#51 (permalink) | |
Member: Burned valve club
Maint: Castrol 10W40 / Mitsu Filter / Rislone Replaced: 2X clutch / 3X brakes / 2X front rotors / 2X ABS HU / 1X NGK Plugs / 1X Ball joints / 2X Antenna mast / 1X Active exhaust cable / 1X Windshield / 1X Fuel FIlter / 1X Struts / 1X rear rotors / 1X Front Head / VSS / 1X rear wheel bearings / 1X Transfer case (warranty) / 1x Tie rod end (drivers side) Overhauled: Starter, IAC, BISS, CV Boots Upgrade: SilverStar Headlights / ebay "Xenon" Fog Bulbs (no more yellow!) A/F Gauge / MAP - Electronic Boost Logging / MMCd Data Logger Pending Projects: Steering Rack |
#52 (permalink) |
no speed limits here
I thought you were looking for the Mitsu valve spring compressor. The only thing this tool allows for is to compress the valves with the heads (and engine) installed. Yours will be the first to compress the springs w/o removing the cams.
Steve
#53 (permalink) | |
(Or perhaps I was just dreaming?!) Clint |
#54 (permalink) |
EUREKA - I GOT IT!
One minute to: 1. Attach tool 2. Tighten a little - remove rocker arm 3. Tighten more - remove keepers 4. Loosen to remove tool 5. Remove valve retainer Less than a minute to: 6. Attach o ring to top of valve stem (to keep it from falling into cylinder) 7. Remove pressure from cylinder 8. Lower valve stem 9. Remove spring 10. Pull up valve 11. Re-apply pressure 12. Remove o ring Two minutes to: 13. Remove VSS 14. Lube valve stem 15. Carefully install new VSS And less than 2 minutes to put everything back together again. 5 minutes to replace each VSS without removing the heads or removing the timing belt/camshafts - NOT BAD!! Clint |
#55 (permalink) |
No loer a Noob?
ok - here is the plan.
1 you do your valve stems this weekend. 2 I paypal you a shipping and rental amount 3 I do my valve stems next weekend. Sounds like a plan to me ![]() sam
92 Stealth R/T TT - 13t's Installed. note:Is the machining right? - boosting to 15psi so far.
Do I do this for others? No. robbeck is your man.... We know his work . |
#56 (permalink) | |
#57 (permalink) |
Rebuilding...
I'd like to be next on the list to borrow/rent it.
![]() "Hockey is a sport for white men. Basketball is a sport for black men. Golf is a sport for white men dressed like black pimps." -- Tiger Woods |
#59 (permalink) |
500hp daily driver
cbatters- are you going to make any more of that tool?
I know lots of people could use one.
-Marshall
'91 VR-4 one of 293 Check out My Pics and "The Story of My Car" UPDATED 10/23/2007 with engine rebuild ![]() Engine rebuild: Done! 8/07 Paint: Done! 11/07 Mods: Wiseco +0.055" pistons, DR650R turbos, PTE 550cc injectors, Denso 310lph FP, Aeromotive AFPR w/ custom fuel lines, FP Hotwire, ATR downpipe, ATR catback, HKS SSQV, Apexi SAF-C, Apexi AVC-R, Apexi S-ITC, PST 2pc. CFDS, TEIN S spings, Fidanza flywheel, ACT clutch, Magnecore wires, 3SX control arms, speed bleeders, battery relocation, OZ Superleggera 18x9 wheels, Stewart Warner FP gauge, Scanmaster 3, MMcd, Kormex Tranny & T-case, Corbeau seats, '92 Pearl White VR4 - Dad's ride -mint condition, tein coilovers, racing hart wheels, hks IC's, tenabe exhast 18 spline t-case for sale $225 shipped FIRM. PM me |
#60 (permalink) |
40% improvement in speed:
1. Remove rocker arms, keepers, retainers (x4) (This goes very fast!) 2. Attach washers to valve stems (x4) 3. De-pressurize cylinder and push down valves (x4) 4. Remove valve springs (x4) 5. Pull up valves (x4) and pressurize 6. Remove washers (x4) 7. Remove VSS (x4) 8. Install VSS (x4) 9. Reinstall washers with strings attached (x4) 10. Depressurize and push down valves (x4) 11. Reinstall springs with string through spring (x4) 12. Pull valves up with strings (x4) 13. Pressurize 14 Remove washers (x4) 15. Reinstall retainers, keepers, rocker arms (x4) Replacing VSS in groups of 4 saves ~half the time. Two areas remaining for improvement: 1. Still looking for a more positive/refined way to remove the old VSS 2. Looking to lower the risk of losing a keeper - perhaps a powerful magnet on the tool that presses down on the valve retainer. Time to do a search and find out if someone already has a patent on the tool I just invented. Clint |
