Old 11-12-2004, 01:04 PM   #21 (permalink)
Member: Burned valve club
cbatters's Avatar
Drives: 91 Stealth RT/TT
Trader Rating: (12)
cbatters is an unknown quantity at this point
Default Re: Make your own valve spring compressor for $15
Originally Posted by Boostaddict
Pull off your front valve cover (cake) to see what you are dealing with. There is no room to remove the valve springs without pulling the cams. Removing the cams isn't that much work. The timing belt will only take a few hours more and the extra room will make sure you don't drop the keepers into the abys of the head...
Think of it this way... you could probably swap brake pads without taking the wheels off, but why would you want to?
Already removed valve cover as per earlier post. I am pretty much resigned to removing the cams but would still like to find a screw type spring compressor instead of arm wrestling with a lever. (If I can save 10 minutes per valve with a better tool I save 4 hours on the job and a lot of frustration.)
Clint
Maint: Castrol 10W40 / Mitsu Filter / Rislone
Replaced: 2X clutch / 3X brakes / 2X front rotors / 2X ABS HU / 1X NGK Plugs / 1X Ball joints / 2X Antenna mast / 1X Active exhaust cable / 1X Windshield / 1X Fuel FIlter / 1X Struts / 1X rear rotors / 1X Front Head / VSS / 1X rear wheel bearings / 1X Transfer case (warranty) / 1x Tie rod end (drivers side)
Overhauled: Starter, IAC, BISS, CV Boots
Upgrade: SilverStar Headlights / ebay "Xenon" Fog Bulbs (no more yellow!)
A/F Gauge / MAP - Electronic Boost Logging / MMCd Data Logger
Pending Projects: Steering Rack
cbatters is offline   Reply With Quote
Old 11-12-2004, 02:17 PM   #22 (permalink)
Gearhead
OthercarisaFiat's Avatar
Drives: 92 TT,82 Fiat Spider
OthercarisaFiat is an unknown quantity at this point
Originally Posted by cbatters
Appreciate your input. My first choice is to find an existing tool that allows the spring to be compressed using a screw instead of a lever. This would free up both hands to remove/install the spring/keepers. Any time savings gets multiplied times 24 springs so I figured it was worth looking around to see what was available.
Did you ever consider modifying the tool (KD-2078) to allow it to grab onto the spring?
Clint
Yes, but I couldn't figure out how. The arms that are supposed to grab the spring coils are too big. There's really nothing you can do without redesigning the whole tool. You could make some kind of frame that bolts on to the cam towers, and holds the screw but you'd need several different configurations to reach all the valves.
I started out with a piece of pipe and a crowbar, and it developed into the tool that started this thread. As I stated somewhere earlier, it took me about 15 minutes per valve to remove the keepers, remove the spring and retainer, replace the stem seal, replace the spring and retainer, and reinsert the keepers before moving on to the next valve--so about 6 hours for the whole engine, not counting my time to make the tool.
OthercarisaFiat is offline   Reply With Quote
Old 11-12-2004, 05:34 PM   #23 (permalink)
cbatters's Avatar
Trader Rating: (12)
I'll pop the front rocker cover off again this weekend and measure the spring/head clearances to see if there is any hope for a stand-alone spring compressor remover. If it's too tight, I will be making one of your tools.
Do you know if there are any online pics of the Mitsu tool?
Clint
Old 11-12-2004, 06:05 PM   #24 (permalink)
Gearhead
Clint
I've never seen one. I understand it bolts onto the cam tower somehow, and then there is a lever to compress the spring. I think that is what Hans at Ground Zero Performance has, and I understand that he sometimes loans it out.
Old 11-13-2004, 11:51 AM   #25 (permalink)
Paid Member
pearlxman's Avatar
Drives: 92 3000GT
Trader Rating: (21)
pearlxman Level 2pearlxman Level 2pearlxman Level 2pearlxman Level 2
I have the second mitsu type tool. I requires taking the heads off, but works great cost me $130 shipped for it. it puts a cut out socket on the spring, the other side goes on the end of the valve (piston side) and you just turn it and pull out the keepers. Took me about 3-5 minutes per valve.
Taking off the heads wasn't that bad either. Only a few more things to take them off. Just had to take off the downpipe, water coolant housing, lower intake, fuel rails, etc. Makes doing the valve seals MUCH easier.
pearlxman is offline   Reply With Quote
Old 11-24-2004, 12:23 PM   #26 (permalink)
cbatters's Avatar
Trader Rating: (12)
Many thanks to *GT for providing me with a loaner DOHC...
After talking to another member a few months ago, I had abandoned my original goal to build a tool that would allow replacing the VSS without removing the cams. After spending a couple of hours measuring tolerances on the head last night, I am 100% convinced it is possible to build a robust tool that will allow the spring to be compressed with a screw action and leave both hands free for removing/installing the keepers.
Compressed height of the springs is 1.492" with a force of ~50 pounds and a free length of 1.827" There is approximately .650" between the top of the valve retainer and the cam lobe so there is enough room to install the uncompressed spring with the cam shaft in place.
Reviewing possible design/fabrication options now...
Old 11-24-2004, 01:25 PM   #27 (permalink)
Good2Go's Avatar
Drives: people crazy
Trader Rating: (14)
Good2Go is an unknown quantity at this point
The mitsu tool that you can buy is a screw type instead of a lever. It looks pretty easy to replicate if you can just weld
1992 Blue Stealth Single Turbo.
3.5 swap with Ross Pistons, Pauter Rods, 72MM DBB PHR turbo, HKS GT 60mm wastegate, AEM EMS, AEM UEGO dual widebands,6 speed conversion with MR Gear Conversion and NPPW CNC "bellhousing beefup plate", ACPT carbon fiber driveshaft, 3.5 inch dual exhaust, PWR Aluminum Radiator w/ Flexalite fans, 1000cc injectors, ported heads and 5 angle valve job, Maximal Performance solid motor mounts, APEXI FMIC, Competition Clutch IronMan Clutch, fidanza flywheel, Tial BOV, Dual Walboro's, Full Stainless Steel -08 AN to dual -06 AN Fuel system with aeromotive FPR, UDP, KSport Coilovers and Maximal Performance adjustable control arms, Autometer Sport Comp Boost, coolant temp, and oil pressure gauges, 2G Brakes - Full ABS delete, Gunmetal Kosei Sniper 18x9's, Complete 350z Blue Color change... about 100 sq ft of dynamat, Boston Acoustic Pro speakers and xtant amps.
Good2Go is offline   Reply With Quote
Old 11-25-2004, 09:33 PM   #28 (permalink)
No loer a Noob?
skunkworks's Avatar
Drives: low impedance inputs
Trader Rating: (9)
skunkworks is an unknown quantity at this point
Default 3si to the rescue - valve seal replacement
My brother-in-law has an intrepid that started smoking. He was going to spend this weekend changing the valve stem seals. He bought a valve spring compressor and everything. He called my dad to come over and take a look at it to give him some pointers. To make a long story short the vavle spring compressor that he bought did not fit around the valve springs. Dad did a search on yahoo and this thread came up-
Thanks OthercarisaFiat
Dad made one up and it worked great. The funny thing is I was looking at the exact thread last night as I am going to be replacing my valve steam seals in the near future. I was busy cooking thanks giving dinner today to get over and take a look.
sam
92 Stealth R/T TT - 13t's Installed. note:Is the machining right? - boosting to 15psi so far.
Do I do this for others? No. robbeck is your man.... We know his work
skunkworks is offline   Reply With Quote
Old 11-29-2004, 11:24 AM   #29 (permalink)
cbatters's Avatar
Trader Rating: (12)
Default Re: 3si to the rescue - valve seal replacement
UPDATE:
Over the holidays I built a prototype of the patent pending VSS-CSI tool (replace VSS with cam shafts installed) and it worked like a champ. I was able to torque the tool down with a ratchet and remove the valve spring keepers in less than 30 seconds. (Thinking about adding a powerful magnet to automatically remove the keepers to make it even easier/faster.)
Then I discovered a good size glitch. Easy to remove the valve retainer but impossible to remove the valve spring with the valve stem fully extended. (At this point Kevin - aka MyKiss69 can rightly say "I told you so!")
PLAN A
Simple tool to remove the valve stem seal without removing the spring. (Even with the spring off - you really want some kind of tool to quickly remove the VSS. I was able to pop 2 of them off using a screwdriver but is was a PITA.)
PLAN B (probably too complicated/risky for average users)
1. Attach c clip to top of valve stem - remove pressure allowing valve to drop down into cylinder - remove spring
2. Re-pressurize cylinder - remove clip - remove/install VSS
3. Reinstall clip - remove pressure - reinstall spring - pressurize - remove clip
4. Install valve retainer - compress spring - install keepers - decompress spring
Sounds complicated but the whole procedure should not take more than 2-3 minutes / cylinder.
Clint
Old 11-29-2004, 08:26 PM   #30 (permalink)
No loer a Noob?
skunkworks's Avatar
Trader Rating: (9)
I like plan A. Do you think a tool could could be make that would slip over the vss and pull them off? I would love to be able to do this without having to remove the cams.
I was thinking the vss are like the ones in the intrepid where the valve spring traps the seal down.
sam
