LinkBack (1) Thread Tools
Old 11-20-2004, 08:14 AM   #81 (permalink)
Now with 100% more NSX
leet's Avatar
Drives: 95 NSX and 92 TT
Trader Rating: (24)
leet Level 2leet Level 2leet Level 2
Default Re: 1G Electronic Boost Data Logging
Originally Posted by cbatters
EGRT = Exhaust Gas Recirculator Temperature
And yes it is a easy/slick mod!
Clint
ok I thought it had something to do with EGR, which is good since I don't have that anymore
the stealth is officially for sale, PM for info
leet is offline   Reply With Quote
Old 11-20-2004, 08:30 AM   #82 (permalink)
leet's Avatar
Trader Rating: (24)
I found where to order the 2.5bar digikey sensor online, no icky PDF files
http://www.digikey.com/scripts/DkSea...0AP-ND&Site=US
total cost is 18.19 + shipping
Old 07-21-2005, 06:54 PM   #83 (permalink)
Paid Member
Jomojr's Avatar
Drives: 1993 TT ATX w/TT ECU
Jomojr Level 1Jomojr Level 1
Im using a scanmaster three, and MMCD. I have the MAP sensor installed to show boost on the scanmaster3. It is working correctly. I have gone into the setting in MMCD and set it to 3.0 BAR. When looking at mmcd while logging it reads correctly as boost. But when I use the MMCD tool to create an excel file, the boost is only displayed as a temperature.
Im all new to this, and have been searching for three days 8(
Please help this noob out 8)
1993 GT TTATX
Pimpin the TT-ECU and NA-TCU Baby!
Link to Pics Vids and Info
3SX FANBOY
Jomojr is offline   Reply With Quote
Old 07-21-2005, 07:01 PM   #84 (permalink)
No loer a Noob?
skunkworks's Avatar
Drives: low impedance inputs
Trader Rating: (9)
skunkworks is an unknown quantity at this point
You have to do it manually off of the raw egrt sensor data.
This is from clint (cbatters)
3 BAR
BAR = (ADC * 0.0117647) + .1
PSI = (ADC * 0.170632588) - 13.0534
2.5 BAR
BAR = (ADC * 0.0098039) +.1
PSI = (ADC * 0.142193511) - 13.0534
2.0 BAR
BAR = (ADC * 0.0078431) +.1
PSI = (ADC * 0.113755059) - 13.0534
Wideband (0-255 counts = 10-20 AF)
AF = (ADC * .03921569) + 10
92 Stealth R/T TT - 13t's Installed. note:Is the machining right? - boosting to 15psi so far.
Do I do this for others? No. robbeck is your man.... We know his work
skunkworks is offline   Reply With Quote
Old 10-03-2005, 09:52 PM   #85 (permalink)
Drives: 94 VR4
Trader Rating: (19)
Blue94VR4 is an unknown quantity at this point
Hi,
I've studied this thread and one question was left unanswered for me. Can anyone help me out?
I have 94 VR4 (hybrid ECU) Cali spec. My car came stock with EGR valve and sensor. I also have Autometer electronic boost gauge, just like Black94TT.
I did vacuum reduction mod and I removed EGR valve and EGRT sensor. However, in order to avoid CEL I had to install 10 Ohm resistor in place of EGRT. This tricks ECU into thinking that EGR system is working.
Questions
1. Clint, you've mentioned earlier that output of Autometer Map sensor is low. I measured 18 KOhms. Does it sound right to you?
2. Can I still connect output signal of Autometer Map sensor to the signal wire of EGRT? I am worried about 10 Ohm resister that's already there. Will it introduce errors for Autometer gauge or data logger?
3. What is the voltage range I can expect from Autometer Map sensor? Is it 0 - 5v?
Thanks,
Sergey
Blue94VR4 is offline   Reply With Quote
Old 10-04-2005, 05:28 AM   #86 (permalink)
Member: Burned valve club
cbatters's Avatar
Drives: 91 Stealth RT/TT
Trader Rating: (12)
cbatters Level 2cbatters Level 2cbatters Level 2
Originally Posted by Blue94VR4
Hi,
Questions
Thanks,
Sergey
1. You can't directly measure output resistance. Instead, you add a load to the output and measure the attenuation in the signal due to the load. For example, if you connected a 1K resistor and the output voltage went down by 50%, it would mean that the output has a 1K impedance.
2. You cannot use the EGRT input with the 10 ohm resistor attached. The 10 ohm resistor simulates a fairly high EGR temp (low voltage) to keep the CEL light from coming on.
However, the output of the MAP sensor is a fairly low voltage when the engine is under vacuum and may suffice to keep the CEL from coming on. (I have no idea of the logic used to trigger the EGRT CEL)
3. Most MAP sensors put out a 0 - 4.85 V signal. I am not 100% sure but I believe the Autometer is actually a 3.5 bar or 4.0 bar sensor.
If you post voltage/pressure with engine off and with engine on, we can calculate the scale.
Note: MMCd includes the option for displaying EGRT signal as a voltage .
Clint
Maint: Castrol 10W40 / Mitsu Filter / Rislone
Replaced: 2X clutch / 3X brakes / 2X front rotors / 2X ABS HU / 1X NGK Plugs / 1X Ball joints / 2X Antenna mast / 1X Active exhaust cable / 1X Windshield / 1X Fuel FIlter / 1X Struts / 1X rear rotors / 1X Front Head / VSS / 1X rear wheel bearings / 1X Transfer case (warranty) / 1x Tie rod end (drivers side)
Overhauled: Starter, IAC, BISS, CV Boots
Upgrade: SilverStar Headlights / ebay "Xenon" Fog Bulbs (no more yellow!)
A/F Gauge / MAP - Electronic Boost Logging / MMCd Data Logger
Pending Projects: Steering Rack
cbatters is offline   Reply With Quote
Old 10-04-2005, 07:45 PM   #87 (permalink)
Drives: 94 VR4
Trader Rating: (19)
Clint,
I realized I did the measurement wrong. New number are
w/ engine off - 2.2V
w/ engine idling - 0.6V
This looks like 2.5 bar sensor to me. Am I correct?
Thanks,
Sergey
94 3000GT VR4 (upgraded)
"Your 1994 Mitsubishi 3000GT VR-4 is one of 1650. There are 57 other cars that were made with both the same interior and exterior color. Exactly Identical - 8"
For sale:
1. Front strut bar
2. used A/C belt (10K on the belt)
3. Stock front and rear sway bars.
4. 3SX dual O2 simulator
5. Used 2'' couplers/reducers/hump hoses
Old 10-05-2005, 05:11 AM   #88 (permalink)
cbatters's Avatar
Trader Rating: (12)
Clint,
Thanks,
Sergey
Saw the other numbers and could not hazard a guess. Those numbers look like the 2.5 bar sensor (you just happen to have the probes reversed.)
Assuming your boost gage was wired using the ECU signal ground for Ground, all you need to do is run a single wire over to the EGRT connector and remove the resistor to give it a whirl.
Clint
Old 10-05-2005, 08:52 AM   #89 (permalink)
Drives: 94 VR4
Trader Rating: (19)
Thanks Clint,
I'll remove 10 ohm resistor and I'll give it a try. I did not use ECU ground for my gauge, just regular one. Where can I connect it to ECU ground? Any particular location? What is ECU ground anyway? Is not ECU connected to the car body as well? When I installed my gauge, there was no mention of ECU ground in Autometer's instructions.
Sergey
Old 10-05-2005, 08:59 AM   #90 (permalink)
cbatters's Avatar
Trader Rating: (12)
Thanks Clint,
I'll remove 10 ohm resistor and I'll give it a try. I did not use ECU ground for my gauge, just regular one. Where can I connect it to ECU ground? Any particular location? What is ECU ground anyway. Is not ECU connected to the car body as well?
Sergey
I believe there is a discssiion about "grounds" in the boost logging thread. All of the ECU ininputs are single ended inputs referenced to ECU ground. Gages and other onboard instrumentation should use the ECU signal ground.
(There can easily be 10-100 mV of difference between the various "grounds" on the car that would show up as an error in the boost signal. Ground-loops are formed when you attempt to connect two "grounds" together that are at different potentials causing current o flow.
Quick / fun step is to remove resistor and connect a single wire between MAP signal and EGRT input. Very initerestinig to learn if MAP signal is low enough to satisfy the EGRT and keep it from throwing a CEL.
Clint
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f58/1g-electronic-boost-data-logging-202062/
Posted By For Type Date
Boost Logging This thread Refback 04-13-2008 10:49 PM
