LinkBack (1) Thread Tools
Old 08-12-2009, 08:30 PM   #71 (permalink)
Paid Member
jba3's Avatar
Drives: until bearings spin
Trader Rating: (21)
jba3 Level 1jba3 Level 1
Default Re: How to to modify throttle cable for no cruise control (Dont buy another cable!)-P
Originally Posted by Highboosted View Post
Phubars pics are up on the first post and that's pretty much all you need.
Takes about 30 minutes, didn't even really grind the little cylinder into a ball, and it still works fine.
I want to try this, but I'm feeling a little n00bish. On that second picture, is the throttle cable actually going towards the driver's fender like I think? The first pic it's installed as I expected. Is the second pic just to show detail before it was connected to the intake mani?
Old 08-14-2009, 05:35 PM   #72 (permalink)
cool beans
twospoons's Avatar
Drives: around the internet
Trader Rating: (23)
twospoons is an unknown quantity at this point
yes it is going towards the driver fender... that's the way the sleeve is bent and you just have to loop it around to the intake/tb... this is a really simple mod.
Mods: TD05 14b's, 10.0:1 NA Pistons, AEM EMS, etc...
//img507.imageshack.us/img507/389/newsigtj8.jpg
//img34.echo.cx/img34/4804/td05sig4ji.jpg
twospoons is offline   Reply With Quote
Old 08-18-2009, 08:51 PM   #73 (permalink)
Paid Member
jba3's Avatar
Trader Rating: (21)
OK, here's where I'm at. It's easy to see cause there's no motor in the car, so I figured it's the perfect guinea pig to test with so I don't break my DD.
TOOLS NEEDED:
10mm socket (most bolts)
12mm socket (brackets)
12mm wrench (to loosen the cables at the CC box)
Lone throttle cable coming out from the firewall, ready to tweak
There's a cable that comes from the CC box, across the firewall, and into an egg shaped thing that I removed. It was on the left, towards the middle, roughly near the windshield squirter/battery tray. It's not in the pic but this should make it easy to see where it was.
The standard 3S "this is all the stuff I took out" pics
Where the CC box used to sit. Still need to go back and put the bolts in the open holes though.
Here's my couple questions:
1) Is there a tool that lets you remove/reattach the little nubs from the end of the cables? The one inside the CC assembly is smaller than the regular throttle cable end. I'd like to reuse the regular stock size piece that goes to the TB, and also to remove the solid metal sleeve from the cable and get a new one. This would also let me reuse the stock throttle cable sleeve that bolts to the intake manifold.
Once I get those two things taken care of, I think I'm ready to try it on the other car. I'll take more detail pics of the process along the way on that one.
EDIT: I think I'm a moron. I was wondering about the vac line from the cruise control egg shaped thing. I think that goes to the TB, not the windshield wiper squirter :banghead:
Old 10-27-2009, 11:19 PM   #74 (permalink)
ddumond123 is an unknown quantity at this point
i need help! im looking for a throttle body to the cruise control cable. i had dodge order me a accelerator cable for the stealth and they gave me the throttle body to pedal cable. and i cant seem to find the right cable for my 3000gt SL
ddumond123 is offline   Reply With Quote
Old 10-28-2009, 03:43 PM   #75 (permalink)
Paid Member
jba3's Avatar
Trader Rating: (21)
Sounds like they gave you a non-cruise control cable. That one goes from the pedal, wraps around the motor (not literally ) and to the throttle body. Check the part number and/or ask dodge if they ordered a non-cruise cable.
Old 10-28-2009, 07:05 PM   #76 (permalink)
i ended up going to the nearest pick n pull and got what i needed
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f58/how-modify-throttle-cable-no-cruise-control-dont-buy-another-cable-pics-228699/
Posted By For Type Date
Compilation of DIY's - Florida's Mitsubishi 3000GT & Dodge Stealth Community! This thread Refback 04-09-2008 11:43 PM
