Old 09-22-2007, 11:34 AM   #151 (permalink)
highconnector's Avatar
Drives: 92 vr4
highconnector is an unknown quantity at this point
Default Re: Make your own valve spring compressor for $15
Here Is The Pic.the only spot that was a pain was where the egr and plenum stay bracket are. I found that if you insert the tool and then pull it back a hair you get the extra compression you need,it also helped to work the tool up and down a few times to really get the spring down.hope this helps
highconnector is offline   Reply With Quote
Old 12-12-2007, 06:11 PM   #152 (permalink)
soccermania688's Avatar
Drives: 1993 Mitsu 3000GT Sl
soccermania688 is an unknown quantity at this point
so you changed the vss with this tool from ebay with the cams and heads still on? i found the link to the tool on ebay and was thinking of buying to change my vss. also is it worth changing the lifters if mine dont tick at all?
link: http://cgi.ebay.com/SNAP-ON-Mitsubis...spagenameZWDVW
soccermania688 is offline   Reply With Quote
Old 12-16-2007, 07:46 AM   #153 (permalink)
tmcnam is an unknown quantity at this point
Hi Guys,
Is there anyone that will replace VSS on DOHC for a reasonable price. At one time I saw a post from someone would do it this way for around $300.00 in the Dallas area but can't seem to find that thread.
I need this done (for a reasonable amount) in the Ark, La., Texas area.
Thanks!
Tim
'92 3000GT DOHC that embarrasses the crap out of me in a drive through as it puts up a smoke screen...
tmcnam is offline   Reply With Quote
