a good gain on hp? The stock ones look like they were bent with no attention to making it smooth.
I think it will end up costing less than 50 if we buy a flex section and a section of 2 inch and 2.5.
What do you think?
You were talking about the diffrences in the pipes one having a scavenger and one not having a scavenger what part is this?
hostile is offline   Reply With Quote
Old 07-30-2002, 02:58 PM   #132 (permalink)
Default
TTT
ek2?
Old 07-30-2002, 03:33 PM   #133 (permalink)
Supreme creator of stuff
ek2mfg's Avatar
Trader Rating: (137)
ek2mfg Level 1ek2mfg Level 1
Default sand?
honestly I don't know about that one. good for you for getting it made for 50 bucks though thats good anyhow.
I know some mandrel benders have an insert that goes inside the tube while it bends.......like a series of discs that bend with the tube....I would think sand could hold the form to well but you buddie has the machine so certainly try it.....even of you had 10% deformation it would't hurt MUCH. you could use a nut instead of a bung hole (dont laugh bevis) for the o2 sensor and the flex section could be bought from several sources for about 3540 bucks. The collector is also easy to find.........
I actually delisted myself from this thread to keep the trash out.
I have another mod that will be posted tonight I would guess to say a must for NA's with large injectors...look for it in about 3 hours or so......
"Of all human powers operating on the affairs of mankind, none is greater than that of competition. "
Do you need eK2 Fuel Rail Loops? PM me for details...
ek2mfg is offline   Reply With Quote
Old 07-30-2002, 07:01 PM   #134 (permalink)
Forum user
OMAR JAY JULIO is an unknown quantity at this point
Mitsubishi
do you know where can i get a twin turbo kit of my car its a 96 3000gt 5 speed? how much $$$$ ? . borla,kn ,jet chip ......
OMAR JAY JULIO is offline   Reply With Quote
Old 07-30-2002, 07:27 PM   #135 (permalink)
Default
AAM and dnperformance make the kits.
Dnperformance.com
alteredatomosphere.com
Also save up cahs so you can do it right if not you will end up with a half ass and broken twin turbo car.
Old 08-03-2002, 04:29 AM   #136 (permalink)
Registered User
Matthew3000GTsL is an unknown quantity at this point
Default
curious, if I do everything YOGURT! says before the TT upgrade, will those parts need to be replaced, like the testpipe ect.????
Matthew3000GTsL is offline   Reply With Quote
Old 08-03-2002, 12:21 PM   #137 (permalink)
Mommy says I'm special
Master X's Avatar
Drives: 91 Red VR4
Master X is an unknown quantity at this point
Default S/C
I know it is new, but what about a supercharger? I really wanna put one of these in. Would a supercharger bring out the same hp as the turbo if I upgrade everything in the list before that?
For more info on the carpc go here
Master X is offline   Reply With Quote
Old 08-03-2002, 11:24 PM   #138 (permalink)
og
chansigril's Avatar
Drives: 93 stealth rt tt
chansigril Level 4chansigril Level 4chansigril Level 4chansigril Level 4chansigril Level 4
Default
the list of parts is extensive for the tt comversion. the test pipe is not one of the things you have to replace, however.
you will have to have the fuel pump, as well as the clutch, ummm... afc, i'm sure there are others. most of the parts won't hurt.
hope this helps, safe travels.
- mike
93 stealth r/t tt: mildly modified, 12.4@109
94 stealth r/t na: used to drive, 13.9@100
03 ford focus se: beater
chansigril is offline   Reply With Quote
Old 08-12-2002, 08:15 AM   #139 (permalink)
Staugdogg03's Avatar
Staugdogg03 is an unknown quantity at this point
Default
Would you need to lower the compression if you wanted to add turbos or a supercharger? How well does the Venom 400 thingy work? YOGURT how much are you asking for the pipe that replaces the cat(i forgot your technical name for it)?
Red 1995 3000gt NA
K&N
3SX UDP
Little chevy bow-tie on the bumper...thats what makes it fast
For now thats all i can afford untill my money tree grows.
Staugdogg03 is offline   Reply With Quote
Old 08-12-2002, 08:23 AM   #140 (permalink)
Default
YOGURT what all do you have done to your car?
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f58/n-upgrade-bible-85924/
Posted By For Type Date
More power? This thread Refback 04-14-2008 09:07 AM
FAQ..read Before Asking! - Automotive Forums .com Car Chat This thread Refback 04-09-2008 11:00 AM
