Old 07-11-2006, 11:18 AM   #111 (permalink)
og
chansigril's Avatar
Drives: 93 stealth rt tt
Trader Rating: (43)
chansigril is an unknown quantity at this point
Default Re: 1G Electronic Boost Data Logging
http://rdmelton.autoeducation.com/ca.../boostlog.html
this is a great writeup, thanks
93 stealth r/t tt: mildly modified, 12.4@109
94 stealth r/t na: used to drive, 13.9@100
03 ford focus se: beater
chansigril is offline   Reply With Quote
Old 07-11-2006, 11:19 AM   #112 (permalink)
No loer a Noob?
skunkworks's Avatar
Drives: low impedance inputs
Trader Rating: (9)
skunkworks is an unknown quantity at this point
Originally Posted by chansigril
92 Stealth R/T TT - 13t's Installed. note:Is the machining right? - boosting to 15psi so far.
Do I do this for others? No. robbeck is your man.... We know his work
skunkworks is offline   Reply With Quote
Old 07-11-2006, 12:03 PM   #113 (permalink)
og
chansigril's Avatar
Trader Rating: (43)
Originally Posted by skunkworks
fixed, thanks i got lazy
Old 07-11-2006, 12:11 PM   #114 (permalink)
No loer a Noob?
skunkworks's Avatar
Trader Rating: (9)
it is a very good writup - I like how the first picture on the page is from my car. make me feel special.
Old 07-12-2006, 09:33 AM   #115 (permalink)
Drives: '91 VR4
Trader Rating: (13)
Some noob type questions for you guys:
1. I currently run my LC-1 wideband into the scanmaster by means of a 3.5mm stereo jack. Does this mean I am already using the EGRT input or can I go ahead and connect a MAP sensor to the extra EGRT input?
2. I have a Blitz DSBC. Is there a way to tap into the electronic boost gauge of boost controller and wire it into the EGRT?
Thanks.
Declan
'91 VR4 - Modlist: DR650R turbos, Snow stage 2D alky kit, DSM SMICs, blowthrough ported LT1 MAS, Dejon Tool intakes & y-pipe, Blitz DSBC Spec R, HKS SSQV BOV, PTE 580cc injectors, Dual feed fuel system with Aeromotive FPR & filter, Hotwired Supra pump, ek2mfg plenum spacer, HKS DLI, MSD Wires, Apex'i S-AFC II, MAFTranslator, Turbobob ECU, Scanmaster III, LC-1 WBO2, ESP downpipe, Vac/EGR delete, Gutted precats and test pipe, Maximal solid mounts, 300m 18 spline output shaft, Centerforce Dual Friction clutch, RPS flywheel, GC coilover conversions with helper springs, Powerslot slotted rotors, Goodridge SS brake lines, Hawk pads (front), Stillen metal matrix pads (rear)
Old 07-12-2006, 10:04 AM   #116 (permalink)
Member: Burned valve club
cbatters's Avatar
Drives: 91 Stealth RT/TT
Trader Rating: (12)
cbatters is an unknown quantity at this point
Thanks.
Declan
Kindly take the time to carefully read page 1 of this thread which describes hooking up devices to EGRT input.
Maint: Castrol 10W40 / Mitsu Filter / Rislone
Replaced: 2X clutch / 3X brakes / 2X front rotors / 2X ABS HU / 1X NGK Plugs / 1X Ball joints / 2X Antenna mast / 1X Active exhaust cable / 1X Windshield / 1X Fuel FIlter / 1X Struts / 1X rear rotors / 1X Front Head / VSS / 1X rear wheel bearings / 1X Transfer case (warranty) / 1x Tie rod end (drivers side)
Overhauled: Starter, IAC, BISS, CV Boots
Upgrade: SilverStar Headlights / ebay "Xenon" Fog Bulbs (no more yellow!)
A/F Gauge / MAP - Electronic Boost Logging / MMCd Data Logger
Pending Projects: Steering Rack
cbatters is offline   Reply With Quote
Old 07-15-2006, 08:57 AM   #117 (permalink)
Drives: '91 VR4
Trader Rating: (13)
Maybe I should have rephrased my question a bit better. Here it goes:
If I have my wideband plugged into the 3.5mm external analog signal stereo jack, does the Scanmaster output it to MMCd via the unused "EGRT output"? What I'm worried about is that if I get everything wired up, only to realize that the Scanmaster is pushing out two signals on one channel, so to speak.
Edit: After reading the scanmaster manual, I have come to realize that this will not be a problem so long as "data substitution" is used.
As far as hooking up the Blitz DSBC map sensor to the EGRT input is concerned, has anybody done this and does anybody know what kind of map sensor is used in the Blitz DSBC?
Old 08-04-2006, 04:41 PM   #118 (permalink)
og
chansigril's Avatar
Trader Rating: (43)
wow this may actually be an answer to the question that has been plaguing me all day *runs to look at scanmaster manual*
i am using my egrt to log boost. i am trying to get mmcd to see the lm-1 signal being fed into my scanmaster. be back with an update
doctordex if you'd care to follow up with how things worked out for you it'd be appreciated
Old 01-21-2007, 02:28 PM   #119 (permalink)
rdmelton's Avatar
Drives: 2000 WS6
Trader Rating: (35)
rdmelton is an unknown quantity at this point
edit - boost logging items have been sold.
rdmelton is offline   Reply With Quote
Old 01-22-2007, 08:55 AM   #120 (permalink)
Drives: 94 VR4
Trader Rating: (19)
Blue94VR4 is an unknown quantity at this point
I am interested. Pm me how much you want to it.
Thanks
94 3000GT VR4 (upgraded)
"Your 1994 Mitsubishi 3000GT VR-4 is one of 1650. There are 57 other cars that were made with both the same interior and exterior color. Exactly Identical - 8"
For sale:
1. used stock oil sender & gauges
2. used A/C belt (10K on the belt)
3. Stock front and rear sway bars.
4. 3SX dual O2 simulator
5. Used 2'' couplers/reducers/hump hoses
Blue94VR4 is offline   Reply With Quote
