LinkBack (1) Thread Tools
Old 08-14-2004, 11:39 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
GOD
2Mitsus's Avatar
Drives: Like an asshole
Trader Rating: (42)
2Mitsus is an unknown quantity at this point
Exclamation How to to modify throttle cable for no cruise control (Dont buy another cable!)-Pics
Updated!- scroll to the bottom of this post for updated pictures of this mod performed on Race Me TT's car. I also made a small revision in step 7 as well.
For those that have removed their cruise control, and wanted to get rid of the military looking box thing, I found a way you can reuse your current throttle cable, keeping the plenum bracket. The end result will look something like this, you wont have to buy another cable from a non cruise control Galant/Diamante (can't remember which it is), that loops around the plenum (note there is currently no motor in my car). Since the factory throttle cable has a major curve in it, it should be fairly easy to get the proper position so the cable ends up where it should be.
Don't let the instructions discourage you, this is fairly simple to perform. However, as always, perform this at your own risk.
Instructions:
Step 1. Unbolt the 2 10mm bolts holding your throttle cable bracket to the plenum, and remove the cable from your throttle body.
Step 2. Remove the 10mm nuts holding the cruise control box (green military looking thing) from the car (I believe there are 4 of them). Remove any wiring harness plugs.
Step 3. Unbolt the 2 bolts holding the top half of the military box to the bottom half. Remove the cables. Toss the box in the trash, sell it on eBay, etc.
Step 4. Remove the 2 bolts holding the throttle cable to the firewall. Go inside the car, and remove the 2 bolts holding the accelerator pedal to the firewall. Using a set of pliers and screwdriver, remove the blue clip (edit- it has come to my attention that this clip may not be blue on some cars, it has also been reported as yellow)that secures the cable to the accelerator pedal, without breaking the clip. Put the gas pedal assembly , and the cable you just removed aside for now.
Step 5. Look at this cable that you removed in step 3, and you will see the blue clip that attached to the gas pedal assembly (not in this picture).
Using a razor blade, you need to make a precision cut, lengthwise, on the blue clip, to remove it from the cable assembly. DO NOT mess this up. Take your time, and make a clean cut. Once it's cut lengthwise, you may want to use a screwdriver to "open up" the cut a little bit so you can squeeze the cable through the cut. Once the clip is removed, put it aside and do not lose it.
Step 6. Take the throttle cable that originally went to the throttle body (this is the one you are now going to use), and loosen the outermost 12mm nut. Remove the nut from the cable. You will not be able to easily remove it from the end of the cable, however it must be done. Use a screwdriver to maneuver the end piece of the cable through the nut. Only remove the outermost nut, not both of them! Put the nut aside.
Step 7. Take the throttle cable you just removed the nut from (step 6), and push it through the hole from the engine compartment into the passenger compartment. Update! You may want to use a washer on each side of the firewall, so the nuts don't go through.Go inside the car, and now reinstall the nut onto the cable. Again, it will not go on easily but use a screwdriver and you wont have a problem. Tighten the nut a little bit so it doesn't get in your way. Now take the blue clip removed in step 5, and put it on the cable (a screwdriver may help a bit in this as well). If desired, use 1 drop of superglue on the clip where you originally made your precision cut (although I didn't use superglue at all). Let superglue dry, and snap the clip onto the accelerator pedal assembly. Reinstall accelerator pedal assembly back onto the firewall. edit #2- USE WASHERS! As noted above, washers may be recommended as the cable might get partially pushed/pulled through the firewall. I was experiencing some throttle sticking problems (throttle not completely closing 100% at idle- UNTIL I decided to install washers on the cable, on each side of the firewall. Old & unused headbolt washers are the perfect size. Once I installed the washers, there is absolutely no more issues of the throttle sticking & not completely closing.
Step 8. Install cable onto throttle body, and lightly install cable bracket 10mm bolts. Reposition cable to desired position & tightness, and tighten throttle cable bolts. Tighten nuts that are on both sides of the firewall, that hold your newly modified cable into place.
Done deal. Enjoy.
Updated Pics! (Race Me TT's car)
Click Here for phubar's alternate method; making a bracket instead of using washers.
...DEAD...
2Mitsus is offline   Reply With Quote
Old 08-15-2004, 12:10 AM   #2 (permalink)
EVIL HAMSTER !!!
RaceMe TT's Avatar
RaceMe TT is an unknown quantity at this point
Default Re: How to to modify throttle cable for no cruise control (Dont buy another cable!)-Pics
Great mod Andrew. I removed mine in favor of a diamante cable but if I can find my old cruise box I'll take that cable off and do this. It sure as hell looks a lot better than my diamate cable running all over the damn engine bay.
Good idea, for a shithead.
"Brrr I wouldn't wana run into this guy at a stop light folks would hate to see how bad the dorksled would pownzor me." [3L] to Deathsled, in an argument about a gtpro product.
02 Yammy Road Warrior 102 cubes of Vtwin POWA
92 Black Stealth TT (wrecked, getting rid of it)
92 Sandstorm Stealth TT (new baby)
td05 EVO III 16gs + dumps, Kormex hardened 25 spline trans, Greddy Emanage, Greddy Profec E-01, MAF T and lt1 MAF, IPO/SX complete dual pump/dual feed kit, PT 780cc injectors, TEIN Flex Coilovers, SBC DXD-F and UR Flywheel,17x9 5zigen FNO1R-C's with 275/40/17 Yokohama AVS es100s, Adjustable Rear Control Arms, IPO Propane Injection, ATR Single Shot, Stillen Stainless Steel Downpipe, Unorthodox Racing Underdrive Pulley, Gates Belt Set, G-Force ECU Upgrade, Dimpled/Slotted Bradi Rotors, Stillen Metal Matrix Pads, Stainless Steel Lines, Trunk Mount Odyssey PC680, Defi 60mm Boost gauge, Defi 52mm Oil Pressure and Water Temp gauges, GReddy 60mm EGT Gauge, HKS type 1 Turbo Timer, Krank- Vents, Greddy Catch Can, Valentine 1
RaceMe TT is offline   Reply With Quote
Old 08-16-2004, 03:17 AM   #3 (permalink)
GOD
2Mitsus's Avatar
Trader Rating: (42)
so I typed all of this and no one gives a shit
well, 1 person at least.
Old 08-16-2004, 09:25 AM   #4 (permalink)
Forum Moderator
HilbillyHomeboy's Avatar
Drives: Tin Indian
Trader Rating: (39)
HilbillyHomeboy Level 2HilbillyHomeboy Level 2HilbillyHomeboy Level 2HilbillyHomeboy Level 2HilbillyHomeboy Level 2
Andrew this is great. I'm in the middle of this right now. Thanks so much for the write-up.
Jeremy
HilbillyHomeboy is offline   Reply With Quote
Old 08-16-2004, 10:07 AM   #5 (permalink)
DDI
VR4 whaaaaa?
DDI's Avatar
Drives: 1994 VR-4
Trader Rating: (6)
DDI is an unknown quantity at this point
This should go in the how to section.
-Sean
1994 VR4 w/ 99 front conversion, Supercar Engineering Big Red Brakes with Coleman Rotors, PST CFDS, ProBoost MBC, DSM Intercoolers, ACT Clutch, Fidanza Flywheel
THE PROJECT BEGINS: AEM EMS, AEM WB, GM MAP/IAT, Apexi Boost Solenoid, AAM Dual Intake, AAM TD05 Manifolds (coated), Small 16Gs , 780cc injectors, FMIC, IPO Twin Fuel Pumps
2000 Jeep Cherokee - stock for now, Pioneer AVIC-N1
Mideast3s.com
DDI is offline   Reply With Quote
Old 08-16-2004, 12:56 PM   #6 (permalink)
Grandpa
EVILTWIN's Avatar
Drives: 07Accord, 03 C5 ann.
EVILTWIN Level 3EVILTWIN Level 3EVILTWIN Level 3EVILTWIN Level 3EVILTWIN Level 3EVILTWIN Level 3EVILTWIN Level 3
why would you remove the cruise control? Weight savings? If so, what did you save.
Set the gearshift, for the high gear of your soul.
Chuck Norris can win a game of Connect Four in THREE MOVES
I'm an Equal Opportunity Annoyer!
EVILTWIN is offline   Reply With Quote
Old 08-16-2004, 01:30 PM   #7 (permalink)
Forum Moderator
Drives: Tin Indian
Trader Rating: (39)
Yes, weight savings and a less cramped engine bay and less shit to break(all things that the 3/S suffers from). I haven't weighed mine yet, but it's not exactly light.
I'm doing mine today or tomorrow Andrew. I already had it ripped out. I was going to do a custom set-up, but not now thanks to you!!!!!!!!!
Jeremy
Old 08-16-2004, 02:12 PM   #8 (permalink)
Vette
Drives: '92 VR4, '07 C6
Trader Rating: (10)
Slickwheel is an unknown quantity at this point
well done, i've been waiting for this mod for some time. thanks a lot!
'08 Corvette C6
'07 Corvette C6 (Sold)
'92 3000GT VR4 (Sold)
'94 3000GT VR4 (Crushed)
Slickwheel is offline   Reply With Quote
Old 08-16-2004, 02:13 PM   #9 (permalink)
DDI
VR4 whaaaaa?
DDI's Avatar
Drives: 1994 VR-4
Trader Rating: (6)
I heard it makes the throttle slightly more responsive, is this true?
Old 08-16-2004, 02:50 PM   #10 (permalink)
GOD
2Mitsus's Avatar
Trader Rating: (42)
If people could post pics when they're done, that would be great (I'm a picture junkie)
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f58/how-modify-throttle-cable-no-cruise-control-dont-buy-another-cable-pics-228699/
Posted By For Type Date
Compilation of DIY's - Florida's Mitsubishi 3000GT & Dodge Stealth Community! This thread Refback 04-09-2008 11:43 PM
