#41 (permalink) | ||
No loer a Noob?
![]() A more elegent way would be nice. something that wraps around the rear of the rocker to pry the back end off of the lash adjusters - then be able to spin it side ways. I have never seen the official tool. sam edit - ooh ooh - how about making your valve spring compressor so it only pushes on the edges of the spring on each side of the rocker. compress the valve spring and then the rocker would fall out. I assume this would have to be done with no cylender pressure so the spring and valve would go down sam
92 Stealth R/T TT - 13t's Installed. note:Is the machining right? - boosting to 15psi so far.
Do I do this for others? No. robbeck is your man.... We know his work .Last edited by skunkworks : 12-01-2004 at 07:49 AM. |
#42 (permalink) | |
Member: Burned valve club
1/2 of the tool already works this way - slides onto the valve retainer from the rear. Thinking about a change in the other half of the tool that would allow it to be used with the rocker arm in place. Workflow... 1. Attach tool 2. Tighten tool to compress spring enought to remove rocker arm 3. Loosen tool to seal valve 4. Pressurize cylinder 5. Tighten tool to compress spring and remove keepers 6. Remove tool to install VSS (reverse process to reassemble) Very fast / efficient... Clint
Maint: Castrol 10W40 / Mitsu Filter / Rislone Replaced: 2X clutch / 3X brakes / 2X front rotors / 2X ABS HU / 1X NGK Plugs / 1X Ball joints / 2X Antenna mast / 1X Active exhaust cable / 1X Windshield / 1X Fuel FIlter / 1X Struts / 1X rear rotors / 1X Front Head / VSS / 1X rear wheel bearings / 1X Transfer case (warranty) / 1x Tie rod end (drivers side) Overhauled: Starter, IAC, BISS, CV Boots Upgrade: SilverStar Headlights / ebay "Xenon" Fog Bulbs (no more yellow!) A/F Gauge / MAP - Electronic Boost Logging / MMCd Data Logger Pending Projects: Steering Rack |
#43 (permalink) |
No loer a Noob?
one question - with the piston at top dead center how far would the valves fall into the cylander? would they fall far enough to get the valve spring out and still be able to pull them back up?
Just a thought if it would be easyer to remove/replace the vss with the spring out and not have to worry about trying to keep the valve from falling into the cylander. sam |
#44 (permalink) | |
I can measure this on the head to see whether the intake or exhaust valves could actually fall into the engine (Valve angle may cause the valve to hit the cylinder before the stem comes out of the guide.)With piston at TDC I am sure the valve would not fall into the cylinder but I am not not sure if there is enough clearance to remove the spring. Allowing the valve to slide down inside the guide would be a PITA to retreive. O ring on a string keeps the the valve from dropping through the guide while removing the spring. Clint |
#45 (permalink) |
I figured out how to modify the other half of the tool so it can be used to remove the rocker arm. This will also allow the tool to be used with/without the camshaft installed.
Should work (famous last words!) Clint |
#46 (permalink) |
Rebuilding...
Clint,
When are you going to test this new version of the tool? I'd like to replace my seals here in the next few weeks. -- Josh
![]() "Hockey is a sport for white men. Basketball is a sport for black men. Golf is a sport for white men dressed like black pimps." -- Tiger Woods |
#47 (permalink) | |
Clint |
#49 (permalink) | |
Couple other ideas I will play around with tonight while staring at the head on a bench. I would still like to see a pic of the Mitsu tool used to remove the rocker arms. I know I have seen a pic but can't remember where. Clint |
#50 (permalink) | |
no speed limits here
http://www.3si.org/forum/showthread....highlight=tool
Steve
