LinkBack (1) Thread Tools
Old 10-05-2005, 08:29 PM   #91 (permalink)
Drives: 94 VR4
Trader Rating: (19)
Blue94VR4 is an unknown quantity at this point
Default Re: 1G Electronic Boost Data Logging
Did the install and drove around for 5 minutes. CEL did not come yet. I'll do more driving tomorrow, will see.
However, I do not get correct readings if I choose 2.5 or 3 bar sensor. My Autometer gauge shows 8psi. If I choose 3 bar sensor setting, I get 17psi, if I choose 2.5 bar - I get 12psi. This suggests my sensor is 2 bar, which is consistent with the reply I've got from Autometer tech support. Unfortunately, my hybrid logger does not have 2 bar setting. I've contacted Chris already about this. I hope he'll be able to help me out.
Thanks
Blue94VR4 is offline   Reply With Quote
Old 10-06-2005, 03:35 AM   #92 (permalink)
no speed limits here
BLACK94TT's Avatar
Drives: A109E
Trader Rating: (20)
BLACK94TT is an unknown quantity at this point
Thanks
FWIW, I've got the full sweep autometer fp gauge and I'm using the 3bar setting.
Steve
BLACK94TT is offline   Reply With Quote
Old 10-06-2005, 05:28 AM   #93 (permalink)
Member: Burned valve club
cbatters's Avatar
Drives: 91 Stealth RT/TT
Trader Rating: (12)
cbatters Level 2cbatters Level 2cbatters Level 2
Thanks
I went back and checked my earlier math. With engine off you were reporting 2.2V which is approximately 112 ADC counts.
2.5 BAR
BAR = (ADC * 0.0098039) +.1
PSI = (ADC * 0.142193511) - 13.0534
2.0 BAR
BAR = (ADC * 0.0078431) +.1
PSI = (ADC * 0.113755059) - 13.0534
2.5 bar sensor would put you about 5700' below sea level and the 2 bar would put you about 500' above sea level. So either your car was in a mile deep mine or you are at ~500' elevation (or you live closer to sea level and the weather was really awful!)
Clint
Maint: Castrol 10W40 / Mitsu Filter / Rislone
Replaced: 2X clutch / 3X brakes / 2X front rotors / 2X ABS HU / 1X NGK Plugs / 1X Ball joints / 2X Antenna mast / 1X Active exhaust cable / 1X Windshield / 1X Fuel FIlter / 1X Struts / 1X rear rotors / 1X Front Head / VSS / 1X rear wheel bearings / 1X Transfer case (warranty) / 1x Tie rod end (drivers side)
Overhauled: Starter, IAC, BISS, CV Boots
Upgrade: SilverStar Headlights / ebay "Xenon" Fog Bulbs (no more yellow!)
A/F Gauge / MAP - Electronic Boost Logging / MMCd Data Logger
Pending Projects: Steering Rack
cbatters is offline   Reply With Quote
Old 10-06-2005, 08:07 AM   #94 (permalink)
Drives: 94 VR4
Trader Rating: (19)
Clint,
I am above see level So I guess it's 2 bar for me.
Steve,
I think you are using different Autometer gauge. Mine is vacuum/boost w/ max boost of 15psi. I think yours has max boost of 30psi, right? I've contacted Autometer and they confirmed I have 2 bar sensor.
Well, I guess I'll have to wait for Shiver to include 2 bar sensor.
Thanks guys,
Sergey
PS. No CEL so far. Resistor has been removed.
Old 10-06-2005, 10:26 AM   #95 (permalink)
cbatters's Avatar
Trader Rating: (12)
Clint,
Steve,
Thanks guys,
Sergey
Pittsbug, PA Elevation - 750'
Add a few clouds and your MAP sensor is spot on.
Great info about the CEL. I didn't know if people that had removed EGR could get away with using the EGRT input for boost logging without tripping a CEL.
Clint
Old 10-06-2005, 10:35 AM   #96 (permalink)
BLACK94TT's Avatar
Drives: A109E
Trader Rating: (20)
Clint,
Steve,
Thanks guys,
Sergey
Yep, 30 psi boost max.
Old 10-06-2005, 10:36 AM   #97 (permalink)
Drives: 94 VR4
Trader Rating: (19)
Clint,
I'll let you know if CEL comes up.
Thanks,
Sergey
Old 10-23-2005, 02:13 PM   #98 (permalink)
Wanted: Traction Problems
badass3000's Avatar
Drives: 18 Y.O. "badass" VR4
Trader Rating: (19)
badass3000 Level 2badass3000 Level 2badass3000 Level 2
Originally Posted by cbatters
AUTOMETER BOOST GAGE
If you have an AutoMeter Boost gage you already have a GM 3.0 BAR MAP sensor installed. All you have to do is connect the signal wire from the MAP sensor to the EGRT input on A22. (Only connect the signal line, not the ground.)
where???
badass3000 is online now   Reply With Quote
Old 10-23-2005, 02:28 PM   #99 (permalink)
No loer a Noob?
skunkworks's Avatar
Drives: low impedance inputs
Trader Rating: (9)
skunkworks is an unknown quantity at this point
that is a machanical guage - autometer must also make a electronic boost guage - that is what clint is talking about.
Originally Posted by badass3000
where???
92 Stealth R/T TT - 13t's Installed. note:Is the machining right? - boosting to 15psi so far.
Do I do this for others? No. robbeck is your man.... We know his work
skunkworks is offline   Reply With Quote
Old 10-23-2005, 03:39 PM   #100 (permalink)
badass3000's Avatar
Trader Rating: (19)
okay, from the looks of it this was going to be a simple trick. I have a Greddy guage MAP sensor right neer the EGRT plug.
so three wires from MAP sensor (red, black, and white) I chose white and wired it to the light green with black stripe EGRT wire. configed the MMCd for 3 bar but I get a constant 113 from the BOST line.
what did I do wrong?
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f58/1g-electronic-boost-data-logging-202062/
Posted By For Type Date
Boost Logging This thread Refback 04-13-2008 10:49 PM
