Old 11-04-2004, 04:18 AM   #71 (permalink)
Member: Burned valve club
cbatters's Avatar
Drives: 91 Stealth RT/TT
Trader Rating: (12)
cbatters is an unknown quantity at this point
Default Re: 1G Electronic Boost Data Logging
Originally Posted by Kuato
I have the sensor teed with my boost gauge line to the back of the plenum.
I did a leak test, and everything is tight...
1. Confirm that you have +5V to sensor
2. Change MMCd to English to see units in PSI.
Clint
Maint: Castrol 10W40 / Mitsu Filter / Rislone
Replaced: 2X clutch / 3X brakes / 2X front rotors / 2X ABS HU / 1X NGK Plugs / 1X Ball joints / 2X Antenna mast / 1X Active exhaust cable / 1X Windshield / 1X Fuel FIlter / 1X Struts / 1X rear rotors / 1X Front Head / VSS / 1X rear wheel bearings / 1X Transfer case (warranty) / 1x Tie rod end (drivers side)
Overhauled: Starter, IAC, BISS, CV Boots
Upgrade: SilverStar Headlights / ebay "Xenon" Fog Bulbs (no more yellow!)
A/F Gauge / MAP - Electronic Boost Logging / MMCd Data Logger
Pending Projects: Steering Rack
cbatters is offline   Reply With Quote
Old 11-04-2004, 07:09 AM   #72 (permalink)
Drives: '91 VR4
Trader Rating: (23)
Kuato is an unknown quantity at this point
I'm reading 4.97v to the sensor. After changing the units to psi, I got the following
E-01 Idle -7psi Full Boost 14.5psi
MMCD Idle -3.3, -4psi Full Boost 9.1,9.6psi
EIII 16G's, DR Street cams, DR Stg III Heads, 4" single shot, FMIC, SPEC Stage III, ek2 x-cage, solid mounts, FIC 750's, W/M inj, AEM ems
Kuato is offline   Reply With Quote
Old 11-18-2004, 05:57 AM   #73 (permalink)
cbatters's Avatar
Trader Rating: (12)
SAMCO/SKUNKWORKS
Changed injectors with a set that I had cleaned/flow tested and the problem we were fighting with low O2 voltage on one bank under under light load immediately went away. Sending out the old injectors now to confirm that there was a flow problem on one or more of the rear injectors.
Still fighting some knock issues that I believe are related to excess oil from valve stem seals that lower the effective octanne of the fuel. (I got a repreive when I used an additive that is supposed to help swell the valve stem seals. Was pleasantly surprised that the knock is almost completely gone. Permanent solution is obviously to replace the VSS which I am planning to do some time over the holidays.)
I don't recall if you ever tried changing the injectors when you wre fighting the same problem. I may have an extra set of cleaned/flow tested injectors available shortly.
Clint
Old 11-18-2004, 10:53 AM   #74 (permalink)
No loer a Noob?
skunkworks's Avatar
Drives: low impedance inputs
Trader Rating: (9)
skunkworks is an unknown quantity at this point
my problems with the low o2s are all but gone - I have to try really hard to get it to do it. This was all but fixed with a new fuel pump, fuel pressure regulator and fuel pump rewire. The car has been running wonderfully except for the knock. It seems to be random but like you have mentioned that the longer you run it with low manifold pressure(vaccume) the worst the knock is when accellerating after. again WOT sees no knock.
I think you are on the right track - my car has 122000 miles on it and i have a little bit of oil in the intake track and I am sure I am getting it though the vss.
This would be my dream - dr stage II heads - dr 500 turbos and new dsm injectors with some sort of fuel controller. kind of an expenive intake oil leak fix but what the heck. new vss, turbo seals and injectors with 3rd gen lifters. unlike yours mine are quite loud at least twice a week. I have new rod bearings and oil pump so I hope my bottem end will last a while longer. over 10000 miles sense the install.
sam
btw - I did replace the injectors with some used one from here. It didn't help the knock and my low o2s - but I had to take them out because everyone of them leaked at the seam between the plastic and the metal. I think they just sat too long without being used.
sam
92 Stealth R/T TT - 13t's Installed. note:Is the machining right? - boosting to 15psi so far.
Do I do this for others? No. robbeck is your man.... We know his work
skunkworks is offline   Reply With Quote
Old 11-18-2004, 12:29 PM   #75 (permalink)
cbatters's Avatar
Trader Rating: (12)
sam
sam
Three things:
1. When you say leak are you referring to a fuel leak on the injectors or an air leak betwen the injector and the intake manifold. (My old injector/manifold bushings were as hard as rocks.)
2. I should end up with a set of serialized/cleaned/flow tested injectors shortly if you want to try them. Day/night difference on my rear O2. (I have a switch on the fuel resistor bypass so I can easily change it back to stock and see if the O2 votlage is still good at luight throttle.)
3. Small amount of oil on intake tract is from turbo seals and crankcase gasses venting into intake during WOT. Oil leaking from bad VSS gets sucked directly into combustion chamger during intake stroke and directly into manifold at the end of the exhaust stroke.
Clint
Old 11-18-2004, 12:42 PM   #76 (permalink)
No loer a Noob?
skunkworks's Avatar
Trader Rating: (9)
Originally Posted by cbatters
Three things:
If you remember what your injectors look like they are metal top (where the go into the fuel rail) and bottom (where the go into the intake). In between there is a plastic piece sandwitched (where the plug is). every one of the used ones I bought where leaking from between the metal and the plastic. I figured it was because they had not been used for a long time and maybe the plastic changed shape(dried out - I don't know).
If they could fix my used injector I have a set too. As I stated above they leak from the body. well I should say I have 5 - I tried to take one apart to see if I could . I am not really worried right now about my injectors because my o2s look good and my hesitation is gone. I am more worried about the knock - the knock usually only happens when the o2s are cycleing normally. I don't think I have ever gotten knock when the o2s would dip for a second (when I used to get a hesitation).
BTW - I have a switch wired in too
Clint
Right now I have my rear valvecover vented to the atmoshire to see if I was still getting oil out of the rear intercooler line. I still am. So for sure my rear turbo is leaking a little bit. and I am sure I am getting vss oil into the combustion chamber.
I don't seem to smoke much though
sam
edit - thanks for the offer
Old 11-18-2004, 01:08 PM   #77 (permalink)
cbatters's Avatar
Trader Rating: (12)
Weird failure mode on the injectors. Have never heard of them leaking at that seam. I assumed that the injector was just pressed together with no seals or o rings. I have never taken one apart so I have no idea what they look like inside. (Shoot some pics if you get one apart.)
KNOCK
The knock that used to bother me was transitioning from light throttle at 3500-4000 RPM to WOT. With the new injectors and some oil additives, I am only getting 3-4 knock occasionally and a lot more pull. (Anxious to replace VSS to see if it gets rid of oil smell at idle, oil consumption and knock. I also think my plugs are burning whiter / hotter because of the VSS oil.)
Matter of fact, the car is pulling so much better now that I will need to move "new clutch" to the top of my priority list.
Clint
Old 11-18-2004, 01:25 PM   #78 (permalink)
No loer a Noob?
skunkworks's Avatar
Trader Rating: (9)
KNOCK
Clint
My knock is usually below 3000 rpm like pulling away from a stop or speeding back up after turning down a sideroad. I get less knock if I keep the car in a lower gear and rev higher. Like I have said before I get no knock at wot
Old 11-20-2004, 08:02 AM   #79 (permalink)
Now with 100% more NSX
leet's Avatar
Drives: 95 NSX-T
Trader Rating: (24)
leet Level 1leet Level 1
I have a few questions just to make sure I read all of this right
What is EGRT
All I have to do is take the one wire from the middle plug (of the 3 plugs on the plenum) and splice it into the TPS wire, then wire the other 2 into the MAP sensor, then set the thing on MMCd to 3bar (or whatever size) and that's it?
is there any other wiring then those 3 wires?
this seems like a really cool, really useful simple mod, I am going to do this if it really is that easy
*edit*
ok I did read it wrong, 2 of the wires off of the middle plug go to the MAP sensor, then splice the third wire to the TPS sensor
I think I got it now, but some reassureance would be nice
the stealth is officially for sale, PM for info
leet is offline   Reply With Quote
Old 11-20-2004, 08:13 AM   #80 (permalink)
cbatters's Avatar
Trader Rating: (12)
What is EGRT
*edit*
EGRT = Exhaust Gas Recirculator Temperature
And yes it is a easy/slick mod!
Clint
