Old 08-28-2008, 04:15 PM   #11 (permalink)
Arlof is an unknown quantity at this point
Default Re: JDM TT ECU Speed limiter
I tried to do this on my 1991 GTO import from Japan to fix the cruise control limit, and it didn't work do delimit the cruise.
Arlof is offline   Reply With Quote
Old 09-04-2008, 02:30 AM   #12 (permalink)
GTONW is good to go
Colt45_GTO's Avatar
Drives: Black '91 TT
Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7
your better off with a speed converter one that solders in just above the speed sensor on the tranny, how the limiter works is from the signal it gets from the speed sensor so if the sensore is showing 200km/h it cuts the engine. the converter recalculates this and sends the signal in mph instead so the whole system reads as normal except its reading it slower. it also fixes the cruise control.
the unit is a simple chip with 4 wires sprouting from it 2 in 2 out it sits inline with the speed sensor wiring and costs £19 off ebay. no need to snip ecu wires and you're speedo will start to read in mph. its the cheapest and most effective fix
MITSUBISHI SPEEDO CONVERTER / DELIMTER / KMH TO MPH on eBay, also, Toyota, Car Parts, Cars, Parts Vehicles (end time 11-Sep-08 13:13:50 BST)
Colt45_GTO
Semper Fidelis
go register at www.gtonw.co.uk
Originally Posted by Stealthee View Post
Seriously. Just like people will talk down to you when you post about getting a ticket.
People on here need to learn when to shut the fuck up and stop being hypocritical.
Old 09-09-2008, 11:31 AM   #13 (permalink)
15t's ... ? yep
DigiiManDan3KGT's Avatar
Drives: 80Gig WesternDigital
Trader Rating: (7)
DigiiManDan3KGT Level 2DigiiManDan3KGT Level 2DigiiManDan3KGT Level 2
Originally Posted by Cruzer View Post
Im really stumped and could use some ideas to try. Maybe I can hotwire the fuel pump so the ECU cant turn it off... dunno? any ideas? or know of someone else with a JDM TT swap?
You have the wrong idea about fuel cut. Its not actually fuel cut. The injectors stay open and it safely prevents you from making power.
If that fuel pump cut off at 120mph at 6+K rpms you would be in the wanted section looking for a motor.
btw i cut the wire and it worked fine with my 91 JDM ECU on my FWD TT.
Green 1995 3000GT FWD-TT 8:1 // 15t Turbos // ATX to MTX // NA to TT // Purchased 11/12/02
White 1999 3000GT Black Dash/Tan Leather Interior // SOHC // MTX // Stock Daily Driver Purchased 7/25/07
Red.._1992 Stealth RT/TT Twin Turbo AWD // Organ Donor // Purchased 05/19/08
<-- Click Here Join FL3S
DigiiManDan3KGT is offline   Reply With Quote
Old 09-09-2008, 11:44 AM   #14 (permalink)
LeRoyDL's Avatar
Drives: 1992 R/T TT Conv.
Trader Rating: (46)
LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7
Were you really getting speed cut before clipping the wire? I do not hit a speed limiter, what model are you? 92RT uses a mechanical speeddo and i have had i above 135 since the jdm tt ecu went in. Is it pulling a signal from somewhere else? Maybe I actually have euro spec and not jap?
1992 Stealth R/T
Drive Train/Performance:
Aem FPR (Rob's adapter), DR650r's, Borla Cat-Back, Dejon Intake / Blow Through Setup, GM Maf / Maf-T, Greddy E-Manage (Blue), Greddy E-01 Boost controller, Greddy Type RS BOV,
Maximal Performance Solid Motor Mounts, MSD Ignition Wires, Optima Yellow Top Battery, Spec Stage 3 6 puck Clutch, Walbro Fuel Pump.
Exterior/Appearance:
1999 3000GT Front Bumper, Headlamps and Turn Signals, Second Generation Stealth Hood, Side Skirts/Door Caps, Rear Bumper and OEM 96 Wing.
Interior:
Cianci Triple 60mm Gauge Pod (matching passenger side replacement), Greddy Counter Weight Shift Knob,
Greddy Silver 60mm P/H/W Gauges (center replacement and gauge pod), LC-1 Wide Band, M515 PDA/MMCD Data Logger,
Seattle Roller Bearing Short Throw Shifter.
Suspension/Wheels:
Black Racing Pro N1 17x9 Wheels, Cusco Front and Rear Strut Bars, Ground Control Coil Overs (Stock ECS Struts), Stealth TT Brake Upgrade.
Soon To Come:
A drivable car!!!!
To Do:
Finish building/Install motor, Install Water/Meth Injection, Tune Properly, Paint and Install AWD Conversion parts (after motor break in/tuned).
LeRoyDL is offline   Reply With Quote
Old 09-09-2008, 02:05 PM   #15 (permalink)
15t's ... ? yep
Trader Rating: (7)
I'll try and find out more for you but for now, i know it was deffinitly stopping me at 120mph.
being fwdTT i used the JDM ECU, JDM harness, on the JDM motor, with the JDM 5spd tranny, and im pretty sure it was an electronic speedo not mechanical. (I might be wrong b/c ive only delt with 1 type and not the other) Obviously some parts are identical but maybe that will aid you somehow.
Old 09-09-2008, 07:51 PM   #16 (permalink)
LeRoyDL's Avatar
Trader Rating: (46)
Ahh HA! If you changed out the harness what was why. I am using the JDM TT ECU on a stock NA harness, I have no speed sensor on the tranny.
Old 09-10-2008, 12:07 AM   #17 (permalink)
15t's ... ? yep
Trader Rating: (7)
i was working on the car tonight, and i deffinitly have a electronic speedo. I remember what the mechanical one looked like now. Deffinitly electronic for my car.
Old 09-10-2008, 04:04 AM   #18 (permalink)
Drives: 98 3rd Gen GTO
TrueblueGTO is an unknown quantity at this point
Sounds like a good idea I'll have to look into that. Does it work on all models?
TrueblueGTO is offline   Reply With Quote
Old 09-11-2008, 01:40 AM   #19 (permalink)
GTONW is good to go
Colt45_GTO's Avatar
it works on all models that have electronic speedo's
Old 09-12-2008, 07:55 AM   #20 (permalink)
15t's ... ? yep
Trader Rating: (7)
ya but if he had an electronic speedo then cutting the wire would of worked lol
