#31 (permalink) |
Preserve a 3S
That connection doesn't exist on the ECU Diagram in 94-95. But the ACC diagram has it going to pin 40 on C-52 Which is only numbered 1-26. Seeing the parts were from a 92 ACC for the 95RT/TT install and a 93 ACC for the 95SL install, That connection was used in the donor car and not in the 95SL The Connection does exist in the TT ECU. It is part of the high speed relay system for the radiator and condenser fans in the 92 and 93 cars.
BTW upyun we have the parts for a TT conversion on the SL it is an atx.
![]() October Quickening Best Performance Modification 2004 & 05 -Stealth- Best Non Performance Modification 2004 & 06 Check out the Links "Stealths in Boston" "The 315-Watt Mitsubishi/InfinityŽ CD Audio System with 7 Speakers" "How to install an Amp on a Stock Infinity System. With pics!" "Dash & Door Speaker alternative, installation, & review" '95 RT/TT Firestorm Red one of 61 MSRP $37,448.72 Digital Climate Control Conversion, Radio Control Addition DR-500 turbos, Lucas 550's, RPS Max Street Clutch & Flywheel, Tanabe SM Hyper Exhaust, Greddy Denso, ARC-2, Blitz DSBC, 03 Mitsu Infinity System/in dash 6 Disc Changer Diamond-D971 components, JL e6450 650w 6ch amp Smokin corner box JL W3. 99 lights & fogs w/Hid's . Bridgestone S-03 Pole Position skins. Member #846 6/01 99SL Black (Deb) The first actual 99 Digital Climate Control Conversion Oct. 04, 05, & 06 Quickening "Best Stock" |
#32 (permalink) | |
"The Fisherman"
when i get the time i'd like to do this mod as well brian
#34 (permalink) | |
Electrical Whiz
1995 Vr4 Spyder purchased 3/01/05 Completely Stock. Yea, it's not so stock anymore |
#35 (permalink) |
Dont Do Speed! Mkay!?~
This isnt a thread jack. But ive got a digital climate control im wanting to get rid of. Its in perfect shape as far as I know. If your intrested just Email me at Sharpy698@aol.com Just make me an offer. Ill sell it cheap But Im not going to pay shipping. Thx
91 Pearl White 3KGT VR-4. Fully Conditioned as of 1/7/05 ![]() Mitsubishi. Over engineered to perfection. |
#36 (permalink) |
Florida3S.com
well today i spent a good amount of time going though my GTO dash harness and removing anything connected to the auto air wiring, after hours of unwrapping electrical tape, sniping wires, studying wiring diagrams and labeling wires i hooked it up to 12 volts and the display lit up and the servos came alive. i just hope the servos will work with the left hand drive HVAC unit (the RHD HVAC unit is a mirror of the LHD HVAC) and that they will move the correct way, and not move in the opposite direction. anyway i like the way the display looks and how the buttons beep when you push them, oh and can't forget the animations. my display shows in celsius though so I'm lost, good thing they put a hot and cold bar to the left for cool people like me that can't read celsius
. below are some pics of it under my grandmas hood, i needed the battery (Alan will know what it is )Evan ![]() ![]()
#37 (permalink) |
Preserve a 3S
Good Job looks like you are on your way!
Just for a point of reference what are all the part numbers on the: Display Auto AC Controller Right Motor Center Motor Left Motor Controller Comp Maybe we can figure out this celsius display (if it has a specific part #) Also what year was the donor car? Dave |
#38 (permalink) |
Florida3S.com
Display -------------- MB898523
Auto AC Controller --- MB897173 Right Motor ---------- MB609564 <---RECIRCULATE/FRESH AIR (in RHD this is the left motor) Center Motor -------- MB657287 Left Motor ----------- MB439074 <---NEAR STEERING COLUMN (in RHD this is the right motor) Controller Comp ------ MB897122N I've narrowed the cars year down to a 91 or 92, 1990s did not have power folding mirrors (mine does) and second gens came into play in 93 (mine had pop up headlights and no passenger air bag), I'm speaking of GTOs for those who are confused. i also just noticed that i have a 3 position switch at the top of my display, and on my auto a/c controller i have a hole where i can adjust something called EVA, counter clockwise is L, and clockwise is h. Evan Last edited by shooter83 : 11-08-2003 at 08:24 PM. |
#39 (permalink) |
Preserve a 3S
-------------------Right hand drive-----93 RT/TT (The last donor car)
Display -------------- MB898523-------- MB898523 Auto AC Controller --- MB897173-------- MB897174 Right Motor ---------- MB609564 <---RECIRCULATE/FRESH AIR (in RHD this is the left motor) ----------------------------------------MB439125 Center Motor -------- MB657287-------- MB657209 Left Motor ----------- MB439074 <---NEAR STEERING COLUMN (in RHD this is the right motor) ----------------------------------------MB439123 Controller Comp ------ MB897122N-------MB897122 (not changed in CCC) Caps shows 90.5 and some 91 cars as having different displays and auto controllers. After 91 they are the same until 98. It looks like the Auto AC Controller --- MB897173 is the celsius controller as the display is the same. Hopefully the sensors are the same. They could be checked with an ohm meter. It doesn't look like the motors work. I hear that there is a 91 display that is not as bright???? |
#40 (permalink) |
What have we here
Ahh, can you post a pic of it installed please, just cause I want to see how cool that painted panel would look in the car... and since I don't have an electronic control, does the bands in the icons move or are they still?
