LinkBack (1) Thread Tools
Old 11-07-2004, 07:11 PM   #31 (permalink)
prwest's Avatar
prwest is an unknown quantity at this point
Default Re: How to to modify throttle cable for no cruise control (Dont buy another cable!)-P
I did it today and didn't have any problems, rather easy mod. I'll post pics tomorrow.
I really like the feel of the pedal now, here are some pics.
Suzuki GSXR-600
2003 Corvette -sold 13.1@106mph stock A4
1998 pearl white 3000gt base model -sold
1992 White 3000GT VR4 -sold
WERA #100
prwest is offline   Reply With Quote
Old 11-13-2004, 02:18 PM   #32 (permalink)
Paid Member
pearlxman's Avatar
Drives: 92 3000GT
Trader Rating: (21)
pearlxman Level 2pearlxman Level 2pearlxman Level 2pearlxman Level 2
Default Re: How to to modify throttle cable for no cruise control (Dont buy another cable!)-Pics
I also just finished doing this mod. Wow, not too hard at all. Took about 45min taking my time. Really frees up a lot of space and took away 6lbs.
pearlxman is offline   Reply With Quote
Old 12-06-2004, 01:35 AM   #33 (permalink)
VR4 EVR
autopilot747's Avatar
Drives: 04 STi
Trader Rating: (28)
autopilot747 is an unknown quantity at this point
Im getting tired of my throttle pedal sticking all tha time in idel , any way to get a shorter cable or one with less of a bend, mabe form Galant/Diamante ?
04 STi:
APS cold air intake/turbo inlet/3.5in exhaust/DR750,Cusco oil catch can/headders,Perrin up-pipe/fuel rails,PE 850cc injectors,HKS BOV,Supertec forged pistons,Ferrea springs w/titanium retainers,Ferrea+1mm valves,port&polish,DPR stage 2 cams,MRT radiator,Fp Green,Exedy,Utec
I WILL NEVER GUT ANOTHER CAT AGAIN
autopilot747 is offline   Reply With Quote
Old 02-15-2005, 07:59 PM   #34 (permalink)
Wanted: Traction Problems
badass3000's Avatar
Drives: 18 Y.O. "badass" VR4
Trader Rating: (24)
badass3000 is an unknown quantity at this point
did it today, I have a few "updates" for ya.
#1. I looked for about 10 min for a "blue clip", I dont have one! I do have what your talking about but its bright yellow and not really a 'clip'. I would call it a 'stopper'. Its the thing that stops the big metal thing on the end of the cable from coming loose. located at the top tip of the pedle assmbly.
#2. in step 5 where you say "Look at this cable that you removed in step 3," well you didnt remove that cable YET b/c it is still running thru the firewall, although you did loosen everything on that cable in STEP 4.
the hardest part of this mod is getting those cable ends thru the nut while on your back in the drivers floor, I cused for about 10 min, I hate being down there upside down. But overall, easy mod! thanks for the write up.
badass3000 is offline   Reply With Quote
Old 02-16-2005, 04:03 AM   #35 (permalink)
GOD
2Mitsus's Avatar
Drives: Like an asshole
Trader Rating: (42)
2Mitsus is an unknown quantity at this point
badass3000-
first off; I hope you used washers on your throttle cable, on each side of the firewall. I was having some throttle sticking problems (throttle not 100% completely closing at idle), until I added some washers. This was due to the throttle cable getting partially pushed/pulled through the firewall. Since adding washers (headbolt washers are the perfect size), the problem has disappeared completely.
I also wanted to let you know that I edited my original post to note that the "clip" is yellow on some cars. I also edited yet again to strongly recommend installing washers on the throttle cable.
I agree, getting those nuts off the cable ends is a pain in the ass without getting a screwdriver blade right through your fingers!
...DEAD...
2Mitsus is offline   Reply With Quote
Old 02-16-2005, 04:41 AM   #36 (permalink)
Gene's Performance
RussianVR-4's Avatar
Drives: 2002 TIsilver M3
Trader Rating: (18)
RussianVR-4 Level 1RussianVR-4 Level 1
i couldnt even get the cable to sit there without washers on my buddy's car. washers are a MUST
02 TI silver/black 6spd 90k on the clock
KW V3's, Eibach 2way sway bars, Headers, AEM FIC, VMR V715's Michelin PS2's 295/35/19 rear 245/40/19 front. Boost inc.
RussianVR-4 is online now   Reply With Quote
Old 03-17-2005, 09:49 AM   #37 (permalink)
cool beans
twospoons's Avatar
Drives: around the internet
Trader Rating: (23)
twospoons is an unknown quantity at this point
just wanted to say this is an excellent mod... throttle is a lot more responsive and lighter feeling.
twospoons is offline   Reply With Quote
Old 04-01-2005, 01:39 AM   #38 (permalink)
3S-less
maTT's Avatar
Drives: legally...for once
Trader Rating: (19)
maTT Level 2maTT Level 2maTT Level 2maTT Level 2maTT Level 2
Thanks for the info! I finally broke down and removed my CC. I staired at it for 25minutes the other day debating whether or not to remove it. With the motor out, I could stand looking at the firewall with CC on it so I ripped it out. Time to mod the cable
1992 VR4 12.5@110 - Sold
1991 SL Stock - Sold
1993 RT/TT 11.4@129 - Sold
1992 Porn Panda Twin Turbo ATX- Sold
1995 Montero
1990 Montero
2003 Odyssey
1968 1600 Fairlady
maTT is offline   Reply With Quote
Old 04-01-2005, 01:52 AM   #39 (permalink)
Drives: 99 VR4
Trader Rating: (112)
SHiVeR-91VR4 Level 1SHiVeR-91VR4 Level 1
yep, did it yesterday too. Hated all those line and vacuum hoses everywhere. Took it all out.
SHiVeR-91VR4 is offline   Reply With Quote
Old 04-18-2005, 04:49 PM   #40 (permalink)
Back From Heck
phubar's Avatar
Drives: Black '94 VR-4
phubar is an unknown quantity at this point
Just did mine. I've attached a composite pic.
In pic 1, you can see my gas pedal and the original throttle cable that was attached to it. Note that my "blue" clip is actually yellow - which I suppose doesn't matter if you are blue-yellow colorblind. There is a rubber gasket right behind the clip.
I decided to make a bracket / gasket to mount the cable to my firewall in the original location. So I got my big sheet of tin (purchased from the home depot) and went to work to fashion one.
In pic 2, you can see that I have traced the rubber gasket onto the sheet of tin. I drilled the holes - be sure to back the tin on a piece of wood which you can overdrill into. Step on the tin to hold it in place while drilling (wear boots to protect your feet). When you drill, use very light pressue to avoid tearing the tin. Then cut the tin containing the bracket off, deburr the holes with a dremel, and cut the gasket along the outline.
I decided to make 2 gaskets for added strength (the tin is pretty thin). In pic 3, you can see on the left the first, completed gasket, with the two bolts and the cable threaded through the holes. On the right is the second gasket, whih has been drilled (but not cut or deburred).
In pic 4, you can see the gaskets attached to the firewall, before I threaded the throttle cable through (both are stacked there, not that you can see that).
Pic 5 shows my throttle cable in place, with the cable bolted onto the bracket.
I've also attached a special bonus pic of another bracket I made using this method. Can anyone guess what it's for?
A riced-out car is like a woman in too much makeup...
The intent is to look good, the actual effect is just the opposite.
"You have a plane. It is welded to the runway. Can it take off?"
phubar is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f58/how-modify-throttle-cable-no-cruise-control-dont-buy-another-cable-pics-228699/
Posted By For Type Date
Compilation of DIY's - Florida's Mitsubishi 3000GT & Dodge Stealth Community! This thread Refback 04-09-2008 11:43 PM
