Old 07-05-2005, 12:00 PM   #1 (permalink)
Toni's Avatar
Drives: 13geed 92 rt tt
Trader Rating: (43)
Toni level 6Toni level 6Toni level 6Toni level 6Toni level 6Toni level 6
Default In car oil pump replacement (faq).
Created a faq from this weekends pump replacement. Decided it should be a seperate post for easier searching. Includes description with pics, pictures.
http://www.penguinhosting.net/~bigma...p/oilpump.html
Let me know if there are any additions or changes.
-Antoni
My site, tons of pics/faqs(Added LED faq!)
DIY LED Kit for Sale
Speed Factor 2nd place best interior modified
'92 pearl white stealth Rt TT: Mitsu 13gs, Black Racing pro n1s, LC1/LM1 logging (rpm, tps, map, dual egt), RPS street disc/fly,255 Walbro, high flow filter, -6an from tank, AFPR with RobBeck adapter, Apexi el2 5 gauges, maximalperformance tcase bracket/adjustable arms/powdercoating, Tein S-Tech, Greddy Type S bov, Custom exhaust, poly motor mounts, short shifter, led interior.
'06 ninja 500r
'08 vw rabbit
Toni is offline   Reply With Quote
Old 07-05-2005, 12:37 PM   #2 (permalink)
BAWC: In the Mix
Monochrome's Avatar
Trader Rating: (25)
Monochrome is an unknown quantity at this point
Default Re: In car oil pump replacement (faq).
Great write up! You should note to use a small amount of RTV on both sides of the gaskets to avoid leaks.
You can also get away with leaving the oil cooler lines and front turbo feed line bolted to the oil filter housing when you unbolt it from the pump. It'll easily push out of the way so you can remove the pump. Saves from having to buy new crush washers for all those banjo bolts.
05 MSM MX5 with 3K miles
98 Solano Black Pearl Metallic VR4: 100% stock - totalled by an Illegal 2-12-08
95 Galaxy Pearl White Stealth TT: 11.852 @ 118.25 - sold
95 Emerald Green Pearl Stealth TT - Sold
95 SSG Stealth TT: 11.981 @ 115.81mph - sold
Nonstop Mixes by Monochrome
"I don't actually work on cars, I just talk about them on the internet."
Monochrome is offline   Reply With Quote
Old 08-03-2005, 11:41 AM   #3 (permalink)
Member #0711
defgh1's Avatar
Drives: 99 VR4, 04Volvo V70R
Trader Rating: (7)
defgh1 is an unknown quantity at this point
Originally Posted by eyeluvmy3kgt
I have an oil leak coming from the back of the block between the oil pump and the block about a cm above the oil pan. You guys think I just need to put a new oil pump gasket on and seal it up good? I'm dreading this job.
Yup, been there and had that. Pump is not completely sealed to block. I would first check all oil pump bolts are torqued to spec. If that does not correct it then it is the gasket.
Doug H
91 Sandstorm TT, 431 AWHP, 433 ft-lbs. , Kormex 25 spline,LSD, RPS CC Clutch, 4 bolt conversion, Super 15Gs, Stage 3 heads, DSM Sidemounts, PST Driveshaft, Blitz DSBS, HKS Exhaust, 3SX Downpipe, Supra Pump, 780 cc PTE Injectors, SX Fuel reg. & dual feed, AEM, Duel WJO Wideband, HKS DL1, Alcohol Injection. Photos: -->
defgh1 is offline   Reply With Quote
Old 08-03-2005, 12:25 PM   #4 (permalink)
Toni's Avatar
Trader Rating: (43)
Haha, its funny how I still find the time to drink at least 10 every night WITH girls I might add
Old 08-03-2005, 12:43 PM   #5 (permalink)
500hp daily driver
eyeluvmy3kgt's Avatar
Drives: a 17 year old VR4
Trader Rating: (15)
eyeluvmy3kgt is an unknown quantity at this point
Originally Posted by defgh1
Nice write-up. I would emphasize the importance of ensuring proper oil pump gasket alignment of the pump channels and block surface. Use of a small amount of gasket adhesive between the pump and gasket will help keep it aligned. If the gasket slips just a little or gets pinched during the install you will end up with a oil leak from the pump and you will have to start all over again.
Doug H
-Marshall
'91 VR-4 one of 293
Check out My Pics and "The Story of My Car" UPDATED 10/23/2007 with engine rebuild
Engine rebuild: Done! 8/07
Paint: Done! 11/07
Mods:
Wiseco +0.055" pistons, DR650R turbos, PTE 550cc injectors, Denso 310lph FP, Aeromotive AFPR w/ custom fuel lines, FP Hotwire, ATR downpipe, ATR catback, HKS SSQV, Apexi SAF-C, Apexi AVC-R, Apexi S-ITC, PST 2pc. CFDS, TEIN S spings, Fidanza flywheel, ACT clutch, Magnecore wires, 3SX control arms, speed bleeders, battery relocation, OZ Superleggera 18x9 wheels, Stewart Warner FP gauge, Scanmaster 3, MMcd, Kormex Tranny & T-case, Corbeau seats,
'92 Pearl White VR4 - Dad's ride
-mint condition, tein coilovers, racing hart wheels, hks IC's, tenabe exhast
18 spline t-case for sale $225 shipped FIRM. PM me
eyeluvmy3kgt is offline   Reply With Quote
Old 08-19-2005, 08:56 PM   #6 (permalink)
Fast6Performance
Project 3000GT's Avatar
Drives: 1995 3000GT MTX
Project 3000GT is an unknown quantity at this point
Here is a correction for you:
I just took mine off about 20 minutes ago and I did NOT have to remove the a/c compressor or the bracket holding the compressor on to remove the oil pump. I have a 1995 3000GT Base. Now, I'm going to go ahead and put my new timing belt on since I have so much shit torn apart anyways, but I've noticed that you WILL have to remove the motor mount bracket attached to the engine just to get the old timing belt off and the new one in there.
Project 3000GT is offline   Reply With Quote
Old 08-21-2005, 09:18 PM   #7 (permalink)
ddsmith's Avatar
Drives: 92 3KGT VR4, 71Vette
ddsmith is an unknown quantity at this point
On the VR4's you must at least remove the three bolts holding the A/C compressor in place so it can move far enough to get to the three oil filter adapter bolts. Two of which have holes in the A/C bracket to get to. The third one at the top has no hole and is a bitch to remove but can be done with an offset box wrench. The back of the VR4 oil pump has a groove which runs nearly all the way around the pump and returns back to the sump. This will allow most leaks to just recycle. The only problem area is on the firewall side of the pump because the groove stops before this area. You definately should apply some sort of sealer to this area. Here is a picture of the pump so people can see what I'm talking about. Thanks DoctorStupid for the picture. Hope you don't mind.
ddsmith is offline   Reply With Quote
Old 09-13-2005, 01:13 PM   #8 (permalink)
Drives: '91 Base
Trader Rating: (6)
eyebrowski is an unknown quantity at this point
Do the turbo and NTs use the oil pump/parts?
eyebrowski is offline   Reply With Quote
Old 11-24-2007, 10:12 PM   #9 (permalink)
1992 Stealth RT
jbavousett's Avatar
jbavousett Level 1jbavousett Level 1
Bringing back the dead...but do I need a puller for the timing belt pulley? I may be doing this soonish.
jbavousett is offline   Reply With Quote
Old 11-25-2007, 06:33 AM   #10 (permalink)
3000GT_Rider is an unknown quantity at this point
Nope slides right off
3000GT_Rider is online now   Reply With Quote
