LinkBack (1) Thread Tools
Old 08-16-2004, 02:54 PM   #11 (permalink)
Grandpa
EVILTWIN's Avatar
Drives: 07Accord, 03 C5 ann.
EVILTWIN Level 3EVILTWIN Level 3EVILTWIN Level 3EVILTWIN Level 3EVILTWIN Level 3EVILTWIN Level 3EVILTWIN Level 3
Default Re: How to to modify throttle cable for no cruise control (Dont buy another cable!)-Pics
Originally Posted by HilbillyHomeboy
Yes, weight savings and a less cramped engine bay and less shit to break(all things that the 3/S suffers from). I haven't weighed mine yet, but it's not exactly light.
I'm doing mine today or tomorrow Andrew. I already had it ripped out. I was going to do a custom set-up, but not now thanks to you!!!!!!!!!
Jeremy
Thanks i was just curious
Set the gearshift, for the high gear of your soul.
Chuck Norris can win a game of Connect Four in THREE MOVES
I'm an Equal Opportunity Annoyer!
EVILTWIN is offline   Reply With Quote
Old 08-16-2004, 10:40 PM   #12 (permalink)
EVIL HAMSTER !!!
RaceMe TT's Avatar
RaceMe TT is an unknown quantity at this point
Anyone actually done this? I took my cruise cable out today and was looking at it. To me it looks WAY too long and its going to have to do some little loop in order for it to work.
Any success from anyone?
"Brrr I wouldn't wana run into this guy at a stop light folks would hate to see how bad the dorksled would pownzor me." [3L] to Deathsled, in an argument about a gtpro product.
02 Yammy Road Warrior 102 cubes of Vtwin POWA
92 Black Stealth TT (wrecked, getting rid of it)
92 Sandstorm Stealth TT (new baby)
td05 EVO III 16gs + dumps, Kormex hardened 25 spline trans, Greddy Emanage, Greddy Profec E-01, MAF T and lt1 MAF, IPO/SX complete dual pump/dual feed kit, PT 780cc injectors, TEIN Flex Coilovers, SBC DXD-F and UR Flywheel,17x9 5zigen FNO1R-C's with 275/40/17 Yokohama AVS es100s, Adjustable Rear Control Arms, IPO Propane Injection, ATR Single Shot, Stillen Stainless Steel Downpipe, Unorthodox Racing Underdrive Pulley, Gates Belt Set, G-Force ECU Upgrade, Dimpled/Slotted Bradi Rotors, Stillen Metal Matrix Pads, Stainless Steel Lines, Trunk Mount Odyssey PC680, Defi 60mm Boost gauge, Defi 52mm Oil Pressure and Water Temp gauges, GReddy 60mm EGT Gauge, HKS type 1 Turbo Timer, Krank- Vents, Greddy Catch Can, Valentine 1
RaceMe TT is offline   Reply With Quote
Old 08-16-2004, 11:10 PM   #13 (permalink)
GOD
2Mitsus's Avatar
Drives: Like an asshole
Trader Rating: (42)
2Mitsus is an unknown quantity at this point
You use the stock throttle cable (with the plenum bracket attached to it), not the cruise cable.
Look at the first pic I posted, with it installed.
...DEAD...
2Mitsus is offline   Reply With Quote
Old 08-16-2004, 11:21 PM   #14 (permalink)
EVIL HAMSTER !!!
RaceMe TT's Avatar
No shit Satan, but the stock cable was the one I was looking at, with the bracket attached, and im still telling you it looks way too long.
Old 08-16-2004, 11:26 PM   #15 (permalink)
GOD
2Mitsus's Avatar
Trader Rating: (42)
did you already hook it up to the gas pedal?
Just move it so it's in a position where it reaches the plenum.
Old 08-17-2004, 12:19 AM   #16 (permalink)
GOD
2Mitsus's Avatar
Trader Rating: (42)
since Race MeTT isnt gonna post it, I might as well- here's our AIM conversation...
BligaBla (RaceMeTT): welp, you were right i guess, it goes on there
BligaBla: but it has to be as tight as it possibly can to work
BligaBla: it barely makes it
BligaBla: at the very tightest setting i was able to get 13 on the low, and 98 on the high from teh logger
FrickinJackoff (Me): thats it
BligaBla: but even when i cranked the throttle body by hand
FrickinJackoff: perfect
BligaBla: i couldnt get 100
Old 08-17-2004, 12:27 AM   #17 (permalink)
EVIL HAMSTER !!!
RaceMe TT's Avatar
Well I just went out and did it. It ended up working fine if you set the cable bracket on the plenum as tight as it can go, I was able to get the tension needed. It was just barely there, but there none the less and thats all that matters.
The cable does do a little loop near the brake booster, but its sure as hell a lot better looking than one doing a loop around the whole engine bay, and its waaaaay better looking than the cruise box and all those cables.
1 thing that may make it better are some washers where it goes through the firewall because the nuts kinda go into the hole. I didnt put any on but may do it sometime soon, just to make this deal rock solid. I also didnt find the need to put any superglue on the little clip, its pretty thick plastic and should be fine.
I think he's gonna put some of my pics in his first post.
Anyway, it works, good mod Andrew.
Brandon
Old 09-06-2004, 11:11 PM   #18 (permalink)
VR4 EVR
autopilot747's Avatar
Drives: 04 STi
Trader Rating: (28)
autopilot747 is an unknown quantity at this point
sounds simple and I want to do it, but I need good pics of the whole process.
autopilot747 is offline   Reply With Quote
Old 09-07-2004, 07:07 AM   #19 (permalink)
GOD
2Mitsus's Avatar
Trader Rating: (42)
just follow the step by step instructions above and you'll be fine.
Let me know if you run into any problems (which you wont).
Old 09-07-2004, 10:32 PM   #20 (permalink)
Gene's Performance
RussianVR-4's Avatar
Drives: 2002 TIsilver M3
Trader Rating: (18)
RussianVR-4 Level 1RussianVR-4 Level 1
Originally Posted by 2Mitsus
Updated!- scroll to the bottom of this post for updated pictures of this mod performed on Race Me TT's car. I also made a small revision in step 7 as well.
For those that have removed their cruise control, and wanted to get rid of the military looking box thing, I found a way you can reuse your current throttle cable, keeping the plenum bracket. The end result will look something like this, you wont have to buy another cable from a non cruise control Galant/Diamante (can't remember which it is), that loops around the plenum (note there is currently no motor in my car). Since the factory throttle cable has a major curve in it, it should be fairly easy to get the proper position so the cable ends up where it should be.
jee i didn't notice
02 TI silver/black 6spd 90k on the clock
KW V3's, Eibach 2way sway bars, Headers, AEM FIC, VMR V715's Michelin PS2's 295/35/19 rear 245/40/19 front. Boost inc.
RussianVR-4 is online now   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f58/how-modify-throttle-cable-no-cruise-control-dont-buy-another-cable-pics-228699/
Posted By For Type Date
Compilation of DIY's - Florida's Mitsubishi 3000GT & Dodge Stealth Community! This thread Refback 04-09-2008 11:43 PM
