#101 (permalink) | |
Preserve a 3S
I really didn't want to post anything I have for sale in the thread because it is in the "How to section" It was a line I didn't want to cross. Kit # 21 is for sale PM or email me for any details and or questions.BTW thanks for the referral Brian
![]() October Quickening Best Performance Modification 2004 & 05 -Stealth- Best Non Performance Modification 2004 & 06 Check out the Links "Stealths in Boston" "The 315-Watt Mitsubishi/InfinityŽ CD Audio System with 7 Speakers" "How to install an Amp on a Stock Infinity System. With pics!" "Dash & Door Speaker alternative, installation, & review" '95 RT/TT Firestorm Red one of 61 MSRP $37,448.72 Digital Climate Control Conversion, Radio Control Addition DR-500 turbos, Lucas 550's, RPS Max Street Clutch & Flywheel, Tanabe SM Hyper Exhaust, Greddy Denso, ARC-2, Blitz DSBC, 03 Mitsu Infinity System/in dash 6 Disc Changer Diamond-D971 components, JL e6450 650w 6ch amp Smokin corner box JL W3. 99 lights & fogs w/Hid's . Bridgestone S-03 Pole Position skins. Member #846 6/01 99SL Black (Deb) The first actual 99 Digital Climate Control Conversion Oct. 04, 05, & 06 Quickening "Best Stock" |
#102 (permalink) |
"The Fisherman"
No Problem Dave. You are certainly the guy I'll come to when I want to install my kit
I'm sure you could install it waaaay quicker than I could seeing as you've assembled 21 kits already Good Job!
#103 (permalink) |
Hatchet Warrior
its more that people were asking where to get things, so i just wanted to let you know i had something they may need... sorry if i somehow crossed your line...
#105 (permalink) | |
Electrical Whiz
1995 Vr4 Spyder purchased 3/01/05 Completely Stock. Yea, it's not so stock anymore |
#107 (permalink) |
Yep. Power transistor just needed a new ground. But now i'm having trouble with the Mode selector Servo.(far left) i'm getting power to it but it keeps setting itself to the dash vents no matter what i set it to with the control panel. i set it to something manually, with the power off, but as soon as I turn the ignition on it turns to the dash vents.
#108 (permalink) |
Preserve a 3S
This is why you buy a kit
When you dissect a harness you break a few circuits besides the photo and room temp sensors. You need to run all the ground wires you cut to a new ground wire then put a connector on it and ground it. The switch on the top of the display also affects mode settings. The display will remember the settings it was on before being turned off too. |
#110 (permalink) |
Woot!
I am number three for a RT to have the DCCC completed in.
I must say after all the time and energy I have put into this I am now thinking I should have just bought the kit directly from Dave, However if it wasnt for Dave's help on some of the parts I got stuck at I wouldn't be done now. I didn't keep track of the amount of time I spent but it was a lot. All for vanity... -John
1995 Dodge Stealth R/T TT, Dark Green ext, Dark Int, 1 of 20 available to the US.
Mods: 13T turbos, FMIC 3" in/out, Spec Stage 3 clutch, RPS Billet Aluminum Flywheel, Gutted front and rear precat, test pipe, MSD 8.5mm SC Wires, 3rd Gen lifters, EGR Delete, 3SX EGR Block off plates, Blitz DD BOV, Hotwire Walbro 255 Fuel pump, Map ECU, Dual Pillar pod w/ AEM Wideband and AEM Tru Boost, Halo Hybrid Data logger, Supercar Engineering 1/2 billet aluminum Shift fork, fresh 1/2/3 friction rings, custom solid front and rear engine mounts, 3" Straight pipe exhaust single out. Looks: DCC Conversion, White face glow gauges. Sound: Infinity components up front, infinity 10" sub in back with Smokin' VR4 corner sub box, Pioneer HU. Myspace Must go faster project underway. |
| Thread Tools | |
