#1 (permalink) |
Ok.. I can't find anything anywhere about dissabling the speed limiter on a JDM TT ECU exept a UK site where they recommend a speed limiter cut controller, So I have one installed and found this out, I had the CVs out with W5MG1 Tranny full of oil and outshaft holes plugged, So I test the delimiter, It ran over 160 in fourth gear no problem. I unplugged the Greddy delimiter and sure enough it cut out @ 120mph. So I plugged the unit back in and reinstalled the CVs and did a road test, Its cutting out @ 120 agian even with the delimiter working, I checked all the wiring its all good, So Im thinking there is an ABS signal bypassing the delimiter? Im really stumped and could use some ideas to try. Maybe I can hotwire the fuel pump so the ECU cant turn it off... dunno? any ideas? or know of someone else with a JDM TT swap?
#6 (permalink) |
VR-4 broken again.
It does indeed work. Just one little snip and you too can engage in potentially deadly speeding!
"I have no fear of death. It just means dreaming in silence. A dream that lasts for eternity."
Vincent Volaju |
#7 (permalink) |
wooot!!! i tried it today, and laughed like a little kid as i watched the speedo fly off the clock in third gear !!!
![]() thank you for posting this thread. you are a legend!!! sadly however, i snipped my mates one , and he crashed tonight , writing his car off ![]() |
#9 (permalink) |
Best bet is to feed the delimiter controller wire straight to pin 66 on the ECU, some cars have problems with no speed input to the ecu.
I have an MPH/delimiter chip so the 180km/h is actually 180mph, feed an output to the ECU and to the cruise controller.
JDM GTO TT, Emanage Blue - 450`s Hotwired Walbro - Gutted MAS - K&N Blitz SSBC - Aquamist Water Injection |
