#61 (permalink) | |
no speed limits here
Steve
#62 (permalink) | |
Member: Burned valve club
Clint
Maint: Castrol 10W40 / Mitsu Filter / Rislone Replaced: 2X clutch / 3X brakes / 2X front rotors / 2X ABS HU / 1X NGK Plugs / 1X Ball joints / 2X Antenna mast / 1X Active exhaust cable / 1X Windshield / 1X Fuel FIlter / 1X Struts / 1X rear rotors / 1X Front Head / VSS / 1X rear wheel bearings / 1X Transfer case (warranty) / 1x Tie rod end (drivers side) Overhauled: Starter, IAC, BISS, CV Boots Upgrade: SilverStar Headlights / ebay "Xenon" Fog Bulbs (no more yellow!) A/F Gauge / MAP - Electronic Boost Logging / MMCd Data Logger Pending Projects: Steering Rack |
#63 (permalink) | |
(I think I may have come up with a easy mod for a common tool that will make it much easier to remove the old VSS. I will test this on the front bank tonight before tackling the rear back tomorrow morning.) Clint |
#64 (permalink) | |
No loer a Noob?
That will work good as this weekend I will be looking for my oil leak.
engine oil leak drivers side of bay If I find out I have to take the timing belt off to fix it (cam seals or main etc..) Then I will not need your tool as I can get the cams off at that point. btw - I do puff blue smoke according to my wife. thanks for all your work. sam Quote:
92 Stealth R/T TT - 13t's Installed. note:Is the machining right? - boosting to 15psi so far.
Do I do this for others? No. robbeck is your man.... We know his work . |
#65 (permalink) | |
The driving force behind developing this tool was to decouple the VSS replacement from other maintenance. Pleasantly surprised that replacing VSS is only ~2X the effort of changing the plugs. MAGNETS Found a couple crescent shaped Neodymium magnets that I removed a while ago from a hard drive. At least on a bench, the magnets do a great job of snatching the keepers as soon as the valve stem is raised above the retainer. MUCH lower risk than trying to grab them with needle nose pliers and not drop one into the engine. On the last cylinder I did, I used a pair of needle nose pliers and dabbed the keepers in grease before placing them on the valve stem - It worked OK on the front bank but there was the obvious risk of dropping a keeper. Given my recent suuccess with magnets, I will try using a magnet to install the keepers. Clint Last edited by cbatters : 12-03-2004 at 07:52 AM. |
#66 (permalink) |
No loer a Noob?
any update? Good luck.
May your valve spring retainers fall where they are easy to retrieve. ![]() sam edit - I got a tag in the mail saying that my 3rd gen lifters are at the post office. My valves stem and valve cover seals should be here next week. kind of excited. Last edited by skunkworks : 12-04-2004 at 06:27 PM. |
#67 (permalink) |
BAD NEWS
I dropped an intake valve into the cylinder. (Rubber washer I attached to the top of the valve came off while I was removing one of the springs allowing the vallve to drop into the cylinder. So to answer an earlier question, I now know 100% that it is possible to drop a valve into the cylinder.) GOOD NEWS I was about ready to pull the head when I decided to try fishing the valve out of the cylinder. Short version - I GOT IT!! Easy to do once you perfect the technique.) I'll post the long version in another thread. I am now using a strong nylon string to keep the valve from falling. MORAL TO STORY Worth the extra time to make sure the cylinder is at TDC - Just in case.... Clint |
#68 (permalink) |
BAD NEWS
#69 (permalink) | |
No loer a Noob?
cool - though you fished the the valve back up into the valve guide? Impresive. (was a magnet involved though the vavle guide? - my thought)
sam |
#70 (permalink) | |
TDC - Would have saved several hours of frustration. Thios event is forcing me to re-think the viability of removing/reinstalling the VSS without removing the valve springs (which involves lowering the valves with pressure removed - VERY RISKY!!!) Clint |
| Thread Tools | |
