LinkBack (1) Thread Tools
Old 04-09-2007, 05:11 PM   #121 (permalink)
Drives: 94 VR4
Trader Rating: (19)
Blue94VR4 is an unknown quantity at this point
Default Re: 1G Electronic Boost Data Logging
I have Cali hybrid and I log boost with Shiver's logger.
94 3000GT VR4 (upgraded)
"Your 1994 Mitsubishi 3000GT VR-4 is one of 1650. There are 57 other cars that were made with both the same interior and exterior color. Exactly Identical - 8"
For sale:
1. Front strut bar
2. used A/C belt (10K on the belt)
3. Stock front and rear sway bars.
4. 3SX dual O2 simulator
5. Used 2'' couplers/reducers/hump hoses
6. SPEC II+ clutch
Blue94VR4 is offline   Reply With Quote
Old 04-09-2007, 07:09 PM   #122 (permalink)
Wanted: Traction Problems
badass3000's Avatar
Drives: 18 Y.O. "badass" VR4
Trader Rating: (20)
badass3000 Level 4badass3000 Level 4badass3000 Level 4badass3000 Level 4badass3000 Level 4
Originally Posted by DoctorDex
Dumb question here for you guys.
At the moment I have a fed spec. ecu, however my ECU is shot so I need a new one. Problem is, the only one I seem to be able to find for a decent deal is a cali spec ecu. I realize a cali spec should work in my car, however, will I be unable to log boost after installing it?
what happened to your ECU?
badass3000 is offline   Reply With Quote
Old 04-09-2007, 08:35 PM   #123 (permalink)
badass3000's Avatar
Trader Rating: (20)
hope that fixes our problem
Old 04-10-2007, 06:14 PM   #124 (permalink)
Drives: '91 VR4 - RIP
Trader Rating: (14)
According to stealth316.com, I believe the terminal assignments and pin outs are the same for cali spec vs. fed spec. ecus. However, with cali spec ecus, the pin EGRT (a-22 connector) needs to see 2.2 - 3.0V to avoid a CEL.
Does anybody know what range of voltages the MAP sensor puts out?
Edit Nevermind. I'm going to just hang tight for a fed spec ecu. From what I gather other members haven't faired too well trying to swap a 1st gen cali spec into a 1st gen fed spec.
Old 09-20-2007, 06:24 AM   #125 (permalink)
Automotive Geek
Drives: 1993 3000GT VR-4
SpikeyGG is an unknown quantity at this point
Anyone know of a different source for +5V than the TPS? I'd like to tap into it somewhere a little less conspicuous. I'm getting my boost sensor this weekend.
Thanks,
-Greg
93 VR-4 K&N FIPK, Eibach Pro Sport springs, MSD 8.5mm wires, NGK iridium plugs, solid polyurethane motor mounts, Sumitomo HTR+ tires, gutted precats, adjustable rear control arms, 99 lifters, underhood and console shifter bushings, aluminum dash vents, clutch vacuum assist delete, GM boost logging, full set of Defi gauges. Always a work in progress...
SpikeyGG is offline   Reply With Quote
Old 09-20-2007, 06:42 AM   #126 (permalink)
Trader Rating: (14)
On 1st gen's:
ECU Pin 52 - intake air temp sensor
ECU Pin 61 - TPS, IPS, Baro, IAT
ECU Pin 63 - Engine coolant sensor
ECU Pin 67 - Throttle position switch
ECU Pin 70 - Air Flow Sensor
Old 09-22-2007, 06:31 PM   #127 (permalink)
Automotive Geek
Thumbs up Re: 1G Electronic Boost Data Logging
Originally Posted by DoctorDex View Post
On 1st gen's:
Thanks double D, I tapped the +5V off the Air Flow Sensor... Got it installed, and now I'm logging boost, sweet!
I've done a few pulls since the install and it looks like the stock setup keeps map fairly stable at 9lbs +/- 1lb though it also appears to have a some overshoot hitting 11lbs around 3400rpm. Is this normal?
Also, got any tips for a noob: are there any good indicators of a boost leak or boost problems?
-Greg
Old 09-23-2007, 10:04 AM   #128 (permalink)
Trader Rating: (14)
This is a bit off topic, but here it goes:
Do you have a stock boost gauge? If so, you'll see your boost according to that gauge is going higher than it should. Other indicators would be going extremely rich while boosting or it bogging under boost.
Another good indicator is a pressure test.
Some places that are pretty much guaranteed to be leaking are your throttle body shaft o-rings, BISS screw, stock BOV and maybe your y-pipe (if you still have the stocker).
Old 12-31-2007, 07:47 AM   #129 (permalink)
Roybatty's Avatar
Drives: like gas is cheap
Roybatty is an unknown quantity at this point
Some noob type questions for you guys:
1. I currently run my LC-1 wideband into the scanmaster by means of a 3.5mm stereo jack. Does this mean I am already using the EGRT input or can I go ahead and connect a MAP sensor to the extra EGRT input?
2. I have a Blitz DSBC. Is there a way to tap into the electronic boost gauge of boost controller and wire it into the EGRT?
Thanks.
Declan
Declan - did you tie in your Blitz DSBC to the EGRT input? I am going to attempt this - but wasn't sure if it would work or not. Also - I found out from Gerl's website that the Blitz DSBC is 2.5 bar max.
91 AWD TT
K&N, Exhaust upgrade, Blitz DSBC, Steel braided brake lines, Aluminum pulley, Vacuum reduction, Egr block off, Tirerack Wheels
Scanmaster 3 installed - now I need to figure out what it all means, Palm M515 Logger
To do list: Gut the cats - fix the friggin antenna that won't retract
Revel in your time
Roybatty is offline   Reply With Quote
Old 12-31-2007, 02:29 PM   #130 (permalink)
Trader Rating: (14)
Originally Posted by Roybatty View Post
Declan - did you tie in your Blitz DSBC to the EGRT input? I am going to attempt this - but wasn't sure if it would work or not. Also - what is the Blitz DSBC - 2.5 bar or 3 bar? Please advise when you can - thanks RB
I never ended up trying it. I found a GM sensor for a good price, so I just used it instead. However, I am looking at revisiting this idea now that the GM sensor has crapped out on me.
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f58/1g-electronic-boost-data-logging-202062/
Posted By For Type Date
Boost Logging This thread Refback 04-13-2008 10:49 PM
