Old 07-20-2003, 11:48 PM   #1 (permalink)
Gearhead
OthercarisaFiat's Avatar
Drives: 92 TT,82 Fiat Spider
OthercarisaFiat is an unknown quantity at this point
Default Make your own valve spring compressor for $15
I couldn't find a valve spring compressor that would work without taking the heads off. I bought two different ones that didn't work because there is no room around the springs for the little arms that are supposed to hook onto the lower coils. Supposedly there is a Mitsubishi tool that will work but it's $200 if you can find it (I could not). So, I made my own from commonly available parts I bought from Home Depot for less than $15.
The photo below is the valve spring compressor in action. The posts following will explain how to make it.
OthercarisaFiat is offline   Reply With Quote
Old 07-20-2003, 11:59 PM   #2 (permalink)
Gearhead
Default
Materials you will need:
(1) 3/4" pipe nipple, 3-1/2" long not including threads (cut them off if present).
(1) Steel bar stock, at least 12" long (preferably 14"), 1" to 1-1/2" wide, 1/4" thick; or a channel if you can find it, 1-1/2" wide by 1/2" deep by 1/8" thick. I had to buy a 36" long piece and cut it to length; this was the biggest part of the material cost.
(1) 5/16" x 6" screw eye, with a center hole about 1" diameter.
(1) 5/16" washer
(1) 5/16" nut
(1) 1/4" x 1" hex head bolt
(1) 1/4" nut
(4) 1/4" washers
Tools I used (yours may vary):
10" miter saw with abrasive metal cutoff blade (to cut pipe and handle to length)
4" angle grinder with metal cutoff blade
Dremel with 1-1/2" metal cutoff blade
Hacksaw with tungsten carbide rod blade
6" bench grinder with grinding wheel and wire wheel
Flat bastard file
Drill with 3/8" bit
Hammer and centerpunch
The first piece is made from a 3/4" pipe, black iron or galvanized. Cut off a piece 3 1/2" long. You don't want threads on the bottom surface that contacts the valve spring retainer. Threads on the other end don't matter. Cut out the window in the side using an angle grinder with cut-off wheel, a Dremel, or a hacksaw if you're a masochist. I used an angle grinder for the straight cut about 1/4" from the bottom and the angle cut at the top of the window, and a Dremel with a little abrasive cut-off wheel to make the cuts parallel with the pipe. Grind or wire wheel all the cut edges smooth. I tried covering the bottom surface with electrical tape so it wouldn't scratch the retainers, but it doesn't stay in place very long. None of my new retainers got scratched anyway (they're titanium). The finished piece looks like the picture.
Old 07-21-2003, 12:12 AM   #3 (permalink)
Gearhead
Default
Next, make the handle. I used a 1 1/2" x 1/2" x 1/8" channel. You could also use flat bar stock, but it would probably need to be 1/4" thick. Don't use a tube section for reasons which will become obvious. Cut a piece about 13 or 14 inches long and grind the cut edge smooth. Drill a 3/8" hole about 1/2" from one end and another 3/8" hole about 1 1/2" in from the first one.
The hook is a 5/16" x 6" screw eye with about 1/4 of the eye cut off. There are also screw hooks you can buy, but usually they have an elongated hook that will get in the way and be difficult to use. The screw eye with a section cut out works better. You also need one or two 5/16" washers and a 5/16" nut; also a 1/4" x 1" hex head bolt, about four 1/4" washers and a 1/4" nut.
For initial setup, put the hook through the hole closest to the end of the bar, and put on the washer and nut. Run the nut down until about 1" of the threaded end of the hook sticks out. With the hook hanging down, put the 1/4" bolt with three washers up through the other hole, then put the other washer and the nut on and tighten the nut finger tight. The assembly looks like this.
Old 07-21-2003, 12:13 AM   #4 (permalink)
Gearhead
Default
The valve spring compressor is now ready to use. Here is a close up view of the parts.
Old 07-21-2003, 12:18 AM   #5 (permalink)
Gearhead
Default How to Use the Valve Spring Compressor
Step 1: Maneuver the hook under the crossbar cast into the head, approximately under where the camshaft would be (I think this is an oil passage for the lash adjusters?)
Note: In the picture, the camshafts are removed. I haven't tried this without removing the camshafts so I don't know if it is possible. You could probably do it with a little bit larger hook.
Old 07-21-2003, 12:21 AM   #6 (permalink)
Gearhead
Default
Step 2: Put the top end of the pipe over the bolt head and washers (these will keep it in place) and maneuver the bottom end over the spring retainer. Rotate the pipe so that the window is accessible, preferably up to catch any dropped keepers.
Step 3: Make sure the pipe is centered over the spring retainer, and adjust the nut on the hook to take up any slack, then press down on the handle to compress the valve. Hold it with one hand and use your other hand to remove or insert the keepers, with needlenose pliers, hemostat or whatever. By twisting and manipulating the handle, you can control the position of the retainer with respect to the valve stem to facilitate getting the keepers in and out.
Last edited by OthercarisaFiat : 06-24-2004 at 04:16 PM. Reason: Missing Information from Original Thread
Old 07-21-2003, 12:29 AM   #7 (permalink)
Gearhead
Default Exhaust valves in the back row
The exhaust valves in the rear cylinder bank have to be done differently, because there will be no room for the handle. Remove the hook and the bolt, and reverse them so the hook is where the bolt was and vice versa.
Old 07-21-2003, 12:33 AM   #8 (permalink)
Gearhead
Default
Now instead of pushing down on the handle, you have to pull up on it. It's a little harder but it still works. If you have a helper this would be a piece of cake, but I did all 24 valves by myself using this tool.
You could wrap some duct tape around the end to make a sort of handle, that would be more comfortable to use; I didn't bother. There is also a liquid rubber type product you can dip the end in to make a rubber grip; Plasti Dip and Grip 'N' Guard are two brand names. I'd estimate it takes about a 20 lb. push or pull on the handle to compress stock springs, so it's not really uncomfortable even without this, but it would make it nice if you are going to use it more than once.
1992 Stealth Twin Turbo - 352 awhp, 378 ft-lb awtq @ 16 psi
15G's, DSM sidemount intercoolers with electric fans, 680 cc PTE's, Supra fuel pump, Greddy e-manage, Blitz SBC-iD/PWM-iD, lots more
Old 06-07-2004, 06:11 PM   #9 (permalink)
Indy here we come 06/2010
Alan92RTTT's Avatar
Drives: 1992 RT/TT
Alan92RTTT Level 2Alan92RTTT Level 2Alan92RTTT Level 2Alan92RTTT Level 2Alan92RTTT Level 2Alan92RTTT Level 2
Default Re: Make your own valve spring compressor for $15
Post copied to the how-to section.
Better late then never? The 2009 3S Calendar
NG07 T-Shirts For Sale * NG08 T-Shirts For Sale
NG08 Stuff from Cafepress
Custom 12x18 poster/photo prints
Alan(3SI#601)alan92rttt@mi3si.org Michigan 3SI.
1992 Dodge Stealth RT/TT
My Snake Eyes, 13g Turbos, 450cc DSM injectors, Walbro 255 Fuel Pump, Autometer Boost Guage, Greddy peak/hold EGT, Apexi S-AFC, K&N FIPK, Clean Cats, 3rd Gen Lifters, JVC SX990 CD/MP3 Receiver, JVC CH-X200 12 Disc Changer.
1998 3000GT SL
Alan92RTTT is offline   Reply With Quote
Old 06-12-2004, 05:54 PM   #10 (permalink)
Member: Burned valve club
cbatters's Avatar
Drives: 91 Stealth RT/TT
Trader Rating: (12)
cbatters is an unknown quantity at this point
So what is the final word... can the VSS job be done without removing the cam shafts?
Clint
Maint: Castrol 10W40 / Mitsu Filter / Rislone
Replaced: 2X clutch / 3X brakes / 2X front rotors / 2X ABS HU / 1X NGK Plugs / 1X Ball joints / 2X Antenna mast / 1X Active exhaust cable / 1X Windshield / 1X Fuel FIlter / 1X Struts / 1X rear rotors / 1X Front Head / VSS / 1X rear wheel bearings / 1X Transfer case (warranty) / 1x Tie rod end (drivers side)
Overhauled: Starter, IAC, BISS, CV Boots
Upgrade: SilverStar Headlights / ebay "Xenon" Fog Bulbs (no more yellow!)
A/F Gauge / MAP - Electronic Boost Logging / MMCd Data Logger
Pending Projects: Steering Rack
cbatters is offline   Reply With Quote
