#131 (permalink) | |
Also could not find data identifying bar range of DSBC. Surprised you didn't do it - seems going with the GM sensor while already having an EBC is being a glutton for extra work.I will attempt it within the week and let you know how it works out.
91 AWD TT
K&N, Exhaust upgrade, Blitz DSBC, Steel braided brake lines, Aluminum pulley, Vacuum reduction, Egr block off, Tirerack Wheels ![]() Scanmaster 3 installed - now I need to figure out what it all means , Palm M515 LoggerTo do list: Gut the cats - fix the friggin antenna that won't retract ![]() Revel in your time Last edited by Roybatty : 12-31-2007 at 04:17 PM. |
#132 (permalink) |
This didn't work out for me yet - I need to check on my wiring. I attached the EGR light green input wire to the white wire between the solenoid and blitz control. Set the scanmaster expanded mode to allow EGR input retrieve boost data and data subsititution egr to boost, and the scanmaster only shows 23.2 the entire time its on- no matter what boost the blitz shows.
#133 (permalink) | |
Yank in Yorkshire
![]() My first-gen AVC-R (installed in 1997!) uses a Denso 3 bar MAP sensor with 5 VDC output (DPS-310-2000A 949940 6270 5V, blue wire is signal), but it apparently represents vacuum and pressure at voltages slightly higher than the sensor(s) for which the MirageCorp Hybrid logger is calibrated. For example (voltmeter = AVC-R display = datalogger display): Ignition on, engine off 2.08 VDC = 0.00 kg/cm^2 = +4.86 psi Warm idle 1.10 VDC = -485 mmHg (-9.36 psi) = -3.7 psi AVC-R limiting boost 0.8 kg/cm^2 (11.38 psi) = 15.4 psi 0.9 kg/cm^2 (12.80 psi) = 16.6 psi 1.0 kg/cm^2 (14.22 psi) = 17.8 psi 1.1 kg/cm^2 (15.65 psi) = 19.0 psi Here is a chart representing all of the data I collected: ![]() So this Denso sensor's range for positive boost is 2.079 - 5.0 VDC while the hybrid logger software seems to expect more like 1.52 - 5.0 VDC. z = voltage logger expects at zero boost s = scaling factor At zero pressure, my sensor outputs 2.08 VDC and the logger displays 4.86 psi. (2.08 - z) * s = 4.86 s = 4.86 / (2.08 - z) Under warm idle vacuum, my sensor outputs 1.10 VDC and the logger displays -3.7 psi. (1.10 - z) * s = -3.7 s = -3.7 / (1.10 - z) 4.86 / (2.08 - z) = -3.7 / (1.10 - z) 4.86 * (1.10 - z) = -3.7 * (2.08 - z) 5.346 - 4.86z = -7.696 + 3.7z 8.56z = 13.042 z = 1.52 Anyway, unless someone has a better idea, I'm adjusting offset and scale (translating 4.8 - 19 to 0 - 15.65) as follows: (logged boost - 4.86) * (15.65 / (19 - 4.86)) (logged boost - 4.86) * 1.1068 BTW, one side of a slightly collapsed female crimp connector slips snugly over the pin: ![]()
Jim Matthews - Yorkshire, England, UKTeam3S, 3SI #30, GTOUK #155 http://www.the-matthews.com/stealth.html Jet Black '94 Dodge Stealth R/T Twin-Turbo AWD AWS 6-spd Active Suspension Damping, Ek2MFG dual-flex downpipe, Zorstec custom SS cat-back dual A'PEXi Super AVC-R Mk-I, MHI TD04L-13Gs, K&N FIPK, IPS SS Y-pipe A'PEXi Super AFC 5-knob, 450cc Black Tops, MirageCorp Logger Mobil 1 & Redline fluids, Hotwired Denso 1020 Pump, IPO/SX AFPR SCE 332x32/322x28 cryoed StopTechs, Wilwood proportioning valves Winter: stock alloys 17x8.5-46, Hankook Icebear W300 235/45VR17 Summer: Enkei RPM2 17x9-40, Yokohama AVS ES100 245/45ZR17 Track: Enkei RPM2 17x9-40, Yokohama A-032R Hcomp 275/40R17 My reliable daily driver since Feb 1997! ![]() Last edited by bjmsam : 01-27-2008 at 05:50 AM. Reason: added chart |
#134 (permalink) |
Hi Jim,
I may have missed something, but what are you calibrating the logger against? I see the 'Engine off' state, and I suppose you could note the barometric pressure in your driveway at the same moment to get one datapoint, but where's your second 'known value' in the scale? Seems like you'd need a stable (non-fluctuating) vacuum source with an external vacuum gauge to provide the next datapoint. -Mike |
#135 (permalink) |
Yank in Yorkshire
Hey Mike,
I've been wondering about the influence of barometric pressure as well. The gauge on my boost controller does not always read 0.00 with the engine off, but it did both yesterday and today. My weather station currently reads 1036 hPa, which is 15.02591 - 14.50377 = 0.52214 psi high. I can't calibrate the boost controller or the logger; all I've done is compare the pressure displayed on the boost controller to the pressure displayed on the logger and come up with a translation function to apply when I get home. Last edited by bjmsam : 01-27-2008 at 07:05 AM. Reason: converted hPa to psi |
#136 (permalink) |
Hi Jim,
That's interesting too, but that's not what I mean. It seems like you are trying to come up with a formula to apply to the voltage readouts on your logger that will translate into accurate pressure/vacuum numbers. It also seems that the sensor you're grabbing the data from is providing data at a different scale from the sensor you were using previously. What I'm suggesting is to calibrate your scale (using math - I understand the gauge isn't adjustable.) You know the voltage readout at atmospheric pressure (1036 hPa a few minutes ago), but I don't see where you're checking the gauge against a second datapoint (preferably at the other extreme - near full vacuum.) This would give you a volts/hPa scale for the new sensor, completely bypassing any error introduced by previous sources. Just my .02, -Mike |
#137 (permalink) |
Yank in Yorkshire
I am able to measure voltage only while the car is at rest, but I tried to record enough samples (plotted in blue) to verify that they are interpreted as expected (the ECU converts the sensor output to an 8 bit number (0-255) which the logger looks up in a linear table to report pressure). All of the pressure datapoints I collected are plotted in yellow and range from full vacuum (where I could glance at the gauge and logger and jot down the values) to full boost (where I could set the limit and know the gauge reading for later comparison with the logs). None of the data is adjusted to account for baro since I don't know whether the readings are absolute or relative.
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f58/1g-electronic-boost-data-logging-202062/
| Posted By | For | Type | Date | |
| Boost Logging | This thread | Refback | 04-13-2008 10:49 PM | |
| Thread Tools | |
