Old 09-22-2007, 11:34 AM   #151 (permalink)
highconnector's Avatar
Drives: 92 vr4
highconnector is an unknown quantity at this point
Default Re: Make your own valve spring compressor for $15
Here Is The Pic.the only spot that was a pain was where the egr and plenum stay bracket are. I found that if you insert the tool and then pull it back a hair you get the extra compression you need,it also helped to work the tool up and down a few times to really get the spring down.hope this helps
highconnector is offline   Reply With Quote
Old 12-12-2007, 06:11 PM   #152 (permalink)
soccermania688's Avatar
Drives: 1993 Mitsu 3000GT Sl
soccermania688 is an unknown quantity at this point
so you changed the vss with this tool from ebay with the cams and heads still on? i found the link to the tool on ebay and was thinking of buying to change my vss. also is it worth changing the lifters if mine dont tick at all?
link: http://cgi.ebay.com/SNAP-ON-Mitsubis...spagenameZWDVW
soccermania688 is offline   Reply With Quote
Old 12-16-2007, 07:46 AM   #153 (permalink)
tmcnam is an unknown quantity at this point
Hi Guys,
Is there anyone that will replace VSS on DOHC for a reasonable price. At one time I saw a post from someone would do it this way for around $300.00 in the Dallas area but can't seem to find that thread.
I need this done (for a reasonable amount) in the Ark, La., Texas area.
Thanks!
Tim
'92 3000GT DOHC that embarrasses the crap out of me in a drive through as it puts up a smoke screen...
tmcnam is offline   Reply With Quote
Old 05-16-2008, 07:33 AM   #154 (permalink)
Drives: 95 3kgt, 98 Eldorado
Thrashpipe is an unknown quantity at this point
I see this thread has not been talked in for a while. I was wondering if anybody had one of those tools that was being talked about on ebay. seems its not sold anymore. i need to do my VSS pretty bad and wanted it to be as easy as possible. also has anybody looked into this the snap on tool "GA318A"?
heres a link to it: GA318A, Tool, Overhead Valve
theres also a vid of a guy using it on you tube. looks pretty simple (if you have your head out haha) which is why i was hoping somebody had that ebay tool or the other tool that Skunkworks made.
Thrashpipe is offline   Reply With Quote
Old 05-16-2008, 10:46 AM   #155 (permalink)
Token English Guy
FR1DAY's Avatar
Drives: 92 3000Gt SL
FR1DAY is an unknown quantity at this point
well the ebay tool seems to be this one from snapon
http://www.snapon.com/international/...les/ya9970.pdf
part no ya9970
i just did my vss but i pulled my heads at 120k you can bet the combustion chamber and valves need a good cleaning anyway
fresh off the engine
nice and clean used some b12 and it lifted the carbon build up right off the bowl. the valves where cleaned via a wire wheel
My 3000gt is just like a woman.
beautiful to look at but can be a total bitch, has a ton of issues I completely fail to understand and could stand to lose a few pounds
FR1DAY is offline   Reply With Quote
Old 05-17-2008, 04:49 PM   #156 (permalink)
Very good job, and thanks for the link. i will probably pull my heads as well, expecially if its going to look like that inside. (tool looks easy enough to make outa some steel)
Old 05-27-2008, 05:34 PM   #157 (permalink)
Well im all done with my valves and belt/waterpump/pullys change. as far as the toughness of it all, ide say the hardest part was tearing the side apart to put the t-belt on. thanks for all the info and ideas, made the job alot easier! me and my cuz ended up taking the hood off and making a tool with a mix between the first and second versions on here. just a pipe with the "window" area cut wider like the second tool (no leverage, just pushed down on them and used a magnet to grab the keepers. then pushed down on the valve and used sergical snips to put the keepers back in. very fast and easy job. good luck to all the other guys willing to go on this adventure. very good for your experience points!
Edit: Well bad news , after replacing my VSS she smokes more then usual now. i did everything very carefully too, timing is dead on. is there some kind of period of time where they have to "wear in" or something? it dosnt seem like it should but this is my first time replacing VSS.
when i start the car i will have "safe zone" oil pressure. after driving around for about 5 minutes and letting it idle it will drop to around 3 bars from the very bottom of the gauge, under the safe zone. and i know enough for that to not be a good thing. i have not very much smoke at idle but when i take off ill have a trail of blue following me for a minute untill the pressure builds up.
My car is the base model , no turbos. 95 DOHC. using castrol gtx 10w40, Any help would be appreciated. as im kinda confused at the moment. Oh and i did a compression test on all cylinders and they all are exactly the same actually above 155psi a little bit.
Old 07-06-2008, 05:18 PM   #158 (permalink)
*Bump* any suggestions ?
I guess what ill do is pull it and just redo it all like i shoulda in the first place.
Old 07-09-2008, 02:54 AM   #159 (permalink)
Member: Burned valve club
cbatters's Avatar
Drives: 91 Stealth RT/TT
Trader Rating: (12)
cbatters Level 2cbatters Level 2cbatters Level 2
1. Ignore stock oil pressure gage. If you have more than one line at low idle your presure is likely ok. (Assuming oil light never flickers)
2. Is it smoking ll the time? How many miles have you put on engine? (Give it at least 50 miles to burn off all of the oil from assembly.)
Clint
Maint: Castrol 10W40 / Mitsu Filter / Rislone
Replaced: 2X clutch / 3X brakes / 2X front rotors / 2X ABS HU / 1X NGK Plugs / 1X Ball joints / 2X Antenna mast / 1X Active exhaust cable / 1X Windshield / 1X Fuel FIlter / 1X Struts / 1X rear rotors / 1X Front Head / VSS / 1X rear wheel bearings / 1X Transfer case (warranty) / 1x Tie rod end (drivers side)
Overhauled: Starter, IAC, BISS, CV Boots
Upgrade: SilverStar Headlights / ebay "Xenon" Fog Bulbs (no more yellow!)
A/F Gauge / MAP - Electronic Boost Logging / MMCd Data Logger
Pending Projects: Steering Rack
cbatters is offline   Reply With Quote
Old 07-10-2008, 06:56 AM   #160 (permalink)
well, as far as the miles i have put on it since , i would have to say around 250. When i first start it up in the morning i will not have (as much) smoke as when its operating temp. the stock gauge will be up in about the middle of the entire gauge and stay there at idle. but after i have driven it around about 10 minutes, at a light the stock pressure gauge will read about 3 bars from the very bottom of the gauge. and if i was to rev it ide probably smoke everybody out of their cars.
I know its not something that would probably help and ill hate myself for being stupid and trying it but ill try an oil change to mobil1 20w 50 and see if it helps. currently there is new oil (that sat all winter) castrol GTX 10W 30, and i hear that sucks for our cars because of viscosity. if not , well, then my car loses its engine privileges
