Originally Posted by skunkworks
Wonderful!!! that is exactly what I wanted to hear.
sam
TDC plus strings on valve stems provides the redundancy necessary to keep a single failure from dropping a valve.
I wasted at least 4 hours fooling around with retreiving a dropped valve so I can speak from first-hald experience that it is critical to have piston at TDC when the cylinder is pressurized.
And I wasted another 2-3 hours trying to fix a "problem" with zero compression that would have gone away had I simply waited for the valve lifters to bleed down on their own.
Hindsight 20/20 ...
Clint
Maint: Castrol 10W40 / Mitsu Filter / Rislone
Replaced: 2X clutch / 3X brakes / 2X front rotors / 2X ABS HU / 1X NGK Plugs / 1X Ball joints / 2X Antenna mast / 1X Active exhaust cable / 1X Windshield / 1X Fuel FIlter / 1X Struts / 1X rear rotors / 1X Front Head / VSS / 1X rear wheel bearings / 1X Transfer case (warranty) / 1x Tie rod end (drivers side)
Overhauled: Starter, IAC, BISS, CV Boots
Upgrade: SilverStar Headlights / ebay "Xenon" Fog Bulbs (no more yellow!)
A/F Gauge / MAP - Electronic Boost Logging / MMCd Data Logger
Pending Projects: Steering Rack
