LinkBack (1) Thread Tools
Old 03-11-2004, 10:34 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Member: Burned valve club
cbatters's Avatar
Drives: 91 Stealth RT/TT
Trader Rating: (12)
cbatters is an unknown quantity at this point
Default 1G Electronic Boost Data Logging
ELECTRONIC BOOST LOGGING FOR 1st GEN ECU
Just a short FAQ on an easy mod for adding a boost signal for anyone using either the MMCd or Shiver's SW on a 1G ECU. The mod takes advantage of an unused EGRT sensor on all of the Federal ECU's.
Many thanks to Jeff Lucius for putting the bug in my ear on an earlier post about an "unused input."
8/10/04 Thanks to RDMelton for pulling together additional instructions / pics on a web page.
http://rdmelton.autoeducation.com/ca.../boostlog.html
FAQ
EGRT ECU input is just a 0-5 VDC input signal on the ECU. ECU doesn't care whether it is a boost signal, wideband O2, oil pressure or fuel sensor. MMCd and Mirage Datalogger have sensor configurations to correctly scale either the 2.5 or 3.0 BAR MAP sensors.
For those of you running PocketLogger, ask them to get on the ball and provide user scaling options for the EGRT input.
WIRING
Only 3 wires to get boost logging working. +5V, Ground and signal.
Note: EGRT input has 10K ohm resistor to +4.5V to provide excitation for the EGRT sensor. This is why the logger will show raw data of ~229 counts or 90% of full scale before you connect anything to it. (If your connect the EGRT signal to EGRT ground the count will go to zero.) THe 10K pullup resistor does not have any negative effect on the accuracy of the MAP sensor.
MAP - HARNESS 3SI Updated color codes from RDMellon - Thanks!
+5V - TPS Connector (Green/Yellow)
Ground - EGTR Connector (A22 - Black)
Signal - EGTR Connector (A22 - Light Green/Black)
A-22 Connector is located near the injector resistor module - may be taped up with some other wires.
MAP - HARNESS DSM (DSM info from QuasiMondo - Thanks!)
+5V - TPS Connector (green/red)
Ground - EGTR Connector (green/black)
Signal - EGTR Connector (blue/yellow )
GM SENSOR INFO (provided by Jeff Lucius)
The GM 3-bar MAP sensor is available from MSD Ignition. Search google for MSD2313 or MSD-2313. The store below sells it for $49.70
http://www.aquamist.co.uk/sl/plist/p...6/806-666.html
You'll also need a socket/harness connector. Conduct Tite (PN 85146) sells some that are a close match or that may need only a little bit of knife work to make the correct notch for the key on the sensor connector. See middle pic and red rectangle in the web page below for where notch needs to be added.
http://www.tognottisautoworld.com/se...UCT_ID=MSD2313
http://www.hondata.com/3barinstall.html
Better GM Map Connector - Thanks to Fakepower
AC delco Part #PT1035 .... here are some pics of the cable.
http://www.3si.org/forum/attachment....chmentid=41842
http://www.3si.org/forum/attachment....chmentid=41843
ALTERNATE SOURCE for GM SENSOR (Provided by TurboBob)
www.gmpartsdirect.com
Sensor part number 12223861
Connector # 15305891
AUTOMETER BOOST GAGE
If you have an AutoMeter Boost gage you already have a GM 3.0 BAR MAP sensor installed. All you have to do is connect the signal wire from the MAP sensor to the EGRT input on A22. (Only connect the signal line, not the ground.)
MOTOROLLA MPX4250AP MAP SENSOR
You can also use a Motorolla MPX4250AP 2.5 BAR sensor but you will have to either solder or find a suitable connector for the small leads and provide some mechanical protection for the sensor. (Consider using a .100" connector for easy attachment / service.)
PINOUT
PIN1 - Vout (Signal) Note: Pin 1 has notch on pin
PIN2 - GND
PIN3 - +5V
PIN4 - NC
PIN5 - NC
PIN6 - NC
ORDERING INFO
http://rocky.digikey.com/WebLib/Moto...A%20SERIES.pdf
Exact part number is MPX4250AP-ND. It is available for under $20 directly from DigiKey.
HISTORY
Boost signal on ECU-EGR input for logging
MMCd V1.6F posted 3/17/04
http://www.3si.org/forum/attachment....chmentid=35334
More MMCd info / Latest versions
MMCd New Features
Clint
Maint: Castrol 10W40 / Mitsu Filter / Rislone
Replaced: 2X clutch / 3X brakes / 2X front rotors / 2X ABS HU / 1X NGK Plugs / 1X Ball joints / 2X Antenna mast / 1X Active exhaust cable / 1X Windshield / 1X Fuel FIlter / 1X Struts / 1X rear rotors / 1X Front Head / VSS / 1X rear wheel bearings / 1X Transfer case (warranty) / 1x Tie rod end (drivers side)
Overhauled: Starter, IAC, BISS, CV Boots
Upgrade: SilverStar Headlights / ebay "Xenon" Fog Bulbs (no more yellow!)
A/F Gauge / MAP - Electronic Boost Logging / MMCd Data Logger
Pending Projects: Steering Rack
cbatters is offline   Reply With Quote
Old 03-12-2004, 01:03 PM   #2 (permalink)
No loer a Noob?
skunkworks's Avatar
Drives: low impedance inputs
Trader Rating: (9)
skunkworks is an unknown quantity at this point
Default Re: 1G Electronic Boost Data Logging
Nice work. I just noticed I was using verison 1.4. Just installed 1.6e and going to give it a try on my lunch hour. Looks like a map sensor is on the "things to order list".
thanks
sam
92 Stealth R/T TT - 13t's Installed. note:Is the machining right? - boosting to 15psi so far.
Do I do this for others? No. robbeck is your man.... We know his work
skunkworks is offline   Reply With Quote
Old 03-12-2004, 01:14 PM   #3 (permalink)
cbatters's Avatar
Trader Rating: (12)
thanks
sam
Couple things to try during lunch...
1. When you turn off your car, the Palm will automatically power off within ~10 seconds. Pressing F4 (right hand button) after you start your car will automatically un-pause the unit and start scanning.
2. Try programming O2 alarms for any voltage < .85 V Previously the O2 alarms were useless because the alarm would always go off during closed loop operation. Now the O2 alarms are gated with TPS > 80% so they are disabled during closed loop operation / deceleration.
(I believe Shiver / Chris has implemented this in the most recent version of his SW. Pretty sure PocketLogger does not have this function.)
Clint
Old 03-12-2004, 01:37 PM   #4 (permalink)
No loer a Noob?
skunkworks's Avatar
Trader Rating: (9)
The turning off is great. I didn't even notice it. I shut the car off and went to do some banking came back out and started it up and drove. I looked and the abs light wasn't on like it was when I would forget to unplug the cable. very cool. turned it back on and strarted datalogging again.
sam
Clint
Old 03-12-2004, 04:14 PM   #5 (permalink)
No loer a Noob?
skunkworks's Avatar
Trader Rating: (9)
Did anyone ever come up with a way to convert the log files into text files or something usable?
thanks
sam
Old 03-14-2004, 06:52 PM   #6 (permalink)
cbatters's Avatar
Trader Rating: (12)
thanks
sam
Check the MMCd thread for the prototype converter. I had some stability problems but it did a good job of converting the logs.
Clint
Old 03-17-2004, 09:56 AM   #7 (permalink)
No loer a Noob?
skunkworks's Avatar
Trader Rating: (9)
Clint
Did you come up with a wiring diagram? I would rather just hack into the harness to hook it up. I am thinking that I will use it instead of trying to find a place for a gauge. MBC here I come!! (although I have a guage coming )
thanks
sam
Old 03-17-2004, 10:07 AM   #8 (permalink)
No loer a Noob?
skunkworks's Avatar
Trader Rating: (9)
never mind - I just read it again.
thanks
sam
Old 03-17-2004, 11:49 AM   #9 (permalink)
cbatters's Avatar
Trader Rating: (12)
thanks
sam
You can put the MAP sensor inside the car if you had already run the boost vacuum line into the cab by tapping into the signals at the ECU. However, it is actually easier to wire it up under the hood where all of the signals and vacuum connections are easily accessible.
MAP sensor / Palm is an interesting alternative to installing a dedicated turbo gage and offers the option of alarms and logging.
In the brief time I hooked up a manual goost gage, I found if difficult/dangerous to monitor boost while at WOT. With the logger, I can focus on driving with alarms set for O2, Knock, INJD and Boost and then review data after the run.
NEXT PROJECT
Next thing on my list are some mods to the MMCd SW (peak / log triggers) and an interface for adding additional instrumentation to the MMCd logger.
New inputs would include:
o Boost
o EGT
o Wideband O2
o Speed
- MPG
- 0-60 timing
- AWD HP
o Intake Manifold Air Temp
o Fuel Pressure
o Oil Pressure
o Others
Clint
Old 03-17-2004, 12:26 PM   #10 (permalink)
No loer a Noob?
skunkworks's Avatar
Trader Rating: (9)
Nice work
My thoughts exactly.
Mainly going to be using it to set the mbc anyway then after that it will be a log with alarms. My stock boost solenoid only works about 70% of the time.
I didn't think there was a wiring diagram until I reread your first post and saw -
+5V - TPS Connector (Green/White)
Signal - EGTR Connector (A22 - Green/Black)
that is all I needed. I am also going to mount it under the hood. I ordered the 2.5bar sensor from digikey but it will not be in until the end of the month.
Really quit excited about it.
NEXT PROJECT
o Boost
o EGT
o Wideband O2
o Speed
- MPG
- 0-60 timing
- AWD HP
o Fuel Pressure
o Oil Pressure
o Others
Clint
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f58/1g-electronic-boost-data-logging-202062/
Posted By For Type Date
Boost Logging This thread Refback 04-14-2008 02:49 AM
