Old 08-22-2004, 06:02 AM   #61 (permalink)
Beer is good for you!
Beer's Avatar
Drives: 3000GT VR-4
Beer is an unknown quantity at this point
Default Re: 1G Electronic Boost Data Logging
Im thinking about connecting my el. greddy boost gauge sensor to the egtr wire. As this gauge reads to 2kpa, it shoud have 3bar map sensor, am i right? The sensor gets its ground and + from the gauge, so if i just tap into its sensor wire and connect it to the egtr sensor wire it should work?
Beer.
Eurospec VR-4 '94
Beer is offline   Reply With Quote
Old 08-22-2004, 07:51 AM   #62 (permalink)
Member: Burned valve club
cbatters's Avatar
Drives: 91 Stealth RT/TT
Trader Rating: (12)
cbatters is an unknown quantity at this point
Should work like a champ... (as per paragraph at start of post for existing boost sensors.)
Maint: Castrol 10W40 / Mitsu Filter / Rislone
Replaced: 2X clutch / 3X brakes / 2X front rotors / 2X ABS HU / 1X NGK Plugs / 1X Ball joints / 2X Antenna mast / 1X Active exhaust cable / 1X Windshield / 1X Fuel FIlter / 1X Struts / 1X rear rotors / 1X Front Head / VSS / 1X rear wheel bearings / 1X Transfer case (warranty) / 1x Tie rod end (drivers side)
Overhauled: Starter, IAC, BISS, CV Boots
Upgrade: SilverStar Headlights / ebay "Xenon" Fog Bulbs (no more yellow!)
A/F Gauge / MAP - Electronic Boost Logging / MMCd Data Logger
Pending Projects: Steering Rack
cbatters is offline   Reply With Quote
Old 08-24-2004, 02:03 PM   #63 (permalink)
Beer's Avatar
Drives: 3000GT VR-4
No good. The sensor itself is working, but the readings are incorrect. I tried chosing all 3 types of map sensors and none of them read correctly. The 2bar seting is nearest to the truth, when the gauge shows 0 kgcm, mmcd reads 0.81 bar, after starting the motor, gauge reads 500mmhg, mmcd 0.49 bar. When trying to chose bigger map sensor in preferences, reading increase more.
Is there any way to customize egtr reading?
Anyone else actually tried connecting greddy boost gauge sensor to egtr?
Old 08-24-2004, 02:40 PM   #64 (permalink)
cbatters's Avatar
Trader Rating: (12)
Not even close - should be 1.0 bar with engine off (assuming you are near sea-level) and more like .35 bar at idle.
With ignition on but engine not running please provide the following measurements with a DVM so we can figure out what is going on.
Ground Difference ________ Volts
Red Lead - MAP Sensor GND
Black Lead - A22-GND
Sensor Output _________ Volts (engine off)
Red Lead - MAP Sensor Signal
Black Lead - MAP Sensor GND
And sensor voltage at idle.
Sensor Output _________ Volts (Idle)
Old 10-12-2004, 08:44 PM   #65 (permalink)
Drives: '91 VR4
Trader Rating: (23)
Kuato is an unknown quantity at this point
Question Re: 1G Electronic Boost Data Logging
Is this Greddy sensor the same one that the E-01 uses? Any luck with it?
EIII 16G's, DR Street cams, DR Stg III Heads, 4" single shot, FMIC, SPEC Stage III, ek2 x-cage, solid mounts, FIC 750's, W/M inj, AEM ems
Kuato is offline   Reply With Quote
Old 10-13-2004, 05:42 AM   #66 (permalink)
cbatters's Avatar
Trader Rating: (12)
Unfortunately, "Beer" was involved in a fatal car accident... a moment of pause for all of us to enjoy the cars but drive responsibly....
Clint
Old 10-13-2004, 07:38 AM   #67 (permalink)
Drives: '91 VR4
Trader Rating: (23)
Unhappy Re: 1G Electronic Boost Data Logging
Well.. that is unfortunate. Anyway, I'll try using the Greddy pressure sensor this weekend and post the results.
Old 11-03-2004, 08:07 PM   #68 (permalink)
Drives: '91 VR4
Trader Rating: (23)
Finally got off my ass and plugged the Greddy sensor to the A22. Here are the results:
"With ignition on but engine not running please provide the following measurements with a DVM so we can figure out what is going on.
Ground Difference 0.012 Volts
Sensor Output 1.489 Volts (engine off)
Sensor Output 1.200 +/- .060 approx Volts (Idle)
Black Lead - MAP Sensor GND"
With the setting on 3BAR, mmcd was reading .84bar at idle- the E-01 was reading from -5 to -7 psi.
Any thoughts?
Old 11-03-2004, 08:48 PM   #69 (permalink)
cbatters's Avatar
Trader Rating: (12)
Any thoughts?
Bad vac line connection / dead sensor or dying engine! Should be ~.5 V at idle assuming -10 PSI of vacuum.
Clint
Old 11-03-2004, 09:26 PM   #70 (permalink)
Drives: '91 VR4
Trader Rating: (23)
I have the sensor teed with my boost gauge line to the back of the plenum.
I did a leak test, and everything is tight...
