Old 09-17-2008, 04:41 PM   #171 (permalink)
Slow in the driveway
mkmckenzie's Avatar
mkmckenzie is an unknown quantity at this point
Default Re: Make your own valve spring compressor for $15
I suspect a seal that has come off will not be re-seatable. It takes very little force to move the seal up and down the valve stem, but to remove and replace the keepers, you need something holding the valve up: if the heads are on the car, compressed air in the cylinder is the usual choice, though some use rope fed in through the spark plug hole.
mkmckenzie is offline   Reply With Quote
Old 09-17-2008, 06:48 PM   #172 (permalink)
mkmckenzie's Avatar
Here's pictures of my ghetto keeper installer. Works like the silver-bullet-looking tools are supposed to. Just put keepers in retainer and press onto end of valve stem with thumb. Next, center this tool on top of the retainer and press down with whatever you can. CLICK! The socket presses down retainer/valve-spring. The sprung inner sleeve lets the keepers rise up from retainer a bit as they travel down the stem toward the groove and then presses them down into the retainer once they reach the groove.
Deep 13mm socket. 1/2" nut for spacing. Spring is .4" dia (.5" would be better) & .7" long. Steel sleeve is 12mm OD, 8mm ID, 1/2" long. These parts were found at an Ace Hardware.
Old 09-18-2008, 08:55 AM   #173 (permalink)
Keeps 3Ses on the road
xteekayx's Avatar
Drives: anything that rolls
Trader Rating: (15)
xteekayx is an unknown quantity at this point
Thank You ... i'll try to make one liek that to remove the keepers also ... just put a magnet in there... this is amzing idea, thanks!...
xteekayx is offline   Reply With Quote
Old 09-19-2008, 12:56 AM   #174 (permalink)
mkmckenzie's Avatar
Yeah, I did have to ghetto-up a remover for the back 4-5 valves that lacked enough clearence to use the purchased remover. So I put 3 very strong little magnets in the end of a 14mm socket and use a prybar to depress. It worked, but not very well -- the keepers didn't want to come loose (I prolly needed more or stronger magnets).
Old 09-19-2008, 01:18 AM   #175 (permalink)
GymRat's Avatar
GymRat is an unknown quantity at this point
Wow, now if I can incorporate that into my cheap and easy
valve spring compressor ... C-clamp, 5/8" socket and a piece
of flat steel
"If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit."
GymRat is offline   Reply With Quote
Old 09-19-2008, 01:59 PM   #176 (permalink)
OMGOMGOMGOMG
J-Ville VR-4's Avatar
Drives: 91 VR-4
Trader Rating: (13)
J-Ville VR-4 is an unknown quantity at this point
I like that design, hands-free valve spring compression is awesome
Jake - 91 VR-4
J-Ville VR-4 is offline   Reply With Quote
Old 09-28-2008, 10:19 PM   #177 (permalink)
xteekayx's Avatar
Trader Rating: (15)
of flat steel
What size clamp is that? ...
Old 09-29-2008, 01:10 AM   #178 (permalink)
CHRIS75's Avatar
Drives: 93 3000GT VR-QUATTRO
Trader Rating: (16)
CHRIS75 is an unknown quantity at this point
Yeah can you give more details more pictures, that seems a very nice idea.
Originally Posted by blizzy View Post
he was probably used to driving his civic and he punched 2nd hahahahaha
F1 ... Where Nascar & Indi Drivers Dream To Compete
So long Michael.
CHRIS75 is offline   Reply With Quote
Old 09-29-2008, 11:01 PM   #179 (permalink)
xteekayx's Avatar
Trader Rating: (15)
Here's what I've seen in the manual, looks like a piece of bent flat rod .... i maight try this..
Old 06-06-2009, 03:47 AM   #180 (permalink)
GTOruss is an unknown quantity at this point
It's been awhile since this thread was active but I thought I'd post anyway. I'm approaching the very same project and really enjoyed reading all the input. I've done the timing belt thing already and will probably pull the cams, the t.b. wasn't that difficult. I have a '95 VR4 and in looking up the valve stem seals there is a break off date on the seals. One for engines manuf. prior ot 11/94 and on for after that date. Here's my qustion, finally, how can I determine the manufacture date on my car? My vin number says 1995, the id tag in the driver's side door, tire pressures etc, says June 1994. Any help would be greatly appreciated.
GTOruss is offline   Reply With Quote
